  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.7k Views 1 Watching
  • karl261K karl261
    @tekka Node 30 does still not care about the two lines. It is sending direct.
    It also does not send back any routing table. Maybe because it is sleeping most of the time?
    tekkaT
    tekkaT
    tekka
    @karl261 If it's not defined as repeater, it won't have a routing table. And yes, sleeping nodes do not listen for incoming traffic. But still, if GW and node 99 are up, it should prefer 99 - can you show me the log of node 30 during booting?
    karl261K 1 Reply Last reply
    • tekkaT tekka
      karl261K
      karl261K
      karl261
      wrote on last edited by karl261
      #30
      @tekka Now it seems to work.
      But I recompiled, because I had MY_DEBUG commented out. Somehow there is something wrong with debug...
      TSM:INIT
      TSM:RADIO:OK
      TSP:ASSIGNID:OK (ID=30)
      TSM:FPAR
      TSP:MSG:SEND 30-30-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
      TSP:MSG:READ 3-3-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
      TSP:MSG:FPAR RES (ID=3, dist=1)
      TSP:MSG:PAR OK (ID=3, dist=2)
      TSP:MSG:READ 99-99-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
      TSP:MSG:FPAR RES (ID=99, dist=1)
      TSP:MSG:FPAR (PPAR FOUND)
      TSP:MSG:PAR OK (ID=99, dist=2)
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=30)
      TSM:UPL
      TSP:PING:SEND (dest=0)
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
      TSP:MSG:READ 0-0-30 s=255,c=3,t=8,pt=1,l=1,sg=0:0
      TSP:MSG:READ 0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0:2
      TSP:MSG:PONG RECV (hops=2)
      TSP:CHKUPL:OK
      TSM:UPL:OK
      TSM:READY
      Serial started
      Voltage: 3289 mV
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
      TSP:MSG:SEND 30-30-99-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:99
      TSP:MSG:READ 0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:EgTmpHumBat5min
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0,ft=0,st=ok:1.0 151106
      TSP:MSG:SEND 30-30-99-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
      TSP:MSG:SEND 30-30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
      Node and 2 children presented.
      Request registration...
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
      TSP:MSG:READ 0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0:1
      Node registration=1
      Init complete, id=30, parent=99, distance=2, registration=1
      T: 21.59
      TempDiff :121.59
      TSP:MSG:SEND 30-30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.6
      T sent!
      H: 81
      HumDiff  :181.00
      TSP:MSG:SEND 30-30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:81
      H sent!
      Battery voltage: 3279 mV
      Battery percent: 98 %
      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:98
      T: 21.61
      TempDiff :0.02
      H: 81
      HumDiff  :0.00
      tekkaT 1 Reply Last reply
      • karl261K karl261
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:FPAR:OK
        TSM:ID
        TSM:UPL
        TSP:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        Serial started
        Voltage: 3289 mV
        Node registration=1
        T: 21.59
        TempDiff :121.59
        T sent!
        H: 81
        HumDiff  :181.00
        H sent!
        T: 21.61
        TempDiff :0.02
        H: 81
        HumDiff  :0.00
        tekkaT
        tekkaT
        tekka
        You mean, if MY_DEBUG is commented out, the node does not communicate over the repeater (99)?
        • tekkaT tekka
          karl261K
          karl261K
          karl261
          @tekka Well, yes, I added the two lines you suggested, re-compiled, and then it was not using the 99. And also some posts above, I had these weird messages transmitted 6-7 times, see logs. This happend while MY_DEBUG was commented out.
          Hm, I can re-upload the sketch and see if this is reproducible.
          • karl261K karl261
            tekkaT
            tekkaT
            tekka
            @karl261 Yes, that would be good - node 30 is running@1Mhz?
            karl261K 3 Replies Last reply
            • tekkaT tekka
              karl261K
              karl261K
              karl261
              @tekka Yes, @1 MHz.
              • tekkaT tekka
                karl261K
                karl261K
                karl261
                @tekka No, it seems to work as expected. Any idea why I am getting this "fail" line?
