  3. Best Arduino for a lot of digital outputs?
6 Posts 3 Posters 3.3k Views 1 Watching
  • N
    N
    naveen
    wrote on last edited by naveen
    I'm looking to connect two stepper drivers to the Arduino, each one needs 2 digital pins for step/dir and 3 pins to control microstepping. I'd also like another pin to connect a light sensor to it. Is there a board that can support all these pins (~12) and the radio? Or would it be best to just get two Arduino pro minis and split it up?
    Paul AugustoP 1 Reply Last reply
    • N naveen
      Paul AugustoP
      Paul AugustoP
      Paul Augusto
      @naveen
      You can use the analog pins as digital io. It should get you to 12 on the pro mini:
      http://waihung.net/arduino-tip-turn-your-analog-pins-into-digital-io/
      N 1 Reply Last reply
      • Paul AugustoP Paul Augusto
        @naveen
        N
        N
        naveen
        @Paul-Augusto
        That's a good tip, thanks!
        I guess something like this could also work: http://www.arduino.cc/en/Tutorial/ShiftOut
        • N
          N
          naveen
          @hek
          Do you have any recommendation for this? I don't think the digital+analog inputs will be enough to connect two steppers and a luminosity sensor.
          Do you foresee any issues using the shift register I linked previously?
          hekH 1 Reply Last reply
          • N naveen
            @hek
            @naveen
            AtMega 2560 perhaps?
              @naveen
              N
              N
              naveen
              @hek
              Hmm, yeah that would work. It just seems like overkill for a few extra pins (price and size wise). I didn't realize there were 8 analog pins on the APM, those should actually be enough to drive all the things as long as they work OK as digital outputs.
              I figure the shift register will cause problems because I won't be able to build an 'AccelStepper' object since the input for the constructor is a pin number. I assume I'd have to modify the code if I want to put it through the shift register.
