  3. Conversion to mysensors 2.0 for BMP180
8 Posts 4 Posters 4.3k Views 4 Watching
  • denis91D
    denis91D
    denis91
    Since yesteday, I has trying to convert a script for a BMP180 mysensors but I have a error.
    The old script in mysensors 1.5 is
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    #include <Wire.h>
    #include <Adafruit_BMP085.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
    	STABLE = 0,			// "Stable Weather Pattern"
    	SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
    	CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
    	UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
    	THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
    	UNKNOWN = 5			// "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage tempMsg(TEMP_CHILD, V_TEMP);
    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    	gw.begin();
    	gw.sendSketchInfo("Pressure Sensor", "1.1");
    	if (!bmp.begin())
    		Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    		while (1) {}
    	// Register sensors to gw (they will be created as child devices)
    	gw.present(BARO_CHILD, S_BARO);
    	gw.present(TEMP_CHILD, S_TEMP);
    	float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
    	float temperature = bmp.readTemperature();
    	if (!metric)
    		// Convert to fahrenheit
    		temperature = temperature * 9.0 / 5.0 + 32.0;
    	int forecast = sample(pressure);
    	Serial.print("Temperature = ");
    	Serial.print(temperature);
    	Serial.println(metric ? " *C" : " *F");
    	Serial.print("Pressure = ");
    	Serial.print(pressure);
    	Serial.println(" hPa");
    	Serial.print("Forecast = ");
    	Serial.println(weather[forecast]);
    	if (temperature != lastTemp)
    		gw.send(tempMsg.set(temperature, 1));
    		lastTemp = temperature;
    	if (pressure != lastPressure)
    		gw.send(pressureMsg.set(pressure, 0));
    		lastPressure = pressure;
    	if (forecast != lastForecast)
    		gw.send(forecastMsg.set(weather[forecast]));
    		lastForecast = forecast;
    	gw.sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
    	float lastPressureSamplesAverage = 0;
    	for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
    		lastPressureSamplesAverage += lastPressureSamples[i];
    	lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
    	return lastPressureSamplesAverage;
    // Algorithm found here
    // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
    	// Calculate the average of the last n minutes.
    	int index = minuteCount % LAST_SAMPLES_COUNT;
    	lastPressureSamples[index] = pressure;
    	minuteCount++;
    	if (minuteCount > 185)
    		minuteCount = 6;
    	if (minuteCount == 5)
    		pressureAvg = getLastPressureSamplesAverage();
    	else if (minuteCount == 35)
    		float lastPressureAvg = getLastPressureSamplesAverage();
    		float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
    		if (firstRound) // first time initial 3 hour
    			dP_dt = change * 2; // note this is for t = 0.5hour
    		else
    			dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
    	else if (minuteCount == 65)
    		if (firstRound) //first time initial 3 hour
    			dP_dt = change; //note this is for t = 1 hour
    		else
    			dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
    	else if (minuteCount == 95)
    			dP_dt = change / 1.5; // note this is for t = 1.5 hour
    		else
    			dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
    	else if (minuteCount == 125)
    		pressureAvg2 = lastPressureAvg; // store for later use.
    			dP_dt = change / 2; // note this is for t = 2 hour
    		else
    			dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
    	else if (minuteCount == 155)
    			dP_dt = change / 2.5; // note this is for t = 2.5 hour
    		else
    			dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
    	else if (minuteCount == 185)
    			dP_dt = change / 3; // note this is for t = 3 hour
    		else
    			dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
    		pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    		firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
    	int forecast = UNKNOWN;
    	if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
    		forecast = UNKNOWN;
    	else if (dP_dt < (-0.25))
    		forecast = THUNDERSTORM;
    	else if (dP_dt > 0.25)
    		forecast = UNSTABLE;
    	else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
    		forecast = CLOUDY;
    	else if ((dP_dt > 0.05) && (dP_dt < 0.25))
    		forecast = SUNNY;
    	else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
    		forecast = STABLE;
    	else
    		forecast = UNKNOWN;
    	// uncomment when debugging
    	//Serial.print(F("Forecast at minute "));
    	//Serial.print(minuteCount);
    	//Serial.print(F(" dP/dt = "));
    	//Serial.print(dP_dt);
    	//Serial.print(F("kPa/h --> "));
    	//Serial.println(weather[forecast]);
    	return forecast;
    and my script proposed in mysensors 2.0
    #include <MyConfig.h>
    #include <Wire.h>
    enum FORECAST
    float pressureAvg;
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    //	gw.begin();
    	if (!bmp.begin())
    		while (1) {}
    	metric = getConfig().isMetric;
    	if (!metric)
    	sleep(SLEEP_TIME);
    	minuteCount++;
    		minuteCount = 6;
    		else
    		else
    		else
    		else
    		else
    		else
    		forecast = UNKNOWN;
    		forecast = CLOUDY;
    		forecast = SUNNY;
    		forecast = STABLE;
    	else
    		forecast = UNKNOWN;
