  3. GatewayW5100 - unable to get working w/ v2.0.0
10 Posts 7 Posters 6.1k Views 10 Watching
  • joe.kJ
    joe.kJ
    joe.k
    wrote on last edited by joe.k
    Everything has been working rock solid with v1.5 on VeraPlus U17. However, I am not having success with v2.0.0 and not sure what else to check or what I might be missing. I've been using MySensors successfully since 2013 and typically able to troubleshoot problems on my own, but could use some help.
    The GW is wired to use the Soft SPI and have double checked my wiring against the documentation, but then again it all works fine with v1.5.
    Below is the serial output for the W5100 ethernet GW in server mode. The Arduino Uno is restarting continually. Nothing shows in the the log file on the Vera (LuaUPnP.log).
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.x.x
    IP: 192.168.x.x
        .... just repeats
    When configuring the W5100 ethernet GW in client mode I am able to get output in the serial console, but still nothing at the VeraPlus or in the LuaUPnP.log file. Sensor 6 is running v2.0.0 as well.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, x, x
    IP: 192.168.x.x
    0;255;3;0;9;TSP:MSG:READ 6-6-0 s=1,c=1,t=0,pt=7,l=5,sg=0:80.2
    0;255;3;0;9;TSP:SANCHK:OK
    Any help or suggestions are greatly appreciated.
    Regards,
    Joe
    • joe.kJ
      joe.kJ
      joe.k
      Turns out there's something in Arduino IDE v1.6.10 that's causing the problem I was experiencing. The GW is working after compiling and uploading the sketch with Arduino IDE v1.6.7.
      The problem is repeatable w/ Arduino IDE 1.6.10.
      Joe
      • Mark SwiftM
        Mark SwiftM
        Mark Swift
        I've also just experienced this... Rolling back to 1.6.7 now to test.
          A Former User
          Had the same issue with both 1.6.9 and 1.6.10.
          1.6.8 works ok for me.
          • Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            I'm running 1.6.9 and it works for me
            MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
            • Arturas AA
              Arturas AA
              Arturas A
              The problem is repeatable w/ Arduino IDE 1.6.12.
              Works fine with 1.6.5
              Does anybody could explain why server mode gateway restarting with newer Arduino IDE? Client mode is not recognized by Domoticz.
              • Michiel van der WulpM
                This issue is not solved - nobody gave any other solution than try with an older version..
                I still have this problem with Arduino IDE 1.6.7 as well with 1.6.12.
                Reverting to an older IDE is not a solution, merely a temporary work-around.
                Is there a library problem?
                YveauxY joe.kJ 2 Replies Last reply
                • Michiel van der WulpM Michiel van der Wulp
                  YveauxY
                  YveauxY
                  @Michiel-van-der-Wulp You are correct this is a workaround, not a real solution.
                  However, the issue introduced in 1.6.12 is caused by an update of the compiler included with the Arduino environment, and thus outside the reach of MySensors.
                  We reported the bug, it has been fixed, but not yet included in the Arduino release.
                  Until this fix is included, all known reboot-related issues were resolved by reverting the Arduino board package (ref: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/3)
                  If this does not solve your particular case, something else is wrong that sould be looked into.
                    joe.kJ
                    joe.kJ
                    joe.k
                    Agreed - updated the subject by removing the "solved"
                      Thanks, I got it working with the downgrade described in https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time/9
