  3. From 1.5 to 2.0. Can't get it running
13 Posts 5 Posters 4.1k Views 3 Watching
  • xydixX
    xydixX
    xydix
    Hi.
    Decided to go for 2.0.
    I use an ethernet gateway (an uno with w5100 sheild. The same i used with 1.5) and my sensors can't find the gateway.
    I use the NRF radio wired just lite i had before. That i right, yes?
    I downloded a fresh library from arduino library manager today.
    Loaded the sketch to my gateway. I didn't change anything in MyConfig.h or MySensors.h
    The only thing i changed in the sketch was the IP.
    Serial monitor gateway:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    IP: 192.168.1.66
    IP: 192.168.1.66
    Serial monitor node:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=3)
    TSM:FPAR
    TSP:MSG:SEND 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    I tried different sketches from the examples and tried to set ID manually.
    I tried to switch radios. I use a capacitor on the radios.
    I tried different power supplys
    Please help. I going crazy.
    YveauxY 1 Reply Last reply
    • xydixX xydix
      Hi.
      IP: 192.168.1.66
      IP: 192.168.1.66
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      YveauxY
      YveauxY
      @xydix Please refer to this thread: https://forum.mysensors.org/topic/4680/mysensors-2-0-ethernet-gateway-atmega-w5100-restart-all-time
      Looks like you're running into the same issue.
      • xydixX
        xydixX
        xydix
        wrote on last edited by xydix
        Yeah i saw this after i got in bed so i was about to try this in the morning.
        But thank you for your answer.
        Now i got my GW running but i got a new problem.
        If my node fail to deleiver a message for the last 6 tries i "gives up"
        TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:1
        TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=ok:0
        !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=fail:0
        !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=fail:1
        TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=2,st=ok:0
        !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=2,st=fail:0
        !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=3,st=fail:1
        !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=4,st=fail:0
        !TSP:MSG:SEND 3-3-0-0 s=4,c=1,t=16,pt=2,l=2,sg=0,ft=5,st=fail:1
        !TSM:UPL FAIL, SNP
        TSM:FPAR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        !TSP:SEND:TNR
        After this i can't get it to transmit any more and i have to push the resetbutton.
        In this example i use a binary switch, pushing my button and when i hold my hand over the radio so the signal won't reach my GW this happends.
        Any thoughts?
        Thanks.
        sundberg84S tekkaT 2 Replies Last reply
        • xydixX xydix
          !TSM:UPL FAIL, SNP
          TSM:FPAR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          !TSP:SEND:TNR
          Any thoughts?
          Thanks.
          @xydix - i think @tekka can say exatcly but i read somewhere he wrote that it will pause for some time before trying to discover again. If it fails 6 times again it makes a new pause.
          • xydixX xydix
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            Any thoughts?
            Thanks.
            tekkaT
            tekkaT
            tekka
            @xydix I suggest you try these changes:
            • Increase TX power on both, GW and node, using
            • Increase distance between GW and node if they are too close (>5m)
            • Add/substitute radio caps, ideally >100uF
            • If none of that helps, please upload both sketches for further troubleshooting
            • xydixX
              xydixX
              xydix
              Thank you guys for answers.
              @tekka
              What i want here is to know my sensors won't get in a state when i have to reset them.
              I have one door sensor that is to far away and sometimes it won't reach the gateway. I will fix this later.
              But still, i want to be sure my sensors reconnect to my GW.
              If i for some reason have to disconnect my GW and open some doors, this will result in that i have to reset them later when my GW is up.
              Thanks for reminding me to define PA level. Totally forgot about that.
              tekkaT 1 Reply Last reply
              • xydixX xydix
                @tekka
                tekkaT
                tekkaT
                tekka
                As @sundberg84 pointed out, your node will try to reconnect after a timeout. Furthermore, you can prevent the node from searching a new parent after too many fails by setting a static parent (assumption: GW is the parent node):
                #define MY_PARENT_NODE_ID 0
                • xydixX
                  xydixX
                  xydix
                  @tekka I left it running with the serial montor for about an hour but it didn't reconnect. Only !TSP:SEND:TNR
                  I guess i have to set a static parent.
                  What is the point of this? Was it the same in 1.5?
                  • xydixX
                    xydixX
                    xydix
                    I searched the forum and found a thread about this.
                    @tekka you posted this:
                    replace
                    sleep(30000);
                    with
                    if(isTransportOK()){
                        sleep(30000);  // transport is OK, node can sleep
                      else {
                        wait(5000); // transport is not operational, allow the transport layer to fix this
                    And this will do it.
                    Now my node reconnect.
                    Is this the best way to do it?
