  3. RFM69 softSPI
RFM69 softSPI
8 Posts 4 Posters 1.8k Views 3 Watching
  • ? Offline
    ? Offline
    A Former User
    How set softSPI for RFM96 and WIZNET (W5100) gateway. Thank you for your answare.
    • ? A Former User
      @zaba_pv welcome to the MySensors community.
      Just follow the instructions in section "To enable soft-spi you just have to" on https://www.mysensors.org/build/ethernet_gateway
      • ? Offline
        ? Offline
        A Former User
        I use version 2.0.
        In releasenotes is writing "All gateway variants available as examples without any need for re-configuration (E.g. SOFT-SPI automatically enabled for W5100)."
        My gateway is running with nrf24l01+ but not working with rfm69
        • ? A Former User
          I use version 2.0.
          @zaba_pv ok. Then I don't know unfortunately. Github is inaccessible so I can't access the documentation/code and I don't use rfm myself. Hopefully someone else can chip in.
          • ? Offline
            ? Offline
            A Former User
            Thank you. I think it is not implemented support for softSPI in RFM69 API.
            T 1 Reply Last reply
            • ? A Former User
              T Offline
              T Offline
              tekka
              @zaba_pv RFM69 is implemented using interrupts which are not supported in softSPI.
              ? 1 Reply Last reply
              • T tekka
                ? Offline
                ? Offline
                A Former User
                wrote on last edited by A Former User
                @tekka exactly gateway with RFM96 and WIZNET (W5100) will never be functional. Yes?
                • T Offline
                  T Offline
                  tbowmo
                  @zaba_pv
                  We are working on a new GW device, that will work with RFM69 and W5100, should be available later this year (waiting for our manufacturing partner)
                  12.1k
