  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.5k Views 1 Watching
  • T tekka
    @karl261 yup
    K Offline
    K Offline
    karl261
    @tekka Still weird:
    99 says 0203 so 02 is going via 03?? Why?
    0 says 0263 so 02 is going via 99?
    247	22.08.2016 22:15:24	TX	99 - Repeater Node	N/A	C_INTERNAL	NO	I_DEBUG	R
    250	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0000
    252	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0203
    254	22.08.2016 22:15:24	RX	99 - Repeater Node	INTERNAL	C_INTERNAL	NO	I_DEBUG	0404
    255	22.08.2016 22:15:50	TX	0 - Gateway	N/A	C_INTERNAL	NO	I_DEBUG	R
    257	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	0263
    259	22.08.2016 22:15:50	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_DEBUG	6363
    T 1 Reply Last reply
    • K karl261
      @tekka Still weird:
      T Offline
      T Offline
      tekka
      @karl261 hmm...indeed, that's weird. Do you have the debug log of node 3?
      K 1 Reply Last reply
      • T tekka
        K Offline
        K Offline
        karl261
        @tekka Which log exactly? Node 3 is Mysensors 1.5... It is sitting somewhere hidden...
        • K karl261
          T Offline
          T Offline
          tekka
          wrote on last edited by tekka
          #24
          @karl261 But you wrote:
          Btw, all is on 2.0.0.
          mixed setups are not advisable (and not supported). Please update if possible.
          • T tekka
            K Offline
            K Offline
            karl261
            @tekka Yes, with "all" I meant those being involved in the repeater stuff.
            • K karl261
              T Offline
              T Offline
              tekka
              @karl261 Can you add this to node 4 (this is the relayed one?):
              #define MY_PARENT_NODE_ID 99
              K 2 Replies Last reply
              • T tekka
                K Offline
                K Offline
                karl261
                wrote on last edited by karl261
                #27
                @tekka I can add it to node 30 right now. It is also supposed to be relayed. In fact this is why I did start this thread in the first place, I had no luck with these two lines. Will try again.
                Oooohhh, there is a mistake further up: I am talking about node 30, and wrote node 3. That is incorrect. Let's see if I can edit. That is why you were asking about the 1.5...
                • T tekka
                  K Offline
                  K Offline
                  karl261
                  #28
                  @tekka Node 30 does still not care about the two lines. It is sending direct.
                  It also does not send back any routing table. Maybe because it is sleeping most of the time?
                  • K karl261
                    T Offline
                    T Offline
                    tekka
                    @karl261 If it's not defined as repeater, it won't have a routing table. And yes, sleeping nodes do not listen for incoming traffic. But still, if GW and node 99 are up, it should prefer 99 - can you show me the log of node 30 during booting?
                    • T tekka
                      K Offline
                      K Offline
                      karl261
                      #30
                      @tekka Now it seems to work.
                      But I recompiled, because I had MY_DEBUG commented out. Somehow there is something wrong with debug...
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=30)
                      TSM:FPAR
                      TSP:MSG:SEND 30-30-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      TSP:MSG:READ 3-3-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      TSP:MSG:FPAR RES (ID=3, dist=1)
                      TSP:MSG:PAR OK (ID=3, dist=2)
                      TSP:MSG:READ 99-99-30 s=255,c=3,t=8,pt=1,l=1,sg=0:1
                      TSP:MSG:FPAR RES (ID=99, dist=1)
                      TSP:MSG:FPAR (PPAR FOUND)
                      TSP:MSG:PAR OK (ID=99, dist=2)
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:CHKID:OK (ID=30)
                      TSM:UPL
                      TSP:PING:SEND (dest=0)
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                      TSP:MSG:READ 0-0-30 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      TSP:MSG:READ 0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0:2
                      TSP:MSG:PONG RECV (hops=2)
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      Serial started
                      Voltage: 3289 mV
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                      TSP:MSG:SEND 30-30-99-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:99
                      TSP:MSG:READ 0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=11,pt=0,l=15,sg=0,ft=0,st=ok:EgTmpHumBat5min
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0,ft=0,st=ok:1.0 151106
                      TSP:MSG:SEND 30-30-99-0 s=0,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                      TSP:MSG:SEND 30-30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                      Node and 2 children presented.
                      Request registration...
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                      TSP:MSG:READ 0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      Node registration=1
                      Init complete, id=30, parent=99, distance=2, registration=1
                      T: 21.59
                      TempDiff :121.59
                      TSP:MSG:SEND 30-30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:21.6
                      T sent!
