  2. Announcements
  3. šŸ’¬ What's all the fuss about?
34 Posts 18 Posters 20.0k Views 20 Watching
    Hi @matias_sams, welcome to the MySensors community!
    The answer to all your questions is yes. However, the more logic/code added, the harder it will become to create bug-free code, and troubleshooting also becomes harder. Our general recommendation is to start simple and then add more logic step by step.
    bjacobseB
    bjacobseB
    bjacobse
    @mfalkvidd said in šŸ’¬ What's all the fuss about?:
    And this good rules can actually be transferred to almost anything :-)
      Matias_SAMSM
      Matias_SAMSM
      Matias_SAMS
      @mfalkvidd Great!!! Ok, let's do it... I think tonight my girlfriend kicks me out of the house jajaja.... lol...
      • Matias_SAMSM
        Matias_SAMSM
        Matias_SAMS
        Hello! Forgive me if I bother you, or if I ask some stupidity ... but I wanted to ask you something I can not find anywhere.
        I already have a Relay node and a Sensor Node with a gateway running. I am using MYSController. Everything works OK.
        I have concerns about some code syntax.
        I can not finish understanding regarding the reading or writing of states in a binary device the syntax:
        state? RELAY_ON: RELAY_OFF
        or
        state? "true": "false"
        What does the "?" Mean. How should I understand that line? Because there are times when it appears inverted:
        state? RELAY_OFF: RELAY_ON
        or
        state? "false": "true"
        Thank you!
        • bjacobseB
          bjacobseB
          bjacobse
          @matias_sams said in šŸ’¬ What's all the fuss about?:
          It's known in C language as conditional operator
          https://en.wikipedia.org/wiki/%3F:#C
            #25
            To add to the previous answer, in the relay example sketch, ? is used to handle that some relays are active low, some are active high.
            From the sketch:
            • Matias_SAMSM
              Matias_SAMSM
              Matias_SAMS
              Thank you very much community, you are great!
              • T
                TalhaYounis
                Hi, I'm working on project of mobile app to measure the CO2, LPG gas , Smog through MQ135 and MQ7 sensors. Kindly help me what should I do??
                Give me suggestions....Thank you
                • T TalhaYounis
                  Welcome to the MySensors forum @talhayounis
                  Th best way to get started with MySensors is to first read the getting started guide. Then you can move on to https://www.mysensors.org/build/gas which has an example sketch to use with MQ135 and MQ7.
                  The best way is usually to get a gateway and a simple node running, and then expand from that.
                  • V
                    V
                    viti
                    This post is deleted!
                    YveauxY 1 Reply Last reply
                    • V
                      V
                      viti
                      • V viti
                        [[topic:post-is-deleted]]
                        YveauxY
                        YveauxY
                        @viti please stop crossposting your questions!
                        • Z
                          Z
                          ZhangCan
                          Smaller sensors require lighter lenses (for equivalent angle of view, zoom range, build quality and aperture range).
                          • I
                            I
                            IceTalon
                            Banned
                            Hi everyone, I’m new here and happy to join the forum. Looking forward to learning and sharing with you all.
                            • skywatchS
                              skywatchS
                              skywatch
                              Welcome - I hope you find it inspiring, educational and practical. There is lots to learn and more to achieve.
                              With your input, this post could be even better šŸ’—
