  3. Battery powering
Battery powering
27 Posts 6 Posters 9.0k Views 4 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    Happy Friday guys! Fighting with another node and hoping someone may have some thoughts. I have followed the battery powered guide.
    My little sensor does not want to run on 3v. Anyone have any luck running 2.0 on a 3v battery?
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    mfalkviddM F 2 Replies Last reply
    • CrankyCoderC CrankyCoder
      @Jason-Brunk running MySensors 2 on battery shouldn't be a problem. What happens on the sensors? What does the debug output say?
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        I am wondering if maybe the capacitor on my radio is too big while running off the coin cell.
        Here is what i am getting currently
        TSM:INIT
        TSM:RADIO:OK
        TSP:ASSIGNID:OK (ID=1)
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        TSM:INIT
        TSM:RADIO:OK
        TSM:FPAR
        www.CrankyCoder.net
        MySensors: 2.3
        YveauxY 1 Reply Last reply
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          TSM:INIT
          TSM:RADIO:OK
          TSM:FPAR
          YveauxY
          YveauxY
          @Jason-Brunk what arduino ide are you using? 1.6.10 seems to have issues in combination with MySensors.
          CrankyCoderC 1 Reply Last reply
            F
            F
            flopp
            wrote on last edited by flopp
            @Jason-Brunk
            I don't use 2.0, yet, but I have a lot 1.5.1 running on battery without problem.
            Try to run your node with power from e.g. FTDI or other source, then you can see if it works and also if it sleeps.
            What I notice for some of my nodes is that it needs a new battery to work, when my CR2032 battery comes down to ~2,5 volt it stop working maybe because of the mA is to low from battery to power up NRF or ATmega.
            • YveauxY Yveaux
              CrankyCoderC
              CrankyCoderC
              CrankyCoder
              @Yveaux I am using 1.6.9
              www.CrankyCoder.net
              MySensors: 2.3
              • F flopp
                @Jason-Brunk
                CrankyCoderC
                CrankyCoderC
                CrankyCoder
                @flopp Just put a fresh battery in. Checked it before hand, 3.07v
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                TSM:INIT
                TSM:RADIO:OK
                TSM:FPAR
                What capacitor size are you using on the radio? any use to put a cap on the main power/gnd between the battery and the rest of the circuit?
                www.CrankyCoder.net
                MySensors: 2.3
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  F
                  F
                  flopp
                  @Jason-Brunk
                  I am using 4,7 uF SMD mounted on the NRF.
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    F
                    F
                    flopp
                    @Jason-Brunk
                    You can try with a cap on main pwr/gnd.
                    Maybe you can measure the voltage on main pwr/gnd and see what happens when it starts?
                    • F flopp
                      @Jason-Brunk
                      CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      @flopp i changed batteries and made sure i don't go below 2.6v and still the furthest i get is
                      TSP▒Starting sensor (RNNNA-, 2.0.0)
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:INIT
                      TSM:RADIO:OK
                      Looks like it is locking up as soon as the radio is initialized.
                      www.CrankyCoder.net
                      MySensors: 2.3
                      F 1 Reply Last reply
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:INIT
                        TSM:RADIO:OK
                        F
                        F
                        flopp
                        @Jason-Brunk
                        Do you have an other NRF, if you have try with that
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          yeah, this one works if i give it a 3.3v power source. But i can try my other one.
                          www.CrankyCoder.net
                          MySensors: 2.3
                          YveauxY F 3 Replies Last reply
                            YveauxY
                            YveauxY
                            @Jason-Brunk Do you know/did you change the brown-out level of your atmega? See BODLEVEL at e.g. http://cryoarchive.net/tutorials/avr-tutorials/avr-fuses-explained/
                            What Arduino hardware are we talking about?
                              F
                              F
                              flopp
                              This post is deleted!
                              • CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                Im using a 3.3v pro mini.
                                From what I gathered BOD level only affected the power down. Would it affect the power up and radio initialization?
                                www.CrankyCoder.net
                                MySensors: 2.3
                                  F
                                  F
                                  flopp
                                  Do you mean NRF?
                                  NRF should work down to 1,9 volt
                                  • F flopp
                                    Do you mean NRF?
                                    CrankyCoderC
                                    CrankyCoderC
                                    CrankyCoder
                                    @flopp That is correct, everything registers ok and debug shows the connections when i give it 3.3v from my usb power supply
                                    www.CrankyCoder.net
                                    MySensors: 2.3
                                      F
                                      F
                                      flopp
                                      Then it can be bad battery.
                                      Measure battery, should be about 3.1.
                                      Connect something to the battery, like an LED, battery shall now show maybe 2.9, not lower. If it shows lower I guess the battery is almost empty.
                                        YveauxY
                                        YveauxY
                                        How are you pwering it? Through RAW or VCC? Did you remove/disable the regulator?
                                        • YveauxY Yveaux
                                          CrankyCoderC
                                          CrankyCoderC
                                          CrankyCoder
                                          @Yveaux VCC. Yeah i pulled the regulator off
                                          www.CrankyCoder.net
                                          MySensors: 2.3