                      H: 81
                      HumDiff  :181.00
                      TSP:MSG:SEND 30-30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:81
                      H sent!
                      Battery voltage: 3279 mV
                      Battery percent: 98 %
                      TSP:MSG:SEND 30-30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:98
                      T: 21.61
                      TempDiff :0.02
                      H: 81
                      HumDiff  :0.00
                      • K karl261
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:UPL
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        Serial started
                        Voltage: 3289 mV
                        Node registration=1
                        T: 21.59
                        TempDiff :121.59
                        T sent!
                        H: 81
                        HumDiff  :181.00
                        H sent!
                        T: 21.61
                        TempDiff :0.02
                        H: 81
                        HumDiff  :0.00
                        T Offline
                        T Offline
                        tekka
                        You mean, if MY_DEBUG is commented out, the node does not communicate over the repeater (99)?
                        • T tekka
                          K Offline
                          K Offline
                          karl261
                          @tekka Well, yes, I added the two lines you suggested, re-compiled, and then it was not using the 99. And also some posts above, I had these weird messages transmitted 6-7 times, see logs. This happend while MY_DEBUG was commented out.
                          Hm, I can re-upload the sketch and see if this is reproducible.
                          • K karl261
                            T Offline
                            T Offline
                            tekka
                            @karl261 Yes, that would be good - node 30 is running@1Mhz?
                            K 3 Replies Last reply
                            • T tekka
                              K Offline
                              K Offline
                              karl261
                              @tekka Yes, @1 MHz.
                              • T tekka
                                K Offline
                                K Offline
                                karl261
                                @tekka No, it seems to work as expected. Any idea why I am getting this "fail" line?
                                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:READ 30-30-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:BC
                                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:FPAR REQ (sender=30)
                                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:CHKUPL:OK
                                23.08.2016 00:30:33	RX	0;255;3;0;9;TSP:MSG:GWL OK
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-30-30 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 99-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=99, hops=1)
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=24,pt=1,l=1,sg=0:2
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:PINGED (ID=30, hops=2)
                                23.08.2016 00:30:34	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                23.08.2016 00:30:35	RX	0;255;3;0;9;!TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=fail:0100
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=6,pt=1,l=1,sg=0:99
                                23.08.2016 00:30:35	RX	30;255;3;0;6;99
                                23.08.2016 00:30:35	TX	30;255;3;0;6;M
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=6,pt=0,l=1,sg=0,ft=0,st=ok:M
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=12,pt=0,l=10,sg=0:1.0 151106
                                23.08.2016 00:30:35	RX	30;255;3;0;12;1.0 151106
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=0,t=7,pt=0,l=0,sg=0:
                                23.08.2016 00:30:35	RX	30;1;0;0;7;
                                23.08.2016 00:30:35	DEBUG	Update child id=1, type=S_HUM
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:SEND 0-0-99-30 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.3
                                23.08.2016 00:30:35	RX	30;0;1;0;0;24.3
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=1,c=1,t=1,pt=2,l=2,sg=0:73
                                23.08.2016 00:30:35	RX	30;1;1;0;1;73
                                23.08.2016 00:30:35	RX	0;255;3;0;9;TSP:MSG:READ 30-99-0 s=255,c=3,t=0,pt=1,l=1,sg=0:91
                                23.08.2016 00:30:35	RX	30;255;3;0;0;91
                                • K karl261
                                  T Offline
                                  T Offline
                                  tekka
                                  #36
                                  @karl261 Does it fail regularly?
                                  • T tekka
                                    K Offline
                                    K Offline
                                    karl261
                                    #37
                                    @tekka yes, these fails come and go, I see them all the time, but not at the same place necessarily. The logs posted above show plenty of them.
                                    I don't understand this radio trouble.,the distances between the nodes are not long. The radios are all connected using all tricks, the relay is a nrf24+pa+lna which is located in a good location... Maybe all radios are crap? There is only one wifi network and it is not very busy... It's my own. Maybe I should change the channel? 110 or so sounds good. I am using default now. Power is set to max for all nodes, the nrf24+pa+lna is shielded from itself, I put small antenna extensions on the normal ones after @petewill, they all have nice caps, gw and repeater have excellent power sources, ...
                                    I found a script how to test nrf radios... Maybe I should try that?
                                    If I was going to buy new radios, just to try, which ones are the best???
                                    Edit: Hm, I think if I use antennas, it really helps if they all point into the same direction. Like all horizontal or all vertical. Which would make sens, wouldn't it?
