  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.2k Views 1 Watching
  • K Offline
    K Offline
    karl261
    Hi, this is all about the 2.0.0 master stable release. All systems use this code.
    I have 1 gateway, 1 repeater and 1 sensor node. The sensor node is a bit far from the gateway, so I put a repeater node in the middle with an amplified nrf24 version and the real antenna.
    Now what I see from the serial monitor is that gateway and repeater are up and running and the sensor node too.
    My problem is, that I cannot get the sensor node to use the repeater.
    If I bring the sensor close to the gateway they talk directly to each other. If I bring it further away, it does not switch over to use the repeater, but communication just remains dead (for days).
    I did try the MY_PARENT_NODE_ ID but it does not do anything. Even if I bring all 3 devices close together, the repeater is not being used.
    Can anyone confirm this behaviour? I am using the example sketches for gateway and repeater, and a very simple sketch for the sensor.
    Thanks for any ideas!
    T 1 Reply Last reply
    • K karl261
      T Offline
      T Offline
      tekka
      @karl261 Please post the full debug log of all nodes.
      • K Offline
        K Offline
        karl261
        Yes, I can do that, but only in about 4 weeks, because I am away.
        For my understanding: MY_PARENT_NODE_ ID is the correct approach for forcing traffic through a certain repeater, isn't it?
        • K Offline
          K Offline
          karl261
          @tekka I am still struggling with my repeater node. Below the output of the gateway (via pimatic-mysensors).
          So, when I switch on the repeater, why do I get these two "fail" messages? I can see in the log of the repeater that they are received well.
          Also, I noticed that the repeater is sending from time to time something to the gateway:
          mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
          13:32:51debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
          13:32:51debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
          Seems to be some sort of check that the routing table is still ok? When is it supposed to send that? Because sometimes it is not sending this for half an hour, then it is sending this every 20 seconds or so...
          debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
          13:31:11debug [pimatic-mysensors]: <- I_SKETCH_VERSION  99;255;3;0;12;1.0
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
          13:31:11debug [pimatic-mysensors]: <- I_SKETCH_NAME  99;255;3;0;11;Repeater Node
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Repeater Node
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=fail:M
          13:31:11debug [pimatic-mysensors]: -> Sending  99;255;3;0;6;M
          13:31:11debug [pimatic-mysensors]: <- I_CONFIG  99;255;3;0;6;0
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
          13:31:11debug [pimatic-mysensors]: <- Presented Node  [ '99', '255', '0', '0', '18', '2.0.0' ]
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=0,t=18,pt=0,l=5,sg=0:2.0.0
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
          13:31:11debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
          13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
          13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:GWL OK
          13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:CHKUPL:OK
          13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
          13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:BC
          13:31:09debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
          • K Offline
            K Offline
            karl261
            Also, I can't really figure out what is failing here. This was when I was switching a node on. Later I see that it is transmitting data from time to time. I also can't figure out why the repeater is transmitting the data five times.
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=fail:M
            14:23:24debug [pimatic-mysensors]: -> Sending  30;255;3;0;6;M
            14:23:24debug [pimatic-mysensors]: <- I_CONFIG  30;255;3;0;6;99
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
            14:23:24debug [pimatic-mysensors]: <- Presented Node  [ '30', '1', '0', '0', '7', '' ]
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
            14:23:24debug [pimatic-mysensors]: <- Presented Node  [ '30', '0', '0', '0', '6', '' ]
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=0,t=6,pt=0,l=0,sg=0:
            14:23:24debug [pimatic-mysensors]: <- I_SKETCH_VERSION  30;255;3;0;12;1.0 151106
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
            14:23:24debug [pimatic-mysensors]: <- I_SKETCH_NAME  30;255;3;0;11;EgTmpHumBat5min
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=11,pt=0,l=15,sg=0:EgTmpHumBat5min
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
            14:23:24debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
            14:23:23debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
            14:23:23debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
            14:23:23debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
            14:33:46debug [pimatic-mysensors]: <- MySensorDHT  { sender: 30, sensor: 1, type: 1, value: '57' }
            14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:57
            14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
            14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
            14:33:46debug [pimatic-mysensors]: <- I_LOG_MESSAGE  0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
            • K Offline
              K Offline
              karl261
              Something is wrong. In case somebody cares about a bit more debug output.
