  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.7k Views 1 Watching
  • tekkaT tekka
    @karl261 said:
    @tekka Now it seems to work.
    But I recompiled, because I had MY_DEBUG commented out. Somehow there is something wrong with debug...
    You mean, if MY_DEBUG is commented out, the node does not communicate over the repeater (99)?
    karl261K
    karl261K
    karl261
    @tekka Well, yes, I added the two lines you suggested, re-compiled, and then it was not using the 99. And also some posts above, I had these weird messages transmitted 6-7 times, see logs. This happend while MY_DEBUG was commented out.
    Hm, I can re-upload the sketch and see if this is reproducible.
    tekkaT 1 Reply Last reply
    • karl261K karl261
      tekkaT
      tekkaT
      tekka
      @karl261 Yes, that would be good - node 30 is running@1Mhz?
      karl261K 3 Replies Last reply
      • tekkaT tekka
        karl261K
        karl261K
        karl261
        @tekka Yes, @1 MHz.
        • tekkaT tekka
          karl261K
          karl261K
          karl261
          @tekka No, it seems to work as expected. Any idea why I am getting this "fail" line?
          23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:READ 30-30-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
          23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:BC
          23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=30)
          23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:CHKUPL:OK
          23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:GWL OK
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-30-30 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
          23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          23.08.2016 00:30:35	RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
          23.08.2016 00:30:35	RX	30;255;3;0;6;99
          23.08.2016 00:30:35	TX	30;255;3;0;6;M
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
          23.08.2016 00:30:35	RX	30;255;3;0;12;1.0 151106
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
          23.08.2016 00:30:35	RX	30;1;0;0;7;
          23.08.2016 00:30:35	DEBUG	Update child id=1, type=S_HUM
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.3
          23.08.2016 00:30:35	RX	30;0;1;0;0;24.3
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:73
          23.08.2016 00:30:35	RX	30;1;1;0;1;73
          23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0:91
          23.08.2016 00:30:35	RX	30;255;3;0;0;91
          • karl261K karl261
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            #36
            @karl261 Does it fail regularly?
            karl261K 1 Reply Last reply
            • tekkaT tekka
              karl261K
              karl261K
              karl261
              wrote on last edited by karl261
              #37
              @tekka yes, these fails come and go, I see them all the time, but not at the same place necessarily. The logs posted above show plenty of them.
              I don't understand this radio trouble.,the distances between the nodes are not long. The radios are all connected using all tricks, the relay is a nrf24+pa+lna which is located in a good location... Maybe all radios are crap? There is only one wifi network and it is not very busy... It's my own. Maybe I should change the channel? 110 or so sounds good. I am using default now. Power is set to max for all nodes, the nrf24+pa+lna is shielded from itself, I put small antenna extensions on the normal ones after @petewill, they all have nice caps, gw and repeater have excellent power sources, ...
              I found a script how to test nrf radios... Maybe I should try that?
              If I was going to buy new radios, just to try, which ones are the best???
              Edit: Hm, I think if I use antennas, it really helps if they all point into the same direction. Like all horizontal or all vertical. Which would make sens, wouldn't it?
              • tekkaT tekka
                karl261K
                karl261K
                karl261
                @tekka But now I found something: the repeater sketch does not work, if MY_DEBUG is commented out. I tried several times forth and back. On the gw I get the output below.
                0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
                0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                tekkaT karl261K 2 Replies Last reply
                • karl261K karl261
                  tekkaT
                  tekkaT
                  tekka
                  #39
                  @karl261 That's weird - I've just tested that scenario and everything is fine here.
                  Can you add an indicator in loop() to make sure the repeater sketch is running? Also, what board are you using as repeater and how do you power it?
                  • tekkaT tekka
                    karl261K
                    karl261K
                    karl261
                    @tekka I will try this a bit later, thanks.
                    Right now I am going crazy, the node is again not using the defined parent. Did I overlook something in the sketch?
                    TSM:INIT
                    TSM:RADIO:OK
                    TSP:ASSIGNID:OK (ID=4)
                    TSM:FPAR
                    TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                    TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                    TSP:MSG:PAR OK (ID=0, dist=1)
                    TSM:FPAR:OK
                    TSM:ID
                    TSM:CHKID:OK (ID=4)
                    TSM:UPL
                    TSP:PING:SEND (dest=0)
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                    TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                    TSP:MSG:PONG RECV (hops=1)
                    TSP:CHKUPL:OK
                    TSM:UPL:OK
                    TSM:READY
                    BME init success!
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                    TSP:MSG:SEND 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                    TSP:MSG:READ 0-0-4 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:OUTSIDE P&T&H
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.2
                    TSP:MSG:SEND 4-4-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                    TSP:MSG:SEND 4-4-0-0 s=2,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=ok:
                    TSP:MSG:SEND 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                    Request registration...