    	return forecast;
    When I tried to compile, Arduino said :
    Arduino : 1.6.11 (Windows 10), Carte : "Arduino Nano, ATmega328"
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino: In function 'void loop()':
    PressureSensorVDM2:112: error: 'sample' was not declared in this scope
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorvDM.ino: At global scope:
    PressureSensorvDM:46: error: redefinition of 'const float ALTITUDE'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:39:13: note: 'const float ALTITUDE' previously defined here
    PressureSensorvDM:49: error: redefinition of 'const long unsigned int SLEEP_TIME'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:42:21: note: 'const long unsigned int SLEEP_TIME' previously defined here
    PressureSensorvDM:51: error: redefinition of 'const char* weather []'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:44:13: note: 'const char* weather [6]' previously defined here
    PressureSensorvDM:52: error: multiple definition of 'enum FORECAST'
    PressureSensorVDM2:45: error: previous definition here
    PressureSensorvDM:62: error: redefinition of 'Adafruit_BMP085 bmp'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:55:17: note: 'Adafruit_BMP085 bmp' previously declared here
    PressureSensorvDM:65: error: redefinition of 'float lastPressure'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:57:7: note: 'float lastPressure' previously defined here
    PressureSensorvDM:66: error: redefinition of 'float lastTemp'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:58:7: note: 'float lastTemp' previously defined here
    PressureSensorvDM:67: error: redefinition of 'int lastForecast'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:59:5: note: 'int lastForecast' previously defined here
    PressureSensorvDM:69: error: redefinition of 'const int LAST_SAMPLES_COUNT'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:61:11: note: 'const int LAST_SAMPLES_COUNT' previously defined here
    PressureSensorvDM:70: error: redefinition of 'float lastPressureSamples [5]'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:62:7: note: 'float lastPressureSamples [5]' previously declared here
    PressureSensorvDM:77: error: redefinition of 'int minuteCount'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:68:5: note: 'int minuteCount' previously defined here
    PressureSensorvDM:78: error: redefinition of 'bool firstRound'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:69:6: note: 'bool firstRound' previously defined here
    PressureSensorvDM:80: error: redefinition of 'float pressureAvg'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:71:7: note: 'float pressureAvg' previously declared here
    PressureSensorvDM:82: error: redefinition of 'float pressureAvg2'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:73:7: note: 'float pressureAvg2' previously declared here
    PressureSensorvDM:84: error: redefinition of 'float dP_dt'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:75:7: note: 'float dP_dt' previously declared here
    PressureSensorvDM:85: error: redefinition of 'boolean metric'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:76:9: note: 'boolean metric' previously declared here
    PressureSensorvDM:86: error: redefinition of 'MyMessage tempMsg'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:77:11: note: 'MyMessage tempMsg' previously declared here
    PressureSensorvDM:87: error: redefinition of 'MyMessage pressureMsg'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:78:11: note: 'MyMessage pressureMsg' previously declared here
    PressureSensorvDM:88: error: redefinition of 'MyMessage forecastMsg'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:79:11: note: 'MyMessage forecastMsg' previously declared here
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorvDM.ino: In function 'void presentation()':
    PressureSensorvDM:91: error: redefinition of 'void presentation()'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:82:6: note: 'void presentation()' previously defined here
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorvDM.ino: In function 'void loop()':
    PressureSensorvDM:109: error: redefinition of 'void loop()'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:101:6: note: 'void loop()' previously defined here
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorvDM.ino: In function 'float getLastPressureSamplesAverage()':
    PressureSensorvDM:154: error: redefinition of 'float getLastPressureSamplesAverage()'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:145:7: note: 'float getLastPressureSamplesAverage()' previously defined here
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorvDM.ino: In function 'int sample(float)':
    PressureSensorvDM:171: error: redefinition of 'int sample(float)'
    C:\Users\Frédérique\Downloads\PressureSensorVDM2\PressureSensorVDM2.ino:162:5: note: 'int sample(float)' previously defined here
    Utilisation de la bibliothèque MySensors-master version 2.0.0 dans le dossier: C:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master
    Utilisation de la bibliothèque SPI version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    Utilisation de la bibliothèque Wire version 1.0 dans le dossier: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
    Utilisation de la bibliothèque Adafruit_BMP085_Library version 1.0.0 dans le dossier: C:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library
    exit status 1
    Could you help me ?