              99 Repeater
              4 Some outside node BME280
              30 Outside node SI7021
              Somewhere towards the end I toggled the power of the repeater node.
              I go and get some log from the repeater.
              0;255;3;0;9;TSM:INIT
              0;255;3;0;9;TSM:RADIO:OK
              0;255;3;0;9;TSM:GW MODE
              0;255;3;0;9;TSM:READY
              0;255;0;0;18;2.0.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
              2;1;1;0;0;20.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.9
              2;0;1;0;1;73.9
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.5
              3;1;1;0;0;20.5
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.6
              3;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.0
              2;1;1;0;0;21.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.4
              2;0;1;0;1;74.4
              0;255;3;0;9;TSP:SANCHK:OK
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.5
              2;1;1;0;0;19.5
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.6
              2;0;1;0;1;73.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.0
              2;1;1;0;0;19.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.2
              2;0;1;0;1;73.2
              0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:61
              30;1;1;0;1;61
              30;1;1;0;1;61
              30;1;1;0;1;61
              30;1;1;0;1;61
              3;1;1;0;0;20.5
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:41
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              3;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.4
              2;1;1;0;0;20.4
              2;0;1;0;1;73.9
              2;1;1;0;0;19.5
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.7
              2;0;1;0;1;73.7
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.7
              2;1;1;0;0;20.7
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.4
              2;0;1;0;1;73.4
              3;1;1;0;0;20.5
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.6
              2;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.1
              2;0;1;0;1;73.1
              3;1;1;0;0;20.6
              2;1;1;0;0;19.5
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.5
              2;0;1;0;1;73.5
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              3;1;1;0;0;20.5
              2;1;1;0;0;20.7
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.0
              2;0;1;0;1;74.0
              3;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.0
              3;0;1;0;1;61.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:18.9
              2;1;1;0;0;18.9
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:72.9
              2;0;1;0;1;72.9
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.6
              4;1;1;0;0;26.6
              4;1;1;0;0;26.6
              4;1;1;0;0;26.6
              4;1;1;0;0;26.6
              4;1;1;0;0;26.6
              4;1;1;0;0;26.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:18.8
              2;1;1;0;0;18.8
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:72.7
              2;0;1;0;1;72.7
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.1
              3;0;1;0;1;61.1
              2;1;1;0;0;19.5
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.3
              2;0;1;0;1;73.3
              3;1;1;0;0;20.5
              2;1;1;0;0;20.6
              2;0;1;0;1;73.9
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:19.6
              2;1;1;0;0;19.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:73.8
              2;0;1;0;1;73.8
              2;1;1;0;0;20.4
              2;0;1;0;1;74.4
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.2
              2;1;1;0;0;20.2
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.3
              2;0;1;0;1;74.3
              2;1;1;0;0;20.7
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.7
              2;0;1;0;1;74.7
