  3. Sensor Repeat
Sensor Repeat
7 Posts 4 Posters 2.2k Views 3 Watching
  • t1m0T Offline
    t1m0T Offline
    t1m0
    I have found no answer in the forum . therefore a new topic .
    I have a gateway in 10m and in 5 meter any sensor . 0m is now a signal triggered .
    10m to the gateway can not be reached.
    It will then be automatically amplified by sensor standing on 5 meter ????
    The meter disclosures are fictive
    Thanks for answers
    S mfalkviddM 2 Replies Last reply
    • F Offline
      F Offline
      flopp
      If the sensor is a normal node it will not repeat any sensor data.
      You can install a Repeater between the not working sensor and the GW.
      t1m0T 1 Reply Last reply
      • t1m0T t1m0
        Thanks for answers
        This post is deleted!
        • t1m0T t1m0
          Thanks for answers
          @t1m0 Which radio are you using? You should get more than 10 meters unless your walls are mean to radio signals. See the range troubleshooting flow diagram at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
          • t1m0T Offline
            t1m0T Offline
            t1m0
            the meter pay are only examples !!!
            I wanted to know just generally
            • F flopp
              t1m0T Offline
              t1m0T Offline
              t1m0
              wrote on last edited by t1m0
              @flopp they do!!!!!
              i found the answer of my question! :)
              0_1473001308204_a679d359-9cc0-4265-b02e-6b0e9bb81af8.jpg image url)
              F 1 Reply Last reply
              • t1m0T t1m0
                @flopp they do!!!!!
                F Offline
                F Offline
                flopp
                @t1m0
                Repeater-sensor-node is a Repeater node
                What I meant with Normal node is Sensor node and they don't send others data to GW
                Sorry if I was not clear 😉
