  3. Problem building MQTT Gateway ver 2.0
8 Posts 4 Posters 3.8k Views 4 Watching
  • S Offline
    siod
    wrote on last edited by siod
    I would like to update my actual MQTT Gateway to the new MySensors 2.0 version library. Unfortunately I wasn´t able to just upload the sketch to another arduino, first it was asking for "DigitalIO.h" which I copied from an older arduino IDE version on my computer to the latest arduino IDE library. But after that it asks for "MySigningNone.h". Don´t know where to find that.
    Why can´t it finally be just a simple task to upload code using an updated library?
    T:\Programme\Arduino 1.6.10\arduino-builder -dump-prefs -logger=machine -hardware "T:\Programme\Arduino 1.6.10\hardware" -tools "T:\Programme\Arduino 1.6.10\tools-builder" -tools "T:\Programme\Arduino 1.6.10\hardware\tools\avr" -built-in-libraries "T:\Programme\Arduino 1.6.10\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10610 -build-path "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.0\MQTTClientGateway_Ver_2.0.ino"
    T:\Programme\Arduino 1.6.10\arduino-builder -compile -logger=machine -hardware "T:\Programme\Arduino 1.6.10\hardware" -tools "T:\Programme\Arduino 1.6.10\tools-builder" -tools "T:\Programme\Arduino 1.6.10\hardware\tools\avr" -built-in-libraries "T:\Programme\Arduino 1.6.10\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10610 -build-path "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.0\MQTTClientGateway_Ver_2.0.ino"
    Using board 'uno' from platform in folder: T:\Programme\Arduino 1.6.10\hardware\arduino\avr
    Using core 'arduino' from platform in folder: T:\Programme\Arduino 1.6.10\hardware\arduino\avr
    Detecting libraries used...
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\sketch\MQTTClientGateway_Ver_2.0.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\DigitalIO" "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\sketch\MQTTClientGateway_Ver_2.0.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\DigitalIO" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\sketch\MQTTClientGateway_Ver_2.0.ino.cpp" -o "nul"
    "T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "-IT:\Programme\Arduino 1.6.10\libraries\DigitalIO" "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\sketch\MQTTClientGateway_Ver_2.0.ino.cpp" -o "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
    T:\Arduino Projekte\MQTTClientGateway_Ver_2.0\MQTTClientGateway_Ver_2.0.ino:80:27: fatal error: MySigningNone.h: No such file or directory
     #include <MySigningNone.h>
    compilation terminated.
    Bibliothek DigitalIO im Ordner: T:\Programme\Arduino 1.6.10\libraries\DigitalIO (legacy) wird verwendet
    Bibliothek SPI in Version 1.0 im Ordner: T:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI  wird verwendet
    exit status 1
    Fehler beim Kompilieren für das Board Arduino/Genuino Uno.```
    still learning...
    Y 1 Reply Last reply
    • S siod
      exit status 1
      Y Offline
      Y Offline
      @siod There must be something wrong with your installation, as DigitalIO.h is included in the MySensors 2.0.0 release (https://github.com/mysensors/MySensors/tree/development/drivers/AVR/DigitalIO).
      Better remove the digitalio library you installed manually and clear any remaining MySensors directories left in the 'libraries' folder.
      Furthermore the Arduino 1.6.10 release currently faces some stability issues in combination with MySensors, so I would advise you to stick with 1.6.9, until the issue is solved.
      • S Offline
        siod
        Hi Yveaux, thanks for your quick reply. So, I installed Arduino IDE 1.6.9, downloaded Mysensors library 2.0 again and copied it into the libraries folder. Still getting this error:
        T:\Programme\arduino-1.6.9\arduino-builder -dump-prefs -logger=machine -hardware "T:\Programme\arduino-1.6.9\hardware" -tools "T:\Programme\arduino-1.6.9\tools-builder" -tools "T:\Programme\arduino-1.6.9\hardware\tools\avr" -built-in-libraries "T:\Programme\arduino-1.6.9\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10609 -build-path "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.0\MQTTClientGateway_Ver_2.0.ino"
        T:\Programme\arduino-1.6.9\arduino-builder -compile -logger=machine -hardware "T:\Programme\arduino-1.6.9\hardware" -tools "T:\Programme\arduino-1.6.9\tools-builder" -tools "T:\Programme\arduino-1.6.9\hardware\tools\avr" -built-in-libraries "T:\Programme\arduino-1.6.9\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10609 -build-path "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.0\MQTTClientGateway_Ver_2.0.ino"
        "T:\Programme\arduino-1.6.9\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\arduino-1.6.9\hardware\arduino\avr\cores\arduino" "-IT:\Programme\arduino-1.6.9\hardware\arduino\avr\variants\standard" "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\sketch\MQTTClientGateway_Ver_2.0.ino.cpp" -o "nul"
        "T:\Programme\arduino-1.6.9\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10609 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\arduino-1.6.9\hardware\arduino\avr\cores\arduino" "-IT:\Programme\arduino-1.6.9\hardware\arduino\avr\variants\standard" "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\sketch\MQTTClientGateway_Ver_2.0.ino.cpp" -o "C:\Users\Cito\AppData\Local\Temp\build3eff58a7a75746fb3d7ac5b9b27eba4c.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
        T:\Arduino Projekte\MQTTClientGateway_Ver_2.0\MQTTClientGateway_Ver_2.0.ino:77:23: fatal error: DigitalIO.h: No such file or directory
         #include <DigitalIO.h>
        exit status 1
        still learning...
        • hekH Offline
          hekH Offline
          Where did you download the mqtt-gateway ino from? Is it this one:
          https://github.com/mysensors/MySensors/blob/development/examples/GatewayW5100MQTTClient/GatewayW5100MQTTClient.ino
          • S Offline
            siod
            No Sir, I´ve downloaded it from here: https://www.mysensors.org/build/mqtt_gateway
            still learning...
            • S Offline
              siod
              Ok, I could upload your posted code, seems to work, but MQTT messages don´t have the same format as before. Why was this changed (e.g. #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
              #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in")? I don´t want to edit all my controllers code...
              But I must admit I did not update my sensors yet, but if I cannot easily change the MQTT message format I´ll stick with the older MySensors library.
              still learning...
              • S Offline
                siod
                Ok, was experimenting a bit, I guess I have to change my Openhab code...
                So this is what I had until now:
                Contact FensterSzR  "Fenster Rechts"  (FF_Sz)  {mqtt="<[mysensor:MyMQTT/1/2/V_TRIPPED:state:OPEN:1],<[mysensor:MyMQTT/1/2/V_TRIPPED:state:CLOSED:0]"}
                Now, with library ver 2.0, I think I have to change it to sth. like this, but it doesn´t work, yet. I hope you can help me here:
                Contact FensterKzR  "Fenster Rechts"  (FF_Kz)  {mqtt="<[mysensors-1:mygateway1-out/3/2/V_TRIPPED:state:OPEN:1],<[mysensors-1:mygateway1-out/3/2/V_TRIPPED:state:CLOSED:0]"}
                edit: oops, now with correct code snippet
                edit 2: I recieve this in my serial monitor and mosquitto also receives the messages:
                0;255;3;0;9;TSP:MSG:READ 3-3-0 s=2,c=1,t=16,pt=2,l=2,sg=0:0
                0;255;3;0;9;Sending message on topic: mygateway1-out/3/2/1/0/16
                0;255;3;0;9;TSP:MSG:READ 3-3-0 s=4,c=1,t=0,pt=7,l=5,sg=0:21.2
                0;255;3;0;9;Sending message on topic: mygateway1-out/3/4/1/0/0
                0;255;3;0;9;TSP:MSG:READ 3-3-0 s=3,c=1,t=1,pt=7,l=5,sg=0:62.5
                0;255;3;0;9;Sending message on topic: mygateway1-out/3/3/1/0/1
                still learning...
                • Q Offline
                  Q Offline
                  Qu3Uk
                  Can't tell if you fixed this yet but your Contact Item is incorrect. You've stated the topic in the MQTT part as "mygateway1-out/3/2/V_TRIPPED" when it should actually be "mygateway1-out/3/2/1/0/16"
