  3. MyNodes.NET
  4. [SOLVED] Wifi Serialgateway error
Scheduled Pinned Locked Moved MyNodes.NET
7 Posts 3 Posters 2.5k Views 3 Watching
  • WodianW Offline
    WodianW Offline
    Wodian
    I've been busy to setup Mynodes for a while now. After some dissapointments with the serial gateway (Not beeing supported until fix from mono) I tryed the wifi gateway. Installed the firmware correctly and connected to my wifi AP still it doesnt connects from the controller perspective.
    This is what the terminal says:
    11-8-2016 22:47:27: GATEWAY: Failed to connect to 192.168.0.37:5003. Remote host is not responding.
    Any thoughts?
    Kind Regards,
    Wodian van der Zee
    • K Offline
      K Offline
      korttoma
      Is the controller and the GW in the same IP range (in the same subnetwork)?
      Can you ping your GW?
      What does your GWs serial output say if you add the following in the beginning of your sketch:
      #define MY_DEBUG // Enables debug messages in the serial log
      • Tomas
      • WodianW Offline
        WodianW Offline
        Wodian
        Thank you for the quick respons. Will do this when im back home.
        • WodianW Offline
          WodianW Offline
          Wodian
          Found the reason:
          0;0;3;0;9;radio init fail
          Constantly rebooting.
          Any thoughts on how to fix this?
          • WodianW Offline
            WodianW Offline
            Wodian
            wrote on last edited by Wodian
            Update..
            Got my radio working now but now I have this:
            Terminal:
            12-8-2016 18:28:26: GATEWAY: Trying to connect...
            12-8-2016 18:28:26: GATEWAY: Connected to 192.168.0.37:5003
            12-8-2016 18:28:26: GATEWAY: Trying to communicate...
            12-8-2016 18:28:31: GATEWAY: Gateway is not responding.
            12-8-2016 18:28:36: GATEWAY: Gateway is not responding.
            Serial monitor:
            Client 0 connected
            Client 0: 0;0;3;0;2;
            Exception (28):
            epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
            ctx: cont
            sp: 3ffef8b0 end: 3ffefb50 offset: 01a0
            Any Thoughts?
            Y 1 Reply Last reply
            • WodianW Wodian
              Update..
              Terminal:
              Serial monitor:
              Client 0 connected
              Exception (28):
              ctx: cont
              Any Thoughts?
              Y Offline
              Y Offline
              @Wodian I assume you're using an esp, correct?
              Make sure you run mysensors 2.0.0 and the latest esp core.
              • WodianW Offline
                WodianW Offline
                Wodian
                @Yveaux That did the trick!
                The current download @ MyNodes.NET version is outdated!
                Thank you all for support and help!
                12.2k
