  3. Can someone confirm UDP gateway is working in 2.0.0?
3 Posts 2 Posters 1.2k Views 3 Watching
  • rb3rgR
    rb3rgR
    rb3rg
    I'm trying to compile an Ethernet gateway with support for UDP (MY_USE_UDP) however I can't get it compiled.. I've tried with Arduino IDE 1.6.10 and also in PlatformIO
    This library <WiFiUdp.h>, where do I grab it from? Use the one from the ESP8266Wifi arduino core?
    Without UDP both Arduino and platformIO get it compiled successful, but it I enable the MY_USE_UDP will fail in:
    (MyGatewayTransportEthernet.cpp:46:25: error: 'WiFiClient' does not name a type
      #define EthernetClient WiFiClient
    Does anyone have success using UDP in 2.0.0 ?
    Thanks.
    • rb3rgR
      rb3rgR
      rb3rg
      Yes, I can confirm its working..
      in the GatewayESP8266 make sure to change from this:
      #if defined(MY_USE_UDP)
        #include <WiFiUdp.h>
      #else
        #include <ESP8266WiFi.h>
      to
      You have to have both libraries instead of just one (wiFiUdp.h)
      For case sensitive systems (Linux, OS X) also you have to have the correct upper/lower case in the library name.. it must be:
      and NOT:
      #include <WiFiUDP.h>
      as in the the example mysensors file.
      hekH 1 Reply Last reply
      • rb3rgR rb3rg
        #else
        to
        and NOT:
        @rb3rg
        Could you create a pull request with the relevant changes?
