  3. Battery powering
Battery powering
27 Posts 6 Posters 9.0k Views 4 Watching
  • CrankyCoderC CrankyCoder
    @Yveaux VCC. Yeah i pulled the regulator off
    YveauxY
    YveauxY
    @Jason-Brunk Does it run stable without the nRF? E.g. disconnect nRF and simply print something to serial.
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      tried to do the BOD fuse update. bricked a pro mini. grabbed another one. it took the updated boot loader.
      if i disconnect the radio it just loops
      TSM:PDT
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      as you would expect.
      If i hook the radio up i get this.
      TSM:INIT
      TSM:RADIO:OK
      TSP:Á
      I do still need to remove the regulator and led on this one. Not sure if that's the issue. I have also tried a brand new cr2032 battery
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        So here is my latest. I modified the arduino pro mini. Changed the BOD fuse value and reburned the bootloader. I wired it all back up. Got it to register. I got 6 button presses where it sent the data. Now I am right back where it was.
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=1)
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:Starting sensor (RNNNA-, 2.0.0)
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASS▒Starting sensor (RNNNA-, 2.0.0)
        TSM:INIT
        TSM:RADIO:OK
        I am just not having much luck getting this to work via battery. I have a 100u capacitor on the radio.
        If anyone has any thoughts I am all ears. I kind of at a loss now. I am using the 2.0.0 release.
        www.CrankyCoder.net
        MySensors: 2.3
        • CrankyCoderC
          CrankyCoderC
          CrankyCoder
          More testing update:
          I tried 2 AA batteries. Which would be the same voltage, just more mah. 0 Issues. Using the battery monitor with the AA batteries it shows the voltage at about 2.84v
          When I hook a brand new cr2032 up though, I press the button and it shows voltage is already down to 2.48v. I have the BOD disabled (I believe) per the instructions to modify the boards.txt and reburn the bootloader.
          The batteries I have are energizer cr2032. I would think they are ok, but they could all be junk. I have tried 4 so far.
          www.CrankyCoder.net
          MySensors: 2.3
          m26872M 1 Reply Last reply
            m26872M
            m26872M
            m26872
            @Jason-Brunk I would try to put in a delay of the radio startup in the sketch. Maybe there's to much or fast simultaneous power consuption initially with respect to the coincell.
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              Another quick update, seems to be making progress.
              I decided to try to flash a 1mhz boot loader onto my pro mini. Then reuploaded my switch sketch. So far it's looking good. Button presses are registering as expected. 2 things I have seen.
              1. i think i need to read up some more on changing clock speed. My sleep command should wake up and report battery level once an hour. This did not happen at all through the night.
              2. now that I am running at 1mhz when i tried to connect via serial for debugging using the default baudrate it was junk. I forced the baud rate to nice and slow, and it looked like that was going to do it. but no go.
              www.CrankyCoder.net
              MySensors: 2.3
              • Nca78N
                Nca78N
                Hello I gave you some tips for button cell on your other thread.
                In addition: if you are using interrupts only then your power consumption should be extremely low, I don't think it's necessary to wake up regularly to send battery level.
                If you don't do it then then you have even lower consumption because the watchdog timer is turned off, my CR2032 door/windows nodes using the sleep method from MySensors draws less than 2uA, there can be no visible change in battery level except if you leave your node in a closet for one year ;)
