  3. [Solved] Does not work after latest update
17 Posts 4 Posters 11.2k Views 3 Watching
  • eBesE Offline
    eBesE Offline
    eBes
    wrote on last edited by tekka
    Hey all!
    I just updated to the latest 2.0 release and everything stopped working. I have researched as much as I can on this topic, especially this thread. But nothing has worked for me this far, I've tried for hours and hours and now I feel like I've hit a wall. I tried the development branch too but to no success.
    I have updated my gateway (esp8266 mqtt gateway with a nrf24l01+pa+lna) and one Arduino Nano (with a nrf24l01) having DHT22 and motion sensor, all this is reporting to Home Assistant. It worked perfectly before with 2.0.0b.
    I've tried adjusting the rf24 power to LOW and 1mbps etc, playing with stuff that people have suggested, keeping the gw and node at a bigger distance etc. Now I kind of wish I could find the older 2.0.0b libraries but I can't, but I would appreciate any help that I can with getting this latest version working, sorry if I repeated a similar question but I thought I'd start a new thread since the other ones does not work for me.
    I get this message (which some may recognize from the other posts) which is pretty much the same for release 2.0. and dev branch. Let me know if I should provide some more info.
    Starting sensor (RNNNA-, 2.0.1-beta)
    TSM:INIT
    TSM:INIT:TSP OK
    TSM:INIT:STATID,ID=10
    TSF:ASID:OK,ID=10
    TSM:FPAR
    TSF:MSG:SEND,10-10-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:NO REPLY
    TSM:FPAR
    !TSM:FPAR:FAIL
    TSM:FAILURE
    TSM:FAILURE:PDT
    TSM:FAILURE:RE-INIT
    and this is some output from the esp8266 gw:
    0;255;3;0;9;MQTT connected
    0;255;3;0;9;TSF:MSG:READ,10-10-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSF:MSG:BC
    0;255;3;0;9;TSF:MSG:FPAR REQ,ID=10
    0;255;3;0;9;TSF:CHKUPL:OK,FCTRL
    0;255;3;0;9;TSF:MSG:GWL OK
    0;255;3;0;9;!TSF:MSG:SEND,0-0-10-10,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
    0;255;3;0;9;TSF:MSG:GWL OK```
    T 1 Reply Last reply
    • eBesE eBes
      Hey all!
      TSM:INIT
      TSM:INIT:TSP OK
      TSF:ASID:OK,ID=10
      TSM:FPAR
      !TSM:FPAR:NO REPLY
      TSM:FPAR
      !TSM:FPAR:NO REPLY
      TSM:FPAR
      !TSM:FPAR:NO REPLY
      TSM:FPAR
      !TSM:FPAR:FAIL
      TSM:FAILURE
      TSM:FAILURE:PDT
      TSM:FAILURE:RE-INIT
      T Offline
      T Offline
      tekka
      @Emil-Besirevic Radio link is ok:
      1. node sends find parent request:
      TSM:FPAR
      1. GW answers:
      ..but your node does not receive the find parent response, see last line GW log (NACK) + node log:
      !TSM:FPAR:NO REPLY.
      Please make sure GW and node are running the same code base and double check power/cap/wiring. Also, try changing and re-seating the radios. Additionally, please post the node sketch here.
      • eBesE Offline
        eBesE Offline
        eBes
        wrote on last edited by eBes
        Hi Tekka!
        Thanks for you reply!
        The sketches I used for the testing in the end was the included ones, which is the esp8266 mqtt gateway and then I tried with the motion sensor sketch, both are from the mysensors library examples.
        The wiring, cap etc. are all identical to how it has always been when it was working with the 2.0.0beta, it's all in place and sturdy, what do you mean by changing/re-seating the radios?
