  3. DHT and LDR separately working, but together not, what's wrong?
18 Posts 4 Posters 6.1k Views 3 Watching
  • DannyMD
    DannyMD
    DannyM
    Hi all,
    I have a simple sketch for humidity and temperature reading and I want to add a LDR for light level readings. But, separately the sketches for the humidity and temp is working. when putting it together only the LightReading is working.
    What's wrong? hardware is the same for both sketches.
    Thanks, Danny
    Hum/Temp code:
     * Version 1.0 - Henrik EKblad
     * This sketch provides an example how to implement a humidity/temperature
     * sensor using DHT11/DHT-22
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
      gw.begin();
      gw.sendSketchInfo("Humidity", "1.0");
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(SLEEP_TIME); //sleep a bit
    Code: HUM/TMP/LDR:
    #include <DHT.h>
    #define CHILD_ID_LIGHT 2
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    #define LIGHT_SENSOR_ANALOG_PIN A1
    DHT dht;
    float lastTemp;
    float lastHum;
    int lastLightLevel;
    MyMessage msgLight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
     gw.begin();
     dht.setup(LIGHT_SENSOR_ANALOG_PIN);
     gw.sendSketchInfo("HumidityAndLight", "1.0");
     gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
       if (!metric) {
         lastHum = humidity;
     int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
     Serial.print("L: ");
     Serial.println(lightLevel);
         gw.send(msgLight.set(lightLevel));
         lastLightLevel = lightLevel;
    TheoLT 1 Reply Last reply
    • DannyMD DannyM
      Hi all,
      Thanks, Danny
      Hum/Temp code:
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
        gw.begin();
          if (!metric) {
            lastHum = humidity;
      Code: HUM/TMP/LDR:
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
      int lastLightLevel;
       gw.begin();
         if (!metric) {
           lastHum = humidity;
      TheoLT
      TheoLT
      TheoL
      Hello @DannyM,
      Could you be a bit more specific. Like what's the serial ouput what does work and what doesn't work. A bit hard for us to help you without those details
      • DannyMD
        DannyMD
        DannyM
        Okay,
        I understand, here they are:
        TempHum only:
        send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=fail:1.5
        send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
        sensor started, id=1, parent=0, distance=1
        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=fail:Humidity
        send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.0
        send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=fail:
        send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=fail:
        find parent
        send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
        send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:24.0
        T: 24.00
        send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=fail:38.0
        H: 38.00
        With LDR added:
        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=fail:HumidityAndLight
        find parent
        send: 1-1-0-0 s=2,c=0,t=16,pt=0,l=0,sg=0,st=fail:
        send: 1-1-0-0 s=2,c=1,t=23,pt=2,l=2,sg=0,st=fail:62
        L: 62
        • sundberg84S
          @DannyM st=fail indicate you have some range or power issues with your radio. A wild guess since the sensors dont work together is power issues with your node. Try adding wait(50); between readings and when radio transmits so it has the chance to "recharge" before sending again. Also check your capacitor on your radio.
          • DannyMD
            DannyMD
            DannyM
            Hi @sundberg84 I made a higher delay before of the reading of the lightLevel, [delay(1000);] But that didn't change any of the outcome.
            What about the capacitator? do I have to use another one?
            • DannyMD DannyM
              @DannyM - If you use a capacitor on the radio, you are fine.
              Is the node far way from your gateway?
              How do you power the sensors?
              • DannyMD
                DannyMD
                DannyM
                @sundberg84 My node is approx 3 meters away from the gateway, and now I am powering it from the computer, it's an Arduino Nano with USB cable.
                • DannyMD
                  DannyMD
                  DannyM
                  I have now rebooted my GW so sending will be OK:
                  send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:0.2
                  find parent
                  send: 1-1-0-0 s=2,c=1,t=23,pt=7,l=5,sg=0,st=fail:61.2
                  L: 61.2
                  send: 1-1-0-0 s=2,c=1,t=23,pt=7,l=5,sg=0,st=ok:6.9
                  L: 6.9
                  send: 1-1-0-0 s=2,c=1,t=23,pt=7,l=5,sg=0,st=ok:7.1
                  L: 7.1
                  • DannyMD DannyM
                    find parent
                    L: 61.2
                    L: 6.9
                    L: 7.1
                    TheoLT
                    TheoLT
                    TheoL
                    @DannyM You still have some failures. I noticed that they're present in the Humidity only sketch as well.
                    In my experience it's better to power nothing from the Arduino. The radio only works always, but using a phone charger will give you 5v and using a buck boost converter (80 euro cents on aliexpress) can provide 3.3V. As an alternative for the buck converter a low drop LE33 works perfectly for me.
                    But please attache capacitor to all radio's (gateway and nodes). And try to power as less as you can from the arduino. The arduino just wasn't designed to deliver a lot of current.
                    • DannyMD
                      DannyMD
                      DannyM
                      Maybe This has something to do with it:
                      The Lightsensor isn't belonging to the DHT sensor.. I think :-\
                      • DannyMD DannyM
                        TheoLT
                        TheoLT
                        TheoL
                        @DannyM Could be. But I doubt it. Look here.
