  3. Where does MySensor store in EEPROM
14 Posts 4 Posters 6.9k Views 4 Watching
  • djdehaanD
    djdehaanD
    djdehaan
    Hi, I start using MySensor. I red that MySensor also stores data in EEPROM, to have it available after the device has rebooted (like the state of a relais). What address locations does it need/use? This is relevant, because I use EEPROM in my Sketch as well.
    Regards, DJ
    • djdehaanD djdehaan
      Regards, DJ
      @djdehaan see https://www.mysensors.org/download/sensor_api_20#saving-state for information on how to store things in eeprom without interfering with MySensors. The library will handle the addressing to so you don't need to bother with the details.
      If you do want to bother with the details, look at https://github.com/mysensors/MySensors/blob/986389b12591917ecbc44021c63a2cdf6f8c8222/core/MyEepromAddresses.h
      AWIA 1 Reply Last reply
      • djdehaanD
        djdehaanD
        djdehaan
        Thanks! That is what I was looking for!
          AWIA
          AWIA
          AWI
          @mfalkvidd Question..looking at the details... EEPROM_LOCAL_CONFIG_ADDRESS currently (2.0.0) has a value of 0x19D which makes decimal 413. The atmega only having 512 bytes of EEPROM leaves only around 100 bytes for saveState (i.s.o the mentioned 256).. or am I offtrack here?
          • AWIA AWI
            @AWI could you clarify where 256 is mentioned?
            Edit: Found it, on https://www.mysensors.org/download/sensor_api_20#saving-state
            Yes, you are correct. "You have 256 bytes to play with" can not be true for an AtMega328. I've started a discussion for that page, https://forum.mysensors.org/topic/4832/mysensors-library-v2-0-x/
              A Former User
              Hi I'm making a pH sensor with Sparkeys widgets miniPH board. This one stores parameter in eeprom using:
              #include <avr/eeprom.h>
              #define Write_Check      0x1234
              and writes to eeprom like this:
              params.WriteCheck = Write_Check;
              params.pH7Cal = 2048; //assume ideal probe and amp conditions 1/2 of 4096
              params.pH4Cal = 1286; //using ideal probe slope we end up this many
              params.pHStep = 59.16;//ideal probe slope
              eeprom_write_block(&params, (void *)0, sizeof(params)); //write these settings back to eeprom
              The parametertes stored are thees:
              struct parameters_T
                unsigned int WriteCheck;
                int pH7Cal, pH4Cal;
                float pHStep;
              params;
              I think this interferes with mysensosrs eeprom usage.
              The whole code of the schetch is here https://github.com/SparkysWidgets/MinipHBFW/blob/master/MinipH.ino
              I dont understand what this is referng to:
              Pleas help me
              Goran
              • ? A Former User
                struct parameters_T
                  int pH7Cal, pH4Cal;
                  float pHStep;
                params;
                Pleas help me
                Goran
                AWIA
                AWIA
                AWI
                @goranrad The Write_Check constant is meant to check if there is a valid number written in EEPROM. As the sketch writes from EEPROM adress "0x00" there is good chance that it interferes with MySensors as it uses the same start point
                #define EEPROM_START (0u) (defined in MyEepromAddresses.h)
                I would advice to rewrite the code to use the MySensors saveState(..) and loadState(..)
                ? 1 Reply Last reply
                • AWIA AWI
                  A Former User
                  wrote on last edited by [[global:former-user]]
                  @AWI
                  Thank you AWI!
                  I would have to rewrite it like this
                  write to eeprom would be like this:
                  saveState(_WriteCheck, Write_Check);
                  saveState(_pH7Cal, 2048);
                  saveState(_pH4Cal, 1286);
                  saveState(_pHStep, 59.16);
                  read from eeprom would be like this:
                  params.WriteCheck = loadState(_WriteCheck);
                  params.pH7Cal = loadState(_pH7Cal);
                  params.pH4Cal = loadState(_pH4Cal);
                  params.pHStep = loadState(_pHStep);
                  do you think this would work?
                  Then change the WriteState to a int constant with a value of 1234.
                  Don't know if saveState(..) can store a float or do i have to define it somehow?
                  Best regard
                  Goran
                  • ? A Former User
                    @AWI
                    Thank you AWI!
                    Best regard
                    Goran
                    @goranrad saveState can only save a 1 byte value so you won't be able to save integers or floats directly.
                    You'll need to do something like this, but use saveState instead of EEPROM.write.
                      A Former User
                      @mfalkvidd
                      Hi mfalkvidd,
                      This code takes care of writing to eeprom
                      My problem is that mysensors need to handle read and write to eeprom so it dosent conflict with mysensors read and write to eeprom.
                      Any thoughts on solving this ?
                      Best regards
                      Goran
                      • ? A Former User
                        @mfalkvidd
                        Hi mfalkvidd,
                        Best regards
                        Goran
                        @goranrad Yes. My suggestion is in my previous post.
                          A Former User
                          @mfalkvidd I dont understand how http://www.alexenglish.info/2014/05/saving-floats-longs-ints-eeprom-arduino-using-unions/ would make mysensors to take care of the eeprom?
                          Sorry i'm not seasoned programmer.
                          /goran
                          • ? A Former User
                            /goran
                            @goranrad it does if you use saveState instead of EEPROM.write
                              A Former User
                              thank you!