        EDIT: Tried with different radio modules, both usual and the one with antenna for the node etc, but still the same :/
        EDIT2: It worked randomly for like 1 minute but stopped working again, with this ouput from the node:
        TSF:MSG:READ,0-0-10,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSF:MSG:FPAR RES,ID=0,D=0
        TSF:MSG:FPAR OK,ID=0,D=1
        TSM:FPAR:OK
        TSM:ID
        TSM:ID:OK,ID=10
        TSM:UPL
        TSF:PING:SEND,TO=0
        !TSF:MSG:SEND,10-10-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=NACK:1
        TSF:CHKUPL:FAIL
        !TSM:UPL:FAIL
        TSM:FPAR```
        • eBesE eBes
          Hi Tekka!
          TSM:FPAR:OK
          TSM:ID
          TSM:ID:OK,ID=10
          TSM:UPL
          TSF:PING:SEND,TO=0
          TSF:CHKUPL:FAIL
          !TSM:UPL:FAIL
          TSM:FPAR```
          T Offline
          T Offline
          tekka
          @Emil-Besirevic hmm...If it works randomly for a few minutes - this could possibly hint to a power issue. What caps did you connect to the radio modules? Try substituting them for larger ones. 2.0.0 is exchanging more messages during initialisation, and this could cause power instabilities under certain conditions.
          • eBesE Offline
            eBesE Offline
            eBes
            Ok, so you truly rock Tekka!
            I just took entirely new modules, soldered 22uf instead of 10uf caps on them both, just plugged everything in, and it WORKS now!
            I've disconnected it a few times, re-connected, tried back and forth and it communicated and sends everything to Home assistant each time flawlessly, even better than before!
            Super happy guy here! A huge thank you for having patience with me! This new release of mysensors is awesome! :)
            T JicJ 2 Replies Last reply
            • eBesE eBes
              T Offline
              T Offline
              tekka
              @Emil-Besirevic Excellent, have fun 😀
              • eBesE eBes
                JicJ Offline
                JicJ Offline
                Jic
                @Emil-Besirevic I have the same problem, I follow the same steps. I have already soldered a 22uF + 100nF, but I still have the problem.
                Is yours still working? Any other idea?
                eBesE 1 Reply Last reply
                • JicJ Jic
                  eBesE Offline
                  eBesE Offline
                  eBes
                  Hi! I have only soldered a 22uF on all, the arduino nano nodes and the esp8266 gate which uses a nrf24l01 antenna version, and it all works great still! Have you tried with different modules?
                  JicJ 1 Reply Last reply
                  • eBesE eBes
                    JicJ Offline
                    JicJ Offline
                    Jic
                    @Emil-Besirevic
                    yes, I have tested:
                    • with diffetents modules of nrf24l01+,
                    • with the NRF24L01+ Socket Adapter Board.
                    • with 10uF+100nF capacitor and 22uF+100nF capacitor
                    • with diferents Arduino nano, and also with an Arduino One
                    And no success, I'm a bit frustrated now. I suppouse that the problem it is with software it's unlikey that all hardware are wrong.
                    I don't know if the problem is in Arduino nano + nrf24l01plus or in the rpi gateway connected to the GPIO.
                    Somebody know how can I test it?
                    • T Offline
                      T Offline
                      Tigroenot
                      wrote on last edited by Tigroenot
                      Hello everybody!
                      This my first post, but I've been reading for a long while and realy admire the team for the work done :)
                      I have moved to development branch, I have latest MySensors on my gateway (Rpi2 + nrf24l01+plna, caps and reg to solve the power issue), burned the MYSBootloader (8MHz internal) and could upload the binary scetch via serial.
                      Now i have that problem with !TSM:FPAR:NO REPLY on the node side.
                      I can see the FPAR request on the gateway side.