                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:READ 30-30-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:BC
                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=30)
                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:CHKUPL:OK
                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:GWL OK
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-30-30 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                23.08.2016 00:30:35	RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
                23.08.2016 00:30:35	RX	30;255;3;0;6;99
                23.08.2016 00:30:35	TX	30;255;3;0;6;M
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
                23.08.2016 00:30:35	RX	30;255;3;0;12;1.0 151106
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
                23.08.2016 00:30:35	RX	30;1;0;0;7;
                23.08.2016 00:30:35	DEBUG	Update child id=1, type=S_HUM
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.3
                23.08.2016 00:30:35	RX	30;0;1;0;0;24.3
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:73
                23.08.2016 00:30:35	RX	30;1;1;0;1;73
                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0:91
                23.08.2016 00:30:35	RX	30;255;3;0;0;91
                • karl261K karl261
                  tekkaT
                  tekkaT
                  tekka
                  wrote on last edited by tekka
                  #36
                  @karl261 Does it fail regularly?
                  • tekkaT tekka
                    karl261K
                    karl261K
                    karl261
                    #37
                    @tekka yes, these fails come and go, I see them all the time, but not at the same place necessarily. The logs posted above show plenty of them.
                    I don't understand this radio trouble.,the distances between the nodes are not long. The radios are all connected using all tricks, the relay is a nrf24+pa+lna which is located in a good location... Maybe all radios are crap? There is only one wifi network and it is not very busy... It's my own. Maybe I should change the channel? 110 or so sounds good. I am using default now. Power is set to max for all nodes, the nrf24+pa+lna is shielded from itself, I put small antenna extensions on the normal ones after @petewill, they all have nice caps, gw and repeater have excellent power sources, ...
                    I found a script how to test nrf radios... Maybe I should try that?
                    If I was going to buy new radios, just to try, which ones are the best???
                    Edit: Hm, I think if I use antennas, it really helps if they all point into the same direction. Like all horizontal or all vertical. Which would make sens, wouldn't it?
                    • tekkaT tekka
                      karl261K
                      karl261K
                      karl261
                      @tekka But now I found something: the repeater sketch does not work, if MY_DEBUG is commented out. I tried several times forth and back. On the gw I get the output below.
                      0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
                      0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                      tekkaT karl261K 2 Replies Last reply
                      • karl261K karl261
                        tekkaT
                        tekkaT
                        tekka
                        #39
                        @karl261 That's weird - I've just tested that scenario and everything is fine here.
                        Can you add an indicator in loop() to make sure the repeater sketch is running? Also, what board are you using as repeater and how do you power it?
                        • tekkaT tekka
                          karl261K
                          karl261K
                          karl261
                          @tekka I will try this a bit later, thanks.
                          Right now I am going crazy, the node is again not using the defined parent. Did I overlook something in the sketch?
                          TSM:INIT
                          TSM:RADIO:OK
                          TSP:ASSIGNID:OK (ID=4)
                          TSM:FPAR
                          TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSP:MSG:PAR OK (ID=0, dist=1)
                          TSM:FPAR:OK
                          TSM:ID
                          TSM:CHKID:OK (ID=4)
                          TSM:UPL
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                          TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          TSP:MSG:PONG RECV (hops=1)
                          TSP:CHKUPL:OK
                          TSM:UPL:OK
                          TSM:READY
                          BME init success!