                                    • T tekka
                                      K Offline
                                      K Offline
                                      karl261
                                      @tekka But now I found something: the repeater sketch does not work, if MY_DEBUG is commented out. I tried several times forth and back. On the gw I get the output below.
                                      0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                                      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
                                      0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
                                      0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
                                      T K 2 Replies Last reply
                                      • K karl261
                                        T Offline
                                        T Offline
                                        tekka
                                        #39
                                        @karl261 That's weird - I've just tested that scenario and everything is fine here.
                                        Can you add an indicator in loop() to make sure the repeater sketch is running? Also, what board are you using as repeater and how do you power it?
                                        • T tekka
                                          K Offline
                                          K Offline
                                          karl261
                                          @tekka I will try this a bit later, thanks.
                                          Right now I am going crazy, the node is again not using the defined parent. Did I overlook something in the sketch?
                                          TSM:INIT
                                          TSM:RADIO:OK
                                          TSP:ASSIGNID:OK (ID=4)
                                          TSM:FPAR
                                          TSP:MSG:SEND 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                                          TSP:MSG:READ 0-0-4 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          TSP:MSG:PAR OK (ID=0, dist=1)
                                          TSM:FPAR:OK
                                          TSM:ID
                                          TSM:CHKID:OK (ID=4)
                                          TSM:UPL
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                                          TSP:MSG:READ 0-0-4 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          TSP:MSG:PONG RECV (hops=1)
                                          TSP:CHKUPL:OK
                                          TSM:UPL:OK
                                          TSM:READY
                                          BME init success!
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                          TSP:MSG:READ 0-0-4 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=ok:OUTSIDE P&T&H
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.2
                                          TSP:MSG:SEND 4-4-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 4-4-0-0 s=2,c=0,t=8,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 4-4-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                          TSP:MSG:READ 0-0-4 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          Node registration=1
                                          Init complete, id=4, parent=0, distance=1, registration=1
                                          TSP:MSG:SEND 4-4-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=ok:24.7
                                          TSP:MSG:SEND 4-4-0-0 s=0,c=1,t=1,pt=2,l=2,sg=0,ft=0,st=ok:57
                                          TSP:MSG:SEND 4-4-0-0 s=2,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=ok:1012.9
                                          TSP:MSG:SEND 4-4-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,ft=0,st=ok:115
                                          /* Sketch with Si7021 and battery monitoring.
                                          by m26872, 20151109
                                          #define MY_NODE_ID 4
                                          #define MY_BAUD_RATE 9600
                                          #include <Wire.h>  //This library allows you to communicate with I2C / TWI devices.
                                          #include <RunningAverage.h>
                                          #include <SparkFunBME280.h>
                                          //#define DEBUG   // local debug
                                          #ifdef DEBUG
                                          #define DEBUG_SERIAL(x) Serial.begin(x)
                                          #define DEBUG_PRINT(x) Serial.print(x)
                                          #else
                                          // #define NODE_ID 132             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                                          #define CHILD_ID_HUM 0
                                          #define CHILD_ID_TEMP 1
                                          #define CHILD_ID_PRES 2
                                           #define SLEEP_TIME 15000 // 15s for DEBUG
                                          //#define SLEEP_TIME 300000   // 5 min
                                          #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                                          #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                                          #define VMIN 1900
                                          #define VMAX 3300
                                          #define HUMI_TRANSMIT_THRESHOLD 3.0  // THRESHOLD tells how much the value should have changed since last time it was transmitted.
                                          #define TEMP_TRANSMIT_THRESHOLD 0.5
                                          #define PRES_TRANSMIT_THRESHOLD 1.0
                                          #define AVERAGES 2
                                          int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                                          int measureCount = 0;
                                          float lastTemperature = -100;
                                          float lastPressure = -100;
                                          int lastHumidity = -100;
                                          RunningAverage raHum(AVERAGES);
                                          //SI7021 humiditySensor;
                                          BME280 mySensor;
                                          // MyMessage to controler
                                          MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP); // Initialize temperature message
                                          MyMessage msgHum(CHILD_ID_HUM,V_HUM);
                                          MyMessage msgPres(CHILD_ID_PRES,V_PRESSURE);
                                            sendSketchInfo("OUTSIDE P&T&H", "1.2");
                                            present(CHILD_ID_PRES, S_BARO);
                                            present(CHILD_ID_HUM, S_HUM);
                                            DEBUG_PRINT("Node and "); DEBUG_PRINTLN("3 children presented.");
                                            DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                            DEBUG_PRINTLN("Serial started");
                                            DEBUG_PRINT("Voltage: ");
                                            DEBUG_PRINT(readVcc());
                                            DEBUG_PRINTLN(" mV");
                                            delay(500);
                                            DEBUG_PRINT("Internal temp: ");
                                            DEBUG_PRINT(GetInternalTemp()); // Probably not calibrated. Just to print something.