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.5
              2;1;1;0;0;20.5
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.5
              2;0;1;0;1;74.5
              2;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.6
              2;0;1;0;1;74.6
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.8
              2;1;1;0;0;20.8
              2;0;1;0;1;74.7
              2;1;1;0;0;21.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.8
              2;0;1;0;1;74.8
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:20.9
              2;1;1;0;0;20.9
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:74.9
              2;0;1;0;1;74.9
              2;1;1;0;0;21.0
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.2
              3;0;1;0;1;61.2
              2;1;1;0;0;20.6
              2;0;1;0;1;74.6
              3;0;1;0;1;61.1
              2;1;1;0;0;20.5
              2;0;1;0;1;74.7
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              4;1;1;0;0;26.0
              2;1;1;0;0;20.8
              3;1;1;0;0;20.6
              2;1;1;0;0;20.9
              2;0;1;0;1;74.9
              3;1;1;0;0;20.5
              3;0;1;0;1;61.2
              2;1;1;0;0;20.6
              2;0;1;0;1;74.7
              2;1;1;0;0;20.8
              2;0;1;0;1;74.8
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:45
              4;0;1;0;1;45
              4;0;1;0;1;45
              4;0;1;0;1;45
              4;0;1;0;1;45
              4;0;1;0;1;45
              2;1;1;0;0;20.4
              2;0;1;0;1;74.6
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.5
              4;1;1;0;0;26.5
              4;1;1;0;0;26.5
              4;1;1;0;0;26.5
              4;1;1;0;0;26.5
              4;1;1;0;0;26.5
              4;1;1;0;0;26.5
              2;1;1;0;0;20.7
              2;0;1;0;1;74.9
              3;1;1;0;0;20.6
              3;1;1;0;0;20.5
              3;0;1;0;1;61.1
              2;1;1;0;0;21.0
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:75.0
              2;0;1;0;1;75.0
              2;1;1;0;0;20.6
              2;0;1;0;1;74.7
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.1
              2;1;1;0;0;21.1
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:75.1
              2;0;1;0;1;75.1
              2;1;1;0;0;20.8
              2;0;1;0;1;75.0
              3;0;1;0;1;61.2
              2;1;1;0;0;21.1
              2;0;1;0;1;75.1
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              4;0;1;0;1;41
              3;0;1;0;1;61.1
              2;1;1;0;0;20.5
              2;0;1;0;1;74.8
              3;0;1;0;1;61.2
              2;1;1;0;0;20.4
              2;0;1;0;1;74.7
              3;0;1;0;1;61.1
              2;1;1;0;0;20.8
              2;0;1;0;1;73.6
              2;1;1;0;0;20.9
              2;0;1;0;1;75.1
              2;1;1;0;0;20.7
              2;0;1;0;1;74.9
              0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:60
              30;1;1;0;1;60
              30;1;1;0;1;60
              30;1;1;0;1;60
              2;1;1;0;0;20.8
              2;1;1;0;0;20.6
              2;0;1;0;1;74.8
              3;0;1;0;1;61.2
              3;0;1;0;1;61.1
              2;1;1;0;0;20.4
              2;0;1;0;1;74.7
              3;0;1;0;1;61.2
              2;1;1;0;0;21.0
              2;0;1;0;1;75.1
              3;0;1;0;1;61.1
              2;1;1;0;0;21.1
              0;255;3;0;9;TSP:MSG:READ 2-2-0 s=0,c=1,t=1,pt=7,l=5,sg=0:75.2
              2;0;1;0;1;75.2
              3;0;1;0;1;61.2
              2;1;1;0;0;20.6
              2;0;1;0;1;74.8
              3;0;1;0;1;61.1
              2;1;1;0;0;20.4
              2;0;1;0;1;74.7
              3;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:40
              4;0;1;0;1;40
              4;0;1;0;1;40
              4;0;1;0;1;40
              4;0;1;0;1;40
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=2,c=1,t=4,pt=7,l=5,sg=0:1020.2
              4;2;1;0;4;1020.2
              4;2;1;0;4;1020.2
              4;2;1;0;4;1020.2
              4;2;1;0;4;1020.2
              4;2;1;0;4;1020.2
