  3. Battery powering
Battery powering
27 Posts 6 Posters 8.5k Views 4 Watching
  • CrankyCoderC CrankyCoder
    yeah, this one works if i give it a 3.3v power source. But i can try my other one.
    F Offline
    F Offline
    flopp
    • CrankyCoderC Offline
      CrankyCoder
      Im using a 3.3v pro mini.
      From what I gathered BOD level only affected the power down. Would it affect the power up and radio initialization?
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      Y 1 Reply Last reply
        F Offline
        F Offline
        flopp
        Do you mean NRF?
        NRF should work down to 1,9 volt
        CrankyCoderC 1 Reply Last reply
        • F flopp
          Do you mean NRF?
          CrankyCoder
          @flopp That is correct, everything registers ok and debug shows the connections when i give it 3.3v from my usb power supply
          www.CrankyCoder.net
          MySensors: 2.3
          F 1 Reply Last reply
            F Offline
            F Offline
            flopp
            Then it can be bad battery.
            Measure battery, should be about 3.1.
            Connect something to the battery, like an LED, battery shall now show maybe 2.9, not lower. If it shows lower I guess the battery is almost empty.
              Y Offline
              Y Offline
              How are you pwering it? Through RAW or VCC? Did you remove/disable the regulator?
              • Y Yveaux
                CrankyCoder
                @Yveaux VCC. Yeah i pulled the regulator off
                www.CrankyCoder.net
                MySensors: 2.3
                  Y Offline
                  Y Offline
                  @Jason-Brunk Does it run stable without the nRF? E.g. disconnect nRF and simply print something to serial.
                    CrankyCoder
                    tried to do the BOD fuse update. bricked a pro mini. grabbed another one. it took the updated boot loader.
                    if i disconnect the radio it just loops
                    TSM:PDT
                    TSM:INIT
                    !TSM:RADIO:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    !TSM:RADIO:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    TSM:INIT
                    !TSM:RADIO:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    as you would expect.
                    If i hook the radio up i get this.
                    TSM:INIT
                    TSM:RADIO:OK
                    TSP:Á
                    I do still need to remove the regulator and led on this one. Not sure if that's the issue. I have also tried a brand new cr2032 battery
                    www.CrankyCoder.net
                    MySensors: 2.3
                      CrankyCoder
                      So here is my latest. I modified the arduino pro mini. Changed the BOD fuse value and reburned the bootloader. I wired it all back up. Got it to register. I got 6 button presses where it sent the data. Now I am right back where it was.
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=1)
                      TSM:FPAR
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:Starting sensor (RNNNA-, 2.0.0)
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASS▒Starting sensor (RNNNA-, 2.0.0)
                      TSM:INIT
                      TSM:RADIO:OK
                      I am just not having much luck getting this to work via battery. I have a 100u capacitor on the radio.
                      If anyone has any thoughts I am all ears. I kind of at a loss now. I am using the 2.0.0 release.
                      www.CrankyCoder.net
                      MySensors: 2.3
                        CrankyCoder
                        More testing update:
                        I tried 2 AA batteries. Which would be the same voltage, just more mah. 0 Issues. Using the battery monitor with the AA batteries it shows the voltage at about 2.84v
                        When I hook a brand new cr2032 up though, I press the button and it shows voltage is already down to 2.48v. I have the BOD disabled (I believe) per the instructions to modify the boards.txt and reburn the bootloader.
                        The batteries I have are energizer cr2032. I would think they are ok, but they could all be junk. I have tried 4 so far.
                        www.CrankyCoder.net
                        MySensors: 2.3
                          M Offline
                          M Offline
                          m26872
                          @Jason-Brunk I would try to put in a delay of the radio startup in the sketch. Maybe there's to much or fast simultaneous power consuption initially with respect to the coincell.
                            CrankyCoder
                            Another quick update, seems to be making progress.
                            I decided to try to flash a 1mhz boot loader onto my pro mini. Then reuploaded my switch sketch. So far it's looking good. Button presses are registering as expected. 2 things I have seen.
                            1. i think i need to read up some more on changing clock speed. My sleep command should wake up and report battery level once an hour. This did not happen at all through the night.
                            2. now that I am running at 1mhz when i tried to connect via serial for debugging using the default baudrate it was junk. I forced the baud rate to nice and slow, and it looked like that was going to do it. but no go.
                            www.CrankyCoder.net
                            MySensors: 2.3
                            • N Offline
                              N Offline
                              Hello I gave you some tips for button cell on your other thread.
                              In addition: if you are using interrupts only then your power consumption should be extremely low, I don't think it's necessary to wake up regularly to send battery level.
                              If you don't do it then then you have even lower consumption because the watchdog timer is turned off, my CR2032 door/windows nodes using the sleep method from MySensors draws less than 2uA, there can be no visible change in battery level except if you leave your node in a closet for one year ;)