                                            DEBUG_PRINTLN(" *C");
                                            mySensor.settings.commInterface = I2C_MODE;
                                            mySensor.settings.I2CAddress = 0x77;
                                            //runMode can be:
                                            //  0, Sleep mode
                                            //  1 or 2, Forced mode
                                            //  3, Normal mode
                                            mySensor.settings.runMode = 1;
                                            mySensor.settings.filter = 0;
                                            mySensor.settings.tempOverSample = 1;
                                            mySensor.settings.pressOverSample = 1;
                                            mySensor.settings.humidOverSample = 1;
                                            delay(500); // Allow time for radio if power used as reset
                                            if (!mySensor.begin())
                                              Serial.println("BME init failed!");
                                              while (1);
                                            else Serial.println("BME init success!");
                                            raHum.clear();
                                            measureCount ++;
                                            batteryReportCounter ++;
                                            bool forceTransmit = false;
                                            if (measureCount > FORCE_TRANSMIT_CYCLE) {
                                              forceTransmit = true;
                                            mySensor.begin();
                                            // Read and print internal temp
                                            float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                                            DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                                            // Check battery
                                            if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                                              long batteryVolt = readVcc();
                                              DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                                              uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                                              DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                                              batteryReportCounter = 0;
                                            sleep(SLEEP_TIME);
                                          //if(isTransportOK()){
                                          //    sleep(SLEEP_TIME);  // transport is OK, node can sleep
                                          //  else {
                                          //    wait(5000); // transport is not operational, allow the transport layer to fix this
                                          // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                                          // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                                          long readVcc() {
                                            long result = (high<<8) | low;
                                            result = 1134738L / result; // Calculate Vcc (in mV); 1125300 = 1.1*1023*1000
                                          // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                                          double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                                            unsigned int wADC;
                                            double t;
                                            // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                                            ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                                            ADCSRA |= _BV(ADEN);  // enable the ADC
                                            delay(20);            // wait for voltages to become stable.
                                            ADCSRA |= _BV(ADSC);  // Start the ADC
                                            while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                                            wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                                            t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                                            return (t);   // The returned temperature in degrees Celcius.
                                           * * Sends temperature and humidity from Si7021 sensor
                                           * Parameters
                                           * - force : Forces transmission of a value (even if it's the same as previous measurement)
                                          void sendTempHumidityMeasurements(bool force) {
                                            bool tx = force;
                                            float temperature = mySensor.readTempC();
                                            DEBUG_PRINT("T: ");DEBUG_PRINTLN(temperature);
                                            float diffTemp = abs(lastTemperature - temperature);
                                            DEBUG_PRINT(F("TempDiff :"));DEBUG_PRINTLN(diffTemp);
                                            if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                                              send(msgTemp.set(temperature,1));
                                              lastTemperature = temperature;
                                              measureCount = 0;
                                              DEBUG_PRINTLN("T sent!");
                                            int humidity = mySensor.readFloatHumidity();
                                            DEBUG_PRINT("H: ");DEBUG_PRINTLN(humidity);
                                            raHum.addValue(humidity);
                                            humidity = raHum.getAverage();  // MA sample imply reasonable fast sample frequency
                                            float diffHum = abs(lastHumidity - humidity);
                                            DEBUG_PRINT(F("HumDiff  :"));DEBUG_PRINTLN(diffHum);
                                            if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                                              send(msgHum.set(humidity));
                                              lastHumidity = humidity;
                                              measureCount = 0;
                                              DEBUG_PRINTLN("H sent!");
                                            float pressure = mySensor.readFloatPressure()/100.0;
                                            DEBUG_PRINT("P: ");DEBUG_PRINTLN(pressure);
                                            float diffPress = abs(lastPressure - pressure);
                                            DEBUG_PRINT(F("PressDiff :"));DEBUG_PRINTLN(diffPress);
                                            if (diffPress > PRES_TRANSMIT_THRESHOLD || tx) {
                                              send(msgPres.set(pressure,1));
                                              lastPressure = pressure;
                                              measureCount = 0;
                                              DEBUG_PRINTLN("P sent!");