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                    TSP:MSG:READ 0-0-4 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                    Node registration=1
                    Init complete, id=4, parent=0, distance=1, registration=1
                    TSP:MSG:SEND 4-4-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.7
                    TSP:MSG:SEND 4-4-0-0 s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:57
                    TSP:MSG:SEND 4-4-0-0 s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=ok:1012.9
                    TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:115
                    by m26872, 20151109
                    #define MY_PARENT_NODE_ID 99
                    #define MY_NODE_ID 4
                    #define MY_BAUD_RATE 9600
                    #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                    #include <RunningAverage.h>
                    #include <SparkFunBME280.h>
                    //#define DEBUG   // local debug
                    #ifdef DEBUG
                    // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                    #define CHILD_ID_HUM 0
                    #define CHILD_ID_TEMP 1
                    #define CHILD_ID_PRES 2
                     #define SLEEP_TIME 15000 // 15s for DEBUG
                    //#define SLEEP_TIME 300000   // 5 min
                    #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                    #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                    #define VMIN 1900
                    #define VMAX 3300
                    #define PRES_TRANSMIT_THRESHOLD 1.0
                    #define AVERAGES 2
                    int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                    int measureCount = 0;
                    float lastTemperature = -100;
                    float lastPressure = -100;
                    int lastHumidity = -100;
                    //SI7021 humiditySensor;
                    BME280 mySensor;
                    // MyMessage to controler
                    MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                      sendSketchInfo("OUTSIDE P&T&H", "1.2");
                      present(CHILD_ID_PRES, S_BARO);
                      present(CHILD_ID_HUM, S_HUM);
                      DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                      DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                      DEBUG_PRINT("Voltage: ");
                      DEBUG_PRINT(readVcc());
                      DEBUG_PRINTLN(" mV");
                      delay(500);
                      DEBUG_PRINTLN(" *C");
                      mySensor.settings.commInterface = I2C_MODE;
                      mySensor.settings.I2CAddress = 0x77;
                      //runMode can be:
                      //  0, Sleep mode
                      //  1 or 2, Forced mode
                      //  3, Normal mode
                      mySensor.settings.runMode = 1;
                      mySensor.settings.filter = 0;
                      mySensor.settings.tempOverSample = 1;
                      mySensor.settings.pressOverSample = 1;
                      mySensor.settings.humidOverSample = 1;
                      if (!mySensor.begin())
                        Serial.println("BME init failed!");
                        while (1);
                      else Serial.println("BME init success!");
                      raHum.clear();
                      measureCount ++;
                      batteryReportCounter ++;
                      bool forceTransmit = false;
                      if (measureCount > FORCE_TRANSMIT_CYCLE) {
                        forceTransmit = true;
                      mySensor.begin();
                      // Read and print internal temp
                      float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                      DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                      // Check battery
                      if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                        long batteryVolt = readVcc();
                        DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                        uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                        DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                        batteryReportCounter = 0;
                      sleep(SLEEP_TIME);
                    //if(isTransportOK()){
                    //    sleep(SLEEP_TIME);  // transport is OK, node can sleep
                    //  else {
                    //    wait(5000); // transport is not operational, allow the transport layer to fix this
                    // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                    // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                    long readVcc() {
                      result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                    // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                    double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                      unsigned int wADC;
                      double t;
                      // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                      ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                      ADCSRA |= _BV(ADEN);  // enable the ADC
                      delay(20);            // wait for voltages to become stable.
                      ADCSRA |= _BV(ADSC);  // Start the ADC
                      while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                      wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                      t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                      return (t);   // The returned temperature in degrees Celcius.
                     * Parameters
                      bool tx = force;
                      float temperature = mySensor.readTempC();
                      if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                        send(msgTemp.set(temperature,1));
                        measureCount = 0;
                        DEBUG_PRINTLN("T sent!");
                      int humidity = mySensor.readFloatHumidity();
                      raHum.addValue(humidity);
                      if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                        send(msgHum.set(humidity));
                        lastHumidity = humidity;
                        measureCount = 0;
                        DEBUG_PRINTLN("H sent!");
                      float pressure = mySensor.readFloatPressure()/100.0;
                      DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                      float diffPress = abs(lastPressure - pressure);
                      DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                      if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                        send(msgPres.set(pressure,1));
                        lastPressure = pressure;
                        measureCount = 0;
                        DEBUG_PRINTLN("P sent!");
                    • karl261K
                      karl261K
                      karl261
                      Total madness: I uploaded the same sketch again, and now it is using 99.
                      Questions:
                      1. Can I see in the log whether it "found" the parent or if it is using the parent I put into the sketch?
                      2. Is it possible to avoid this transport failure counter? Like, when I put
                        into my sketch I just want the node to send, whether it reaches the parent or not. Is that possible?
                      • karl261K karl261
                        karl261K
                        karl261K
                        karl261
                        I checked and re-programmed the repeater. It seems that it has gone away. I can use my repeater without MY_DEBUG. I don't know what caused this, but the repeater is working now.