              4;2;1;0;4;1020.2
              4;2;1;0;4;1020.2
              2;1;1;0;0;20.7
              2;0;1;0;1;74.9
              3;1;1;0;0;20.5
              2;1;1;0;0;20.9
              2;0;1;0;1;75.1
              2;1;1;0;0;20.7
              2;0;1;0;1;74.9
              2;1;1;0;0;20.9
              2;0;1;0;1;75.1
              2;1;1;0;0;20.6
              2;0;1;0;1;74.8
              2;1;1;0;0;20.8
              2;0;1;0;1;75.0
              2;1;1;0;0;20.5
              2;0;1;0;1;74.8
              2;1;1;0;0;20.7
              2;0;1;0;1;75.0
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=0,c=1,t=1,pt=2,l=2,sg=0:44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.1
              4;1;1;0;0;26.1
              4;1;1;0;0;26.1
              4;1;1;0;0;26.1
              4;1;1;0;0;26.1
              4;1;1;0;0;26.1
              4;1;1;0;0;26.1
              2;1;1;0;0;20.5
              2;0;1;0;1;74.8
              2;1;1;0;0;20.6
              2;1;1;0;0;20.7
              2;0;1;0;1;74.9
              2;1;1;0;0;20.5
              2;0;1;0;1;74.7
              2;1;1;0;0;20.2
              2;0;1;0;1;74.5
              2;1;1;0;0;20.9
              2;0;1;0;1;73.8
              2;1;1;0;0;20.5
              2;0;1;0;1;74.8
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              4;1;1;0;0;26.7
              2;1;1;0;0;20.6
              3;0;1;0;1;61.2
              2;1;1;0;0;20.8
              2;0;1;0;1;74.9
              3;0;1;0;1;61.1
              2;1;1;0;0;20.2
              2;0;1;0;1;74.6
              4;0;1;0;1;40
              4;0;1;0;1;40
              4;0;1;0;1;40
              4;0;1;0;1;40
              4;0;1;0;1;40
              4;0;1;0;1;40
              2;1;1;0;0;20.6
              2;0;1;0;1;74.8
              2;1;1;0;0;20.4
              2;1;1;0;0;20.9
              2;0;1;0;1;75.1
              2;1;1;0;0;20.8
              2;0;1;0;1;75.0
              2;1;1;0;0;20.5
              2;0;1;0;1;74.9
              99;255;0;0;18;2.0.0
              99;255;3;0;6;0
              99;255;3;0;12;1.0
              3;1;1;0;0;20.6
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.3
              3;0;1;0;1;61.3
              2;1;1;0;0;20.4
              2;0;1;0;1;74.8
              3;0;1;0;1;61.2
              2;1;1;0;0;20.6
              2;0;1;0;1;75.0
              3;1;1;0;0;20.5
              0;255;3;0;9;TSP:MSG:READ 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:61.4
              3;0;1;0;1;61.4
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              4;0;1;0;1;44
              3;1;1;0;0;20.6
              3;0;1;0;1;61.2
              0;255;3;0;9;TSP:MSG:READ 4-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
              0;255;3;0;9;TSP:MSG:PINGED (ID=4, hops=2)
              0;255;3;0;9;!TSP:MSG:SEND 0-0-99-4 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=fail:1
              2;1;1;0;0;20.5
              2;0;1;0;1;74.8
              2;1;1;0;0;20.6
              2;0;1;0;1;74.9
              3;1;1;0;0;20.5
              2;0;1;0;1;74.8
              3;0;1;0;1;61.3
              • K Offline
                K Offline
                karl261
                Hm, somehow I have the impression it depends a bit if I have #define MY_DEBUG in my repeater sketch or not. I had to put it back in, because I want to take some logs, and it is behaving a bit better now. At least single messages. And less fails.
                Daniel OliveiraD T 2 Replies Last reply
                • K karl261
                  Daniel OliveiraD Offline
                  Daniel Oliveira
                  Hi @karl261,
                  It's a long shot but can you double check your power sources? I had some weird issues like those in the past because of bad quality power sources.
                  I recommend adding a 47uF electrolytic capacitor as close as possible to the NRF24 GND and VCC pins, as a 470uF between the GND and the Vin pins of the arduino.
                  And keep the external power source on even when connecting the USB cable to read the debug messages.
