  3. Hooking into Ethernet gateway.
2 Posts 2 Posters 1.3k Views 1 Watching
  • AtomicGrogA
    AtomicGrogA
    AtomicGrog
    End game is some kind of integration with my Fibaro HC2 however as it stands the HC2's capabilities are somewhat limited - I can create a virtual device but being able to use is as a power consumption meter for now is near impossible. Cross fingers that the latter releases open up the API (A lot...).
    So.. in the meantime I want to see if there's a few workarounds, I have a Z-Wave module from a Razberry and the innards from a Z-Wave dimmer module to use as a potential hook into the platform, failing that I'll invest in a universal sensor and use it to trigger events within the HC2 at which point i'll look to poll the sensor values.
    Problem is, I cant fathom how the ethernet connection works. Is there a published API/Protocol? I assumed it was the same as the serial protocol, just over IP.
    Am I on the right track? if not can someone point me in the correct direction.
    Cheers
    Atomic
      wrote on last edited by hek
      Yeah, it's a pity they don't open up their API a bit more. The problem is that it won't allow you to keep an outgoing socket open all the time. Also no way of pragmatically create devices (the last time I looked).
      One solution could be to have the gateway "ping" a HC2 device when a message is available over http-api. The device then open the socket to receive the message from gateway. Hackish .. yeah I know.
      Yes, the protocol is the same over an ethernet socket.