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                          TSP:MSG:SEND 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                          TSP:MSG:READ 0-0-4 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:OUTSIDE P&T&H
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.2
                          TSP:MSG:SEND 4-4-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                          TSP:MSG:SEND 4-4-0-0 s=2,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=ok:
                          TSP:MSG:SEND 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                          TSP:MSG:READ 0-0-4 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          Node registration=1
                          Init complete, id=4, parent=0, distance=1, registration=1
                          TSP:MSG:SEND 4-4-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.7
                          TSP:MSG:SEND 4-4-0-0 s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:57
                          TSP:MSG:SEND 4-4-0-0 s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=ok:1012.9
                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:115
                          by m26872, 20151109
                          #define MY_PARENT_NODE_ID 99
                          #define MY_NODE_ID 4
                          #define MY_BAUD_RATE 9600
                          #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                          #include <RunningAverage.h>
                          #include <SparkFunBME280.h>
                          //#define DEBUG   // local debug
                          #ifdef DEBUG
                          // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                          #define CHILD_ID_HUM 0
                          #define CHILD_ID_TEMP 1
                          #define CHILD_ID_PRES 2
                           #define SLEEP_TIME 15000 // 15s for DEBUG
                          //#define SLEEP_TIME 300000   // 5 min
                          #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                          #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                          #define VMIN 1900
                          #define VMAX 3300
                          #define PRES_TRANSMIT_THRESHOLD 1.0
                          #define AVERAGES 2
                          int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                          int measureCount = 0;
                          float lastTemperature = -100;
                          float lastPressure = -100;
                          int lastHumidity = -100;
                          //SI7021 humiditySensor;
                          BME280 mySensor;
                          // MyMessage to controler
                          MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                            sendSketchInfo("OUTSIDE P&T&H", "1.2");
                            present(CHILD_ID_PRES, S_BARO);
                            present(CHILD_ID_HUM, S_HUM);
                            DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                            DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                            DEBUG_PRINT("Voltage: ");
                            DEBUG_PRINT(readVcc());
                            DEBUG_PRINTLN(" mV");
                            delay(500);
                            DEBUG_PRINTLN(" *C");
                            mySensor.settings.commInterface = I2C_MODE;
                            mySensor.settings.I2CAddress = 0x77;
                            //runMode can be:
                            //  0, Sleep mode
                            //  1 or 2, Forced mode
                            //  3, Normal mode
                            mySensor.settings.runMode = 1;
                            mySensor.settings.filter = 0;
                            mySensor.settings.tempOverSample = 1;
                            mySensor.settings.pressOverSample = 1;
                            mySensor.settings.humidOverSample = 1;
                            if (!mySensor.begin())
                              Serial.println("BME init failed!");
                              while (1);
                            else Serial.println("BME init success!");
                            raHum.clear();
                            measureCount ++;
                            batteryReportCounter ++;
                            bool forceTransmit = false;
                            if (measureCount > FORCE_TRANSMIT_CYCLE) {
                              forceTransmit = true;
                            mySensor.begin();
                            // Read and print internal temp
                            float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                            DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                            // Check battery
                            if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                              long batteryVolt = readVcc();
                              DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                              uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                              DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                              batteryReportCounter = 0;
                            sleep(SLEEP_TIME);
                          //if(isTransportOK()){
                          //    sleep(SLEEP_TIME);  // transport is OK, node can sleep
                          //  else {
                          //    wait(5000); // transport is not operational, allow the transport layer to fix this
                          // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                          // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                          long readVcc() {
                            result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                          // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                          double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                            unsigned int wADC;
                            double t;
                            // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                            ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                            ADCSRA |= _BV(ADEN);  // enable the ADC
                            delay(20);            // wait for voltages to become stable.
                            ADCSRA |= _BV(ADSC);  // Start the ADC
                            while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                            wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                            t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                            return (t);   // The returned temperature in degrees Celcius.
                           * Parameters
                            bool tx = force;
                            float temperature = mySensor.readTempC();
                            if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                              send(msgTemp.set(temperature,1));
                              measureCount = 0;
                              DEBUG_PRINTLN("T sent!");
                            int humidity = mySensor.readFloatHumidity();
                            raHum.addValue(humidity);
                            if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                              send(msgHum.set(humidity));
                              lastHumidity = humidity;
                              measureCount = 0;
                              DEBUG_PRINTLN("H sent!");
                            float pressure = mySensor.readFloatPressure()/100.0;
                            DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                            float diffPress = abs(lastPressure - pressure);
                            DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                            if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                              send(msgPres.set(pressure,1));
                              lastPressure = pressure;
                              measureCount = 0;
                              DEBUG_PRINTLN("P sent!");
                          • karl261K
                            karl261K
                            karl261
                            Total madness: I uploaded the same sketch again, and now it is using 99.
                            Questions:
                            1. Can I see in the log whether it "found" the parent or if it is using the parent I put into the sketch?
                            2. Is it possible to avoid this transport failure counter? Like, when I put
                              into my sketch I just want the node to send, whether it reaches the parent or not. Is that possible?
                            • karl261K karl261
                              karl261K
                              karl261K
                              karl261
                              I checked and re-programmed the repeater. It seems that it has gone away. I can use my repeater without MY_DEBUG. I don't know what caused this, but the repeater is working now.
