  3. Resend if communication fail
4 Posts 3 Posters 1.9k Views 6 Watching
  • Felix HaverkampF
    Felix HaverkampF
    Felix Haverkamp
    Re: resend if st=fail
    implemented that on 1.5.0 and worked like a charm.
    How can i implement that resend logic to a gateway in Version 2.0.0?
    There is no parseAndSend() function and i didnt see any function to get the ACK from sensore node.
    How is this done in 2.0.0?
    I have light switches with rf433 and movement sensors. That setup wont work if the communication isnt reliable.
    Any suggestions?
    • Felix HaverkampF
      Felix HaverkampF
      Felix Haverkamp
      nobody know how to implement a safe communication with resend logic to 2.0.0 ?
      are you rely on a system with a "maybe" communication? really?
      • G
        G
        gloob
        wrote on last edited by gloob
        I would also be interessed in a solution for a resend if the communication fails.
        Currently I use this feature for all my sensors.
        Is it possible to use the following
        if (send(uvMsg.set(uvIndex,2)) == false)
             // resend
          Yes, but only if there is one hop between your node and the gateway. If you have a repeater in between, you'll have to ask for ack and do resent if the ack-message hasn't arrived after some timeout.