    Many thanks for your help.
    Best regards.
    Denis
      The example has already been converted:
      https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/PressureSensor/PressureSensor.ino
      • denis91D
        denis91D
        denis91
        Good Morning,
        Many thank for your help but this morning I tried your sketch proposed and I have the same problem :
        C:\Users\Frédérique\Downloads\PressureSensor\PressureSensorV2.ino\PressureSensorV2.ino.ino: In function 'void loop()':
        PressureSensorV2.ino:118: error: 'sample' was not declared in this scope
        The complet return of compilation :
        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Frédérique\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10611 -build-path C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Frédérique\Downloads\PressureSensor\PressureSensorV2.ino\PressureSensorV2.ino.ino
        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Frédérique\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -ide-version=10611 -build-path C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Frédérique\Downloads\PressureSensor\PressureSensorV2.ino\PressureSensorV2.ino.ino
        Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
        Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
        Detecting libraries used...
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c" -o "nul"
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library\Adafruit_BMP085.cpp" -o "nul"
        Generating function prototypes...
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
        "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
        Compilation du croquis...
        "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10611 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\MySensors-master" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire\src" "-IC:\Users\Frédérique\Documents\Arduino\libraries\Adafruit_BMP085_Library" "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp" -o "C:\Users\FRDRIQ~1\AppData\Local\Temp\build273ceb3b965055d440d88958ec10e5e6.tmp\sketch\PressureSensorV2.ino.ino.cpp.o"
        exit status 1
        Could you help me ?
        Best regards.
        Denis
        • denis91D denis91
          Good Morning,
          exit status 1
          Could you help me ?
          Best regards.
          Denis
          @denis91 the sample function is declared at https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/PressureSensor/PressureSensor.ino#L168
          Could you post the full sketch? My guess is that something got damaged between downloading from github and compiling in the Arduino ide.
          • denis91D
            denis91D
            denis91
            Good Morning,
            The sketch :
            #include <Wire.h>
            enum FORECAST
            float pressureAvg;
            float pressureAvg2;
            float dP_dt;
            bool metric;
              if (!bmp.begin())
                while (1) {}
            void presentation()  {
              if (!metric)
              sleep(SLEEP_TIME);
              minuteCount++;
                minuteCount = 6;
                else
                else
                else
                else
                else
                else
                forecast = UNKNOWN;
                forecast = CLOUDY;
                forecast = SUNNY;
                forecast = STABLE;
              else
                forecast = UNKNOWN;
              return forecast;
            Best regards.
            Denis
            • denis91D denis91
              Good Morning,
              The sketch :
              #include <Wire.h>
              enum FORECAST
              float pressureAvg;
              float pressureAvg2;
              float dP_dt;
              bool metric;
                if (!bmp.begin())
                  while (1) {}
                if (!metric)
                sleep(SLEEP_TIME);
                minuteCount++;
                  minuteCount = 6;
                  else
                  else
                  else
                  else
                  else
                  else
                  forecast = UNKNOWN;
                  forecast = CLOUDY;
                  forecast = SUNNY;
                  forecast = STABLE;
                else
                  forecast = UNKNOWN;
                return forecast;
              Best regards.
              Denis
              @denis91 the sketch compiles fine for me:
              Using library SPI at version 1.0 in folder: E:\ArduinoIDE\hardware\arduino\avr\libraries\SPI
              Using library MySensors at version 2.0.0 in folder: C:\Users\Mikael\Documents\Arduino\libraries\MySensors
              Using library Wire at version 1.0 in folder: E:\ArduinoIDE\hardware\arduino\avr\libraries\Wire
              Using library Adafruit_BMP085 in folder: C:\Users\Mikael\Documents\Arduino\libraries\Adafruit_BMP085 (legacy)
              Sketch uses 22,330 bytes (72%) of program storage space. Maximum is 30,720 bytes.
              Global variables use 955 bytes (46%) of dynamic memory, leaving 1,093 bytes for local variables. Maximum is 2,048 bytes.
              So the problem seems to be with your installation of the Arduino IDE. Reinstalling the IDE might be the easiest option.
              • denis91D
                denis91D
                denis91
                OK. I left my home during this weekend but I will try monday and then I will communicate you the result :-)
                Have a nice weekend.
                Denis
                • tlpeterT
                  tlpeterT
                  tlpeter
                  I just installed my own type of weather station with a BMP180 and the 2.0 sketch works fine.
                  I think you are doing something wrong :smile:
