  3. Misterhouse
  4. New MyS module available
Scheduled Pinned Locked Moved Misterhouse
7 Posts 3 Posters 3.4k Views 3 Watching
  • jsiddallJ
    jsiddallJ
    jsiddall
    The new MyS module for Misterhouse (MySensors.pm) has now been merged to the Master branch. Please test and post and questions or comments.
    What it does:
    Serial and Ethernet gateways
    Door/window, motion, binary/light, temperature and humidity sensors
    Assigns node ID requests (untested)
    What it doesn't do:
    Almost everything else!
      @jsiddall
      Could you provide me with some information about Misterhouse (featuers, screenshots) so I can add an article to the main site under the controllers section?
      • jsiddallJ
        jsiddallJ
        jsiddall
        @hek Sure, here's some info. Let me know if you need more detail or something specific
        Misterhouse is one of the longest running home automation platforms around. Started in 1998 it supports a wide range of hardware, protocols and capabilities. It is written in perl which means it is easy to run on a wide range of platforms, to see what is happening and also to make customizations. The flip side of this flexibility is that some perl scripting is required but fortunately there are many examples and a helpful group of people on mailing lists.
        The project is currently hosted on github:
        https://github.com/hollie/misterhouse/wiki
        A search of the wiki will also show what support exists for various protocols and hardware.
        For screenshots of the web interface see:
        https://sourceforge.net/projects/misterhouse/
        Ex: https://a.fsdn.com/con/app/proj/misterhouse/screenshots/MH_ia7.png
        There are articles such as this one from linux magazine:
        http://www.linux-magazine.com/Issues/2015/178/MisterHouse
        and even a book by the same author.
          wrote on last edited by hek
          Thanks,
          Added the page. Let me know if you want to change anything.
          Do you have a larger logo?
          • jsiddallJ
            jsiddallJ
            jsiddall
            @hek
            Here's a larger one that I pulled from my own deployment
            If you need a bigger one I will need to contact the icon designer. Let me know.
            • wallyllamaW
              wallyllamaW
              wallyllama
              I cant seem to find this module in the Misterhouse master at githib, pebkac?
              jsiddallJ 1 Reply Last reply
              • wallyllamaW wallyllama
                jsiddallJ
                jsiddallJ
                jsiddall
                @wallyllama have a look here:
                https://github.com/hollie/misterhouse/blob/master/lib/MySensors.pm
                The default branch is stable but you won't find it there [yet].
