  3. Over the air
Over the air
13 Posts 5 Posters 3.6k Views 3 Watching
  • CrankyCoderC Offline
    CrankyCoder
    Has anyone worked on the over the air updates for mqtt client gateway? I love the idea of over the air updating but I use the mqtt client gateway.
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • hekH Offline
      hekH Offline
      Not sure anyone has tried over MQTT, but it should work if the controller allows/supports it.
        CrankyCoder
        Is there a list of supported controllers? I am using openhab for mine. But since it's just interfacing via mqtt not sure how that would work.
        Is there an additional tool like the https://www.mysensors.org/controller/myscontroller that works with the mqtt integration?
        www.CrankyCoder.net
        MySensors: 2.3
        • hekH Offline
          hekH Offline
          MQTT, not that I know of..
          AFAIK normal OTA updates is only supported by myscontroller and MyController.
            CrankyCoder
            Hmm. is it possible to have a serial+mqttclient gateway? and that way i can have a method to update ota while still utilizing the mqtt integration?
            www.CrankyCoder.net
            MySensors: 2.3
            • hekH Offline
              hekH Offline
              No, not covering the same sensor network. I know that people have done some pretty advanced setups using NodeRed, but I'm afraid I can't help you with that.
              • E Offline
                E Offline
                ericvdb
                @Jason-Brunk i believe MyController supports OTA over MQTT
                  CrankyCoder
                  That could work. Since it's mqtt I don't think it would interfere with openhab. So I could use openhab as my primary controller and mycontroller to manage/update.
                  Im going to have to check that out. Thanks!!
                  www.CrankyCoder.net
                  MySensors: 2.3
                    CrankyCoder
                    Is there a "getting started with OTA" doc somewhere? For like what bootloader I need ect?
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • mfalkviddM Offline
                      https://forum.mysensors.org/topic/1914/over-the-air-ota-bootloading-update-tutorial/9 Is the best I've seen so far I think.
                      CrankyCoderC 1 Reply Last reply
                        CrankyCoder
                        @mfalkvidd looks like that thread got off topic a bit :)
                        guess i need to get some mem chips and just kind of start playing with it. The mqtt thing I think is going to be the tough part since I haven't seen any reference docs on how it breaks up the binaries to send out over the RF. I have 0 starting point to try to get it working with the mqtt client gateway I am running. But we will see.
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • S Offline
                          wrote on last edited by scalz
                          @Jason-Brunk you can get some infos here https://forum.mysensors.org/topic/3503/sensebender-dualoptiboot-ota-howto-in-mysensors
                          • S scalz
                            CrankyCoder
                            @scalz oh sweet. More info :) Very cool. Did anyone find a good location for the memory chips? I am not opposed to ali but amazon prime would be better :)
                            www.CrankyCoder.net
                            MySensors: 2.3