                  Hope you solve this issue soon
                  MySensors rules my home :)
                  K 1 Reply Last reply
                  • K karl261
                    T Offline
                    T Offline
                    tekka
                    @karl261 Ok, I need to see the sketches first: can you post the sketch of all nodes, i.e. GW, node 99, node 3, node 4? Also, do you have MYSController installed for a few tests?
                    • K Offline
                      K Offline
                      karl261
                      wrote on last edited by karl261
                      Oki doki, thanks for looking at this:
                      Sketch GW:
                       * The ArduinoGateway prints data received from sensors on the serial link.
                       * The gateway accepts input on seral which will be sent out on radio network.
                       * The GW code is designed for Arduino Nano 328p / 16MHz
                       * Wire connections (OPTIONAL):
                       * - Inclusion button should be connected between digital pin 3 and GND
                       * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
                       * LEDs (OPTIONAL):
                       * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                      // Enable serial gateway
                      #define MY_GATEWAY_SERIAL
                      // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                      #if F_CPU == 8000000L
                      #define MY_BAUD_RATE 38400
                      // Flash leds on rx/tx/err
                      #define MY_LEDS_BLINKING_FEATURE
                      // Set blinking period
                      // Enable inclusion mode
                      void presentation() {
                      Sketch 99:
                       * Version 1.0 - Henrik Ekblad
                       * Example sketch showing how to create a node thay repeates messages
                       * from nodes far from gateway back to gateway.
                       * It is important that nodes that has enabled repeater mode calls
                       * process() frequently. Repeaters should never sleep.
                      // Enabled repeater feature for this node
                      #define MY_REPEATER_FEATURE
                      #define MY_NODE_ID 99
                        //Send the sensor node sketch version information to the gateway
                        sendSketchInfo("Repeater Node", "1.0");
                      Sketch 4:
                      /* Sketch with Si7021 and battery monitoring.
                      by m26872, 20151109
                      //#define MY_PARENT_NODE_ID 31
                      #define MY_NODE_ID 4
                      //#define MY_DEBUG
                      #define MY_BAUD_RATE 9600
                      #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                      #include <RunningAverage.h>
                      #include <SparkFunBME280.h>
                      //#define DEBUG   // local debug
                      #ifdef DEBUG
                      #define DEBUG_SERIAL(x) Serial.begin(x)
                      #define DEBUG_PRINT(x) Serial.print(x)
                      #else
                      // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                      #define CHILD_ID_HUM 0
                      #define CHILD_ID_TEMP 1
                      #define CHILD_ID_PRES 2
                       #define SLEEP_TIME 15000 // 15s for DEBUG
                      //#define SLEEP_TIME 300000   // 5 min
                      #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                      #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                      #define VMIN 1900
                      #define VMAX 3300
                      #define HUMI_TRANSMIT_THRESHOLD 3.0  // THRESHOLD tells how much the value should have changed since last time it was transmitted.
                      #define TEMP_TRANSMIT_THRESHOLD 0.5
                      #define PRES_TRANSMIT_THRESHOLD 1.0
                      #define AVERAGES 2
                      int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                      int measureCount = 0;
                      float lastTemperature = -100;
                      float lastPressure = -100;
                      int lastHumidity = -100;
                      RunningAverage raHum(AVERAGES);
                      //SI7021 humiditySensor;
                      BME280 mySensor;
                      // MyMessage to controler
                      MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP); // Initialize temperature message
                      MyMessage msgHum(CHILD_ID_HUM,V_HUM);
                      MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                        sendSketchInfo("OUTSIDE P&T&H", "1.2");
                        present(CHILD_ID_PRES, S_BARO);
                        present(CHILD_ID_HUM, S_HUM);
                        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                        DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                        DEBUG_PRINTLN("Serial started");
                        DEBUG_PRINT("Voltage: ");
                        DEBUG_PRINT(readVcc());
                        DEBUG_PRINTLN(" mV");
                        delay(500);
                        DEBUG_PRINT("Internal temp: ");
                        DEBUG_PRINT(GetInternalTemp()); // Probably not calibrated. Just to print something.