                        TempHum only:
                        st=fails means that the radio can't deliver the message to the gateway. If a message could be delivered st will be ok
                        The failed reading is certainly caused by initializing the DHT with the wrong pin.
                        Anyway I hope that you're able to get this to work with the help of others. I wouldn't be much online this weekend. But I'm hoping to see a positive post from you in this thread (meaning you got it working ;-)).
                        Might be a good idea to start with the humidity temp sensor only. And see if you can get to work without any st=fail's in your log. Then you can go to the next step.
                        • DannyMD
                          DannyMD
                          DannyM
                          Yes, that did it,
                          Thanks @sundberg84 and @TheoL for your time..
                          • DannyMD
                            DannyMD
                            DannyM
                            @TheoL I use a telephone charger most of the time, I'm a beginner with all.
                            Hope to make this a battery oparated sensor, will search for the components you mentioned.
                            thanks
                            • DannyMD
                              DannyMD
                              DannyM
                              Hi all,
                              Now I have bought a stepdown regulator to regulate the power for the radio.
                              The readings of the sensor are the same as not using the stepdown regulator. So what can be wrong?
                              Or is it not possible to use a LDR and a DHT11 together?
                              M 1 Reply Last reply
                              • DannyMD DannyM
                                Hi all,
                                MLs
                                wrote on last edited by MLs
                                @DannyM
                                Yes you can use LDR and a DHT11 together.
                                 * Example sketch showing how to measue light level using a LM393 photo-resistor
                                 * http://www.mysensors.org/build/light
                                // NodId
                                #define MY_NODE_ID 99
                                //Including nescessary libraries
                                #include <DHT.h>
                                #define SENSOR_TEMP_OFFSET 0
                                //Defining child ID
                                #define CHILD_ID_LIGHT 0
                                #define CHILD_ID_HUM 1
                                #define CHILD_ID_TEMP 2
                                //Defining Pin
                                #define DHT_DATA_PIN 3
                                #define LDR_PIN A0
                                //Defining values to store sensor information
                                float lastTemp;
                                float lastHum;
                                uint8_t nNoUpdatesTemp;
                                uint8_t nNoUpdatesHum;
                                bool metric = true;
                                int lastLightLevel;
                                //Defining sleep and wait times
                                unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)(30 seconds)
                                #define MESSAGEWAIT 500
                                MyMessage LightMsg(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                                DHT dht;
                                void presentation()  {
                                  sendSketchInfo("Temp Fukt Ljus", "1.0"); // 2017 02 05
                                //  wait(MESSAGEWAIT);
                                  dht.readSensor(true);
                                    if (!metric) {
                                    // Reset no updates counter
                                    nNoUpdatesTemp = 0;
                                    #ifdef MY_DEBUG
                                  } else {
                                    nNoUpdatesTemp++;
                                    lastHum = humidity;
                                    nNoUpdatesHum = 0;
                                    #ifdef MY_DEBUG
                                  } else {
                                    nNoUpdatesHum++;
                                  int lightLevel = (1023-analogRead(LDR_PIN))/10.23;
                                      send(LightMsg.set(lightLevel));
                                  sleep(SLEEP_TIME);
                                LDR pin A0
                                DHT pin 3
                                And i use pro mini.
                                //Mattias
                                DannyMD 1 Reply Last reply
                                • M MLs
                                  @DannyM
                                  // NodId
                                  #include <DHT.h>
                                  //Defining child ID
                                  //Defining Pin
                                  #define LDR_PIN A0
                                  float lastTemp;
                                  float lastHum;
                                  bool metric = true;
                                  int lastLightLevel;
                                  DHT dht;
                                      if (!metric) {
                                      nNoUpdatesTemp = 0;
                                      #ifdef MY_DEBUG
                                    } else {
                                      nNoUpdatesTemp++;
                                      lastHum = humidity;
                                      nNoUpdatesHum = 0;
                                      #ifdef MY_DEBUG
                                    } else {
                                      nNoUpdatesHum++;
                                    sleep(SLEEP_TIME);
                                  LDR pin A0
                                  DHT pin 3
                                  And i use pro mini.
                                  //Mattias
                                  DannyMD
                                  DannyMD
                                  DannyM
                                  @MLs
                                  Hi, thanks for your input, whit setup of the pins you used I have no more failed to read from DHT sensors in my serial monitor.
                                  Now I need to revise my sketch, so it will send correct values.
                                  Thanks again!
                                  • DannyMD DannyM
                                    @MLs
                                    Thanks again!
                                    MLs
                                    @DannyM
                                    //Mattias
                                    I use a 10k resistor to LDR.
                                    • DannyMD
                                      DannyMD
                                      DannyM
                                      Hi all,
                                      All works fine now! After the reshuffle of the connection pins it does what I want it to do.
                                      Only thing I need to change is the sleeptime, it's now set to 6000 and when no change send a value to the GW after ten readings. But it is to often now..
