  3. Vera
  4. MySensors Communication Error
4 Posts 2 Posters 2.0k Views 2 Watching
  • yoramY
    yoramY
    yoram
    wrote on last edited by yoram
    VeraPlus UI7 version: 1.7.2044
    MySensors Gateway: ESP8266 - NodeMCU 0.9
    Library 2.0
    For some reason the Vera is unable to communicate with the gateway
    1. I can see proper information when connected to the gateway via MYSController, no radio problem
    2. I can ping the gateway IP address from my laptop
    3. I can connect to the gateway via telnet to IPADDRESS:5003
    When I logged in to the VeraPlus console
    1. I cannot ping the gateway IP, there is no reply.
    2. I can ping from the gateway to other devices in my network
    3. The MAC address of the gateway is resolved in the controller (arp -a)
    Vera is reporting
    MySensors plugin : Cannot send command - communications error
    Any idea?
    YveauxY 1 Reply Last reply
    • yoramY yoram
      Library 2.0
      Vera is reporting
      Any idea?
      YveauxY
      YveauxY
      @yoram Enable #define MY_DEBUG in the gateway sketch and upload gateway again.
      Connect NodeMCU to a PC and report back serial data output by the gateway.
      • yoramY
        yoramY
        yoram
        I see no problem on this side, I even rebooted one node and it can be seeing
        2016-08-08 20:12:15	Message	0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0)
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:RADIO:OK
        0;255;3;0;9;TSM:GW MODE
        0;255;3;0;9;TSM:READY
        0;255;3;0;9;-^^--
        0;255;3;0;9;Yoram:
        0;255;3;0;9;Static IP:
        10.100.102.111
        scandone
        f 0, scandone
        state: 0 -> 2 (b
        2016-08-08 20:12:15	Message	0)
        state: 2 -> 3 (0)
        state: 3 -> 5 (10)
        add 0
        aid 1
        cnt
        connected with ShechoriHome, channel 11
        ip:10.100.102.111,mask:255.255.255.0,gw:10.100.102.1
        2016-08-08 20:12:15	Message	.IP: 10.100.102.111
        0;255;3;0;9;No regis
        2016-08-08 20:12:15	Message	tration required
        2016-08-08 20:12:25	Message	pm open,type:2 0
        2016-08-08 20:12:45	Message	0;255;3;0;9;TSP:MSG:READ 20-20-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
        0;255;3;0;9;TSP:MSG:BC
        0;255;3;0;9;TSP:MSG:FPAR REQ (sender=20)
        0;255;3;0;9;TSP:CHKUPL:OK
        0;255;3;0;9;TSP:MSG:GWL OK
        2016-08-08 20:12:46	Message	0;255;3;0;9;TSP:MSG:SEND 0-0-20-20 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=ok:0
        0;255;3;0;9;TSP:MSG:READ 1-1-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
        0;255;3;0;9;TSP:MSG:PINGED (ID=1, hops=1)
        0;255;3;0;9;TSP:MSG:SEND 0-0-1-1 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
        2016-08-08 20:12:48	Message	0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=24,pt=1,l=1,sg=0:1
        0;255;3;0;9;TSP:MSG:PINGED (ID=20, hops=1)
        0;255;3;0;9;TSP:MSG:SEND 0-0-20-20 s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=ok:1
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
        0;255;3;0;9;TSP:MSG:SEND 0-0-20-20 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        2016-08-08 20:12:50	Message	0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=11,pt=0,l=19,sg=0:Water Leakage w Bat
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=0,c=0,t=32,pt=0,l=0,sg=0:
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=1,c=0,t=23,pt=0,l=0,sg=0:
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=26,pt=1,l=1,sg=0:2
        0;255;3;0;9;TSP:MSG:SEND 0-0-20-20 s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=ok:1
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=1,c=1,t=38,pt=7,l=5,sg=0:3.178
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=255,c=3,t=0,pt=1,l=1,sg=0:100
        0;255;3;0;9;TSP:MSG:READ 20-20-0 s=0,c=2,t=15,pt=0,l=0,sg=0:
        • yoramY yoram
          0;255;3;0;9;-^^--
          0;255;3;0;9;Yoram:
          10.100.102.111
          scandone
          f 0, scandone
          state: 0 -> 2 (b
          state: 2 -> 3 (0)
          state: 3 -> 5 (10)
          add 0
          aid 1
          cnt
          YveauxY
          YveauxY
          @yoram apart from all the "2016-08-08 20:12:50 Message" texts (does your terminal program add them?) output looks OK.
          I don't have a Vera, so can't help you any further...