                      653051 TSM:INIT
                      653060 TSM:INIT:TSP OK
                      653062 TSM:FPAR
                      653064 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      655073 !TSM:FPAR:NO REPLY
                      655075 TSM:FPAR
                      655077 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      657088 !TSM:FPAR:NO REPLY
                      657090 TSM:FPAR
                      657092 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      659103 !TSM:FPAR:NO REPLY
                      659105 TSM:FPAR
                      659107 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                      661121 !TSM:FPAR:FAIL
                      661123 TSM:FAIL:CNT=7
                      661125 TSM:FAIL:PDT```
                      mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:MSG:FPAR REQ,ID=255
                      mysgw: TSF:PNG:SEND,TO=0
                      mysgw: TSF:CKU:OK
                      mysgw: TSF:MSG:GWL OK
                      mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                      mysgw: Client 0: 0;0;3;0;18;PING
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:CKU:OK,FCTRL
                      mysgw: TSF:MSG:BC
                      mysgw: TSF:MSG:BC
                      Though there is no sign of activity in MYSController (the one included with the MYSBootloader archive)
                      I have tried differen radio modules, different pro minis, modules not jumper wired but soldered with short wires and caps (10, 20, 47 uF). The other 3 nodes are responding (2 x si7021 + motion sensor) but they are on 1.5 version I suppose.
                      EDIT: The interestinf thing is that I tried to update my perfectly working motion sensor and it doesn't work now.
                      TSM:FPAR
                      TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE```
                      • T Tigroenot
                        Hello everybody!
                        653051 TSM:INIT
                        653062 TSM:FPAR
                        655075 TSM:FPAR
                        657090 TSM:FPAR
                        659105 TSM:FPAR
                        mysgw: TSF:MSG:BC
                        mysgw: TSF:CKU:OK
                        mysgw: TSF:MSG:BC
                        mysgw: TSF:MSG:BC
                        mysgw: TSF:MSG:BC
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE```
                        JicJ Offline
                        JicJ Offline
                        Jic
                        @Tigroenot I have the same errors until I soldered the nrf24l01 module.
                        Power supply and wired it is very important with this module. I think a have a lot of problems with jumper wires.
                        Be also sure that you are using the last binding
                        https://github.com/tobof/openhab2-addons/blob/MySensors/addons/binding/org.openhab.binding.mysensors/target/org.openhab.binding.mysensors-2.0.0-SNAPSHOT.jar
                        • JicJ Jic
                          T Offline
                          T Offline
                          Tigroenot
                          @Jic I have all Nrf24 modules soldered, with caps (tried 20 and 47 uF), I have three versions of Nrf24 modules: from the mysensors shop, smd and plna. On the gateway I have plna, on sensors I have both the others. Those sensors worked fine for almost a year, and stoped after I have updated them to 2.0.0 or development branch. On the gateway side I have latest development version.
                          Maybe all my radio modules are clones that do not work with the versions of mysensors higher than 1.4?
                          And I use domoticz. Maybe I should switch to openhub?
                          • eBesE Offline
                            eBesE Offline
                            eBes
                            I just upgraded all my nodes + gateway to latest dev branch (2.10) and it's working great with home assistant, they communicate without issues. As mentioned earlier my setup is nrf24l01 (with antenna mod) for all nodes (arduino nano) and then the gateway (esp8266) is with a nrf24l01+plna, and they all have a 22uF cap, it's been like 6+ months and it's been working great this far. I ordered all the nrf24l01 from aliexpress.
                            • T Offline
                              T Offline
                              Tigroenot
                              I will try to move my gateway from raspberry to esp. When I compiled gateway on raspberry it has argued on some parameter in config, I removed the cortex a7 entry and all went fine. Maybe it was the issue.
                              • T Tigroenot
                                JicJ Offline
                                JicJ Offline
                                Jic
                                @Tigroenot Have you Clean the Eprom before update to mysensors 2.0?
                                https://github.com/mysensors/MySensors/blob/master/examples/ClearEepromConfig/ClearEepromConfig.ino
                                Sometimes it solve me somes issues
                                • JicJ Jic
                                  T Offline
                                  T Offline
                                  Tigroenot
                                  @Jic I sure did, to erase the node id value.
                                  • T Offline
                                    T Offline
                                    Tigroenot
                                    Reporting: I have thrown away the capacitors that I've bought from Ali and replaced them by those bougth here localy (47uF) and everything worked like a charm! So to admit, the promblem IS indeed in the decoupling capacitors! Very happy guy here! :)
                                    12.1k