                        DEBUG_PRINTLN(" *C");
                        mySensor.settings.commInterface = I2C_MODE;
                        mySensor.settings.I2CAddress = 0x77;
                        //runMode can be:
                        //  0, Sleep mode
                        //  1 or 2, Forced mode
                        //  3, Normal mode
                        mySensor.settings.runMode = 1;
                        mySensor.settings.filter = 0;
                        mySensor.settings.tempOverSample = 1;
                        mySensor.settings.pressOverSample = 1;
                        mySensor.settings.humidOverSample = 1;
                        delay(500); // Allow time for radio if power used as reset
                        if (!mySensor.begin())
                          Serial.println("BME init failed!");
                          while (1);
                        else Serial.println("BME init success!");
                        raHum.clear();
                        measureCount ++;
                        batteryReportCounter ++;
                        bool forceTransmit = false;
                        if (measureCount > FORCE_TRANSMIT_CYCLE) {
                          forceTransmit = true;
                        mySensor.begin();
                        // Read and print internal temp
                        float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                        DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                        // Check battery
                        if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                          long batteryVolt = readVcc();
                          DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                          uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                          DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                          batteryReportCounter = 0;
                      //  sleep(SLEEP_TIME);
                      if(isTransportOK()){
                          sleep(SLEEP_TIME);  // transport is OK, node can sleep
                        else {
                          wait(5000); // transport is not operational, allow the transport layer to fix this
                      // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                      // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                      long readVcc() {
                        long result = (high<<8) | low;
                        result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                      // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                      double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                        unsigned int wADC;
                        double t;
                        // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                        ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                        ADCSRA |= _BV(ADEN);  // enable the ADC
                        delay(20);            // wait for voltages to become stable.
                        ADCSRA |= _BV(ADSC);  // Start the ADC
                        while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                        wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                        t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                        return (t);   // The returned temperature in degrees Celcius.
                       * * Sends temperature and humidity from Si7021 sensor
                       * Parameters
                       * - force : Forces transmission of a value (even if it's the same as previous measurement)
                      void sendTempHumidityMeasurements(bool force) {
                        bool tx = force;
                        float temperature = mySensor.readTempC();
                        DEBUG_PRINT("T: ");DEBUG_PRINTLN(temperature);
                        float diffTemp = abs(lastTemperature - temperature);
                        DEBUG_PRINT(F("TempDiff :"));DEBUG_PRINTLN(diffTemp);
                        if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                          send(msgTemp.set(temperature,1));
                          lastTemperature = temperature;
                          measureCount = 0;
                          DEBUG_PRINTLN("T sent!");
                        int humidity = mySensor.readFloatHumidity();
                        DEBUG_PRINT("H: ");DEBUG_PRINTLN(humidity);
                        raHum.addValue(humidity);
                        humidity = raHum.getAverage();  // MA sample imply reasonable fast sample frequency
                        float diffHum = abs(lastHumidity - humidity);
                        DEBUG_PRINT(F("HumDiff  :"));DEBUG_PRINTLN(diffHum);
                        if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                          send(msgHum.set(humidity));
                          lastHumidity = humidity;
                          measureCount = 0;
                          DEBUG_PRINTLN("H sent!");
                        float pressure = mySensor.readFloatPressure()/100.0;
                        DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                        float diffPress = abs(lastPressure - pressure);
                        DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                        if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                          send(msgPres.set(pressure,1));
                          lastPressure = pressure;
                          measureCount = 0;
                          DEBUG_PRINTLN("P sent!");
                      Sketch Node 30:
                      by m26872, 20151109
                      //#define MY_DEBUG
                      //#define MY_NODE_ID 30
                      #include <SI7021.h>
                      #define DEBUG
                      #ifdef DEBUG
                      #else
                      #define CHILD_ID_TEMP 0
                      #define CHILD_ID_HUM 1
                      // #define SLEEP_TIME 15000 // 15s for DEBUG
                      #define VMIN 1900
                      #define VMAX 3300
                      #define AVERAGES 2
                      sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
                        present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                        delay(500);
                        delay(500); // Allow time for radio if power useed as reset
                        raHum.clear();
                        measureCount ++;
                        // Check battery
                        sleep(SLEEP_TIME);
                      long readVcc() {
                        unsigned int wADC;
                        double t;
                       * Parameters
                        bool tx = force;
                        si7021_env data = humiditySensor.getHumidityAndTemperature();
                        float temperature = data.celsiusHundredths / 100.0;
                          measureCount = 0;
                        int humidity = data.humidityPercent;
                          measureCount = 0;
                      • Daniel OliveiraD Daniel Oliveira
                        Hi @karl261,
                        K Offline
                        K Offline
                        karl261
                        @Daniel-Oliveira Yeah, I know about these power things. I am pretty sure the power is ok. I use the caps on all my nodes. For the repeater (99) I picked a very stable 5V source and the NRF24+PA+LNA sits behind its own 3.3V regulator that has a high current output. The NRF24+PA+LNA is shielded after @Oitzu's method, so it should not interfere with itself. Actually I tried to implement all the tricks.
                        Btw, all is on 2.0.0.
                        GW: Nano
                        99: Pro mini
                        30 + 4: 1Mhz battery nodes after @m26872's "My Slim 2AA Battery Node".
                        It all sounds too nice to be true... ;-)
                        • T tekka
                          K Offline
                          K Offline
                          karl261
                          @tekka MYSController? No, but if you point me to a link or so I could install of course.
                          Edit: Ok, I downloaded your software. It seems it is running well on my PC. I am ready to test.
                          Edit2: The 1.0.0beta.
                          • K karl261
                            T Offline
                            T Offline
                            tekka
                            wrote on last edited by tekka
                            @karl261 What version is it saying?
                            • T tekka
                              K Offline
                              K Offline
                              karl261
                              @tekka 1.0.0beta built 3314
                              • K karl261
                                T Offline
                                T Offline
                                tekka
                                @karl261 Ok, then send a C_INTERNAL | I_DEBUG | R message to the GW and node 99 and upload the output.
                                • T tekka
                                  K Offline
                                  K Offline
                                  karl261
                                  @tekka So you mean I connect to my serial gateway and then issue the commands? Yes, let's see.
                                  • K Offline
                                    K Offline
                                    karl261
                                    Here we go:
                                    10	22.08.2016 21:49:41	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
                                    12	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0202
                                    14	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                                    16	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0463
                                    18	22.08.2016 21:49:41	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                                    20	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	1F1F
                                    22	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
                                    24	22.08.2016 21:49:42	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	8B03
                                    25	22.08.2016 21:50:06	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
                                    28	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
                                    30	22.08.2016 21:50:06	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0303
                                    32	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
                                    34	22.08.2016 21:50:07	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	1E1E
                                    37	22.08.2016 21:50:23	RX	2	1	C_SET	NO	V_TEMP	20.8
                                    39	22.08.2016 21:50:23	RX	2	0	C_SET	NO	V_HUM	76.1
                                    • K karl261
                                      Here we go:
                                      T Offline
                                      T Offline
                                      tekka
                                      @karl261 Ok, and now send C_INTERNAL | I_DEBUG | E - first to node 99, then to the GW and finally, press Discover in MYSController. This should re-establish the routing table.
                                      • T tekka
                                        K Offline
                                        K Offline
                                        karl261
                                        @tekka I received ok twice back. Now the nano (GW) is blinking like crazy. And so is the pro mini (repeater). I do a power cycle?
                                        • K karl261
                                          T Offline
                                          T Offline
                                          tekka
                                          @karl261 yup
                                          12.1k