                    I use battery powered sensors. Will this drain my batteries?
                    Will my node sleep as it should?
                    Haven't hade the time to measure this yet.
                    • xydixX xydix
                      replace
                      sleep(30000);
                      with
                        else {
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      @xydix of course, if you have a sleeping node, this will ensure link re-establishment
                      • xydixX
                        xydixX
                        xydix
                        I had it working like one day.
                        Now i have problems again. :-1:
                        Right now i am only using 2 nodes, batterypowered doorswitches.
                        I did a small change in one of my sketches, after that it didn't present itself to the GW/controller I guess.
                        I use Home Assistant as controller, and i deleted my "mysensors.json-file" to do a fresh start.
                        After this i can't get any node working.
                        Side by side log from serial monitor:
                        0_1473238590913_upload-d9867691-1703-476d-b2b4-509fd60e799d
                        @tekka GW recive messages, right? But node don't receive it?
                        @martinhjelmare
                        I hope you are the right person to ask because i use Home Assistant.
                        Can you please check my sketch.
                        Like i said, earlier it woked.
                        No error in HA log.
                         * Interrupt driven binary switch example with dual interrupts
                         * Author: Patrick 'Anticimex' Fallberg
                         * Connect one button or door/window reed switch between
                         * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
                         * one in similar fashion on digital I/O pin 2.
                         * This example is designed to fit Arduino Nano/Pro Mini
                        #define SKETCH_NAME "Basementdoor"
                        #define SKETCH_MAJOR_VER "1"
                        #define SKETCH_MINOR_VER "0"
                        int oldBatteryPcnt = 0;
                        #define CHILD_ID 3
                        #define BUTTON_PIN 3   // Arduino Digital I/O pin for button/reed switch
                           analogReference(INTERNAL1V1);
                        #else
                           analogReference(INTERNAL);
                          // Setup the buttons
                          pinMode(BUTTON_PIN, INPUT);
                          // Activate internal pull-ups
                        //  digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
                        void presentation() {
                          sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
                          // Register binary input sensor to sensor_node (they will be created as child devices)
                          present(CHILD_ID, S_DOOR);
                          uint8_t value;
                          static uint8_t sentValue=2;
                          sleep(5);
                          value = digitalRead(BUTTON_PIN);
                          if (value != sentValue) {
                             // Value has changed from last transmission, send the updated value
                             send(msg.set(value==HIGH ? 0 : 1));
                             sentValue = value;
                              // get the battery Voltage
                           #ifdef MY_DEBUG
                           Serial.println(sensorValue);
                           #ifdef MY_DEBUG
                           float batteryV  = sensorValue * 0.003363075;
                           Serial.print(batteryV);
                           Serial.println(" V");
                           Serial.print(batteryPcnt);
                           Serial.println(" %");
                             // Power up radio after sleep
                             oldBatteryPcnt = batteryPcnt;
                          // Sleep until something happens with the sensor
                            sleep(BUTTON_PIN-2, CHANGE, 0);  // transport is OK, node can sleep
                          else {
                        I read this:
                        Send at least one initial value per V_TYPE. In version 2.0 of MySensors this has to be done in the loop function. See below for an example in 2.0 of how to make sure the initial value has been received by the controller.
                        But not sure if it is needed here and how to put that in my sketch. Please help a Newbe.
                        Edit:
                        BTW. I guess many had problem like this due to powering problems. When i measure, it's steady 3,36V on VCC and on my radio.
                        • xydixX
                          xydixX
                          xydix
                          Okay, i think i found a solution.
                          On my sensors i removed the onboard voltage regulator.
                          By coincidence i powered my sensor from only one AA battery when i was testing. I use battery booster and 2 AA otherwise.
                          Sudenly it worked. Presentation happend and sensor is working.
                          I measured again with a better multimeter. With one AA battery: 3,34V, with two AA batteries: 3,38V.
                          I tested several times and this is really the issue. I guess the pro mini or the radio is sensitive when it comes to higher voltage than 3.3V
                          After presentation i added the second battery without disconnecting and now it works.
                          This was never a problem with Mysensors 1.5.
                          Is the presentation more "sensitive" in 2.0?
                          Can anyone explain why this happend? Someone said that the NRF24-radio can handle up to 3,6V.
                          Anyone know how to "fix" a batterybooster?
                          Please, if someone know. Tell me/us.
                          BUT! If you have problems with a sensor and use batterybooster/ removed onboard voltage regulator. Check voltage.
                          • xydixX xydix
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @xydix
                            Sketch looks OK. Sounds like a hardware issue. Have you tried replacing booster and/or radio?
