  2. Announcements
  3. 💬 Connecting the Radio
162 Posts 49 Posters 109.3k Views 40 Watching
  • scalzS scalz
    for using RFM69HW, you just need to use the common rfm69 defines and add this
    #define MY_IS_RFM69HW
    korttomaK
    korttomaK
    korttoma
    #41
    @rmtucker
    You add the #define to your sketch
    Hi @scalz ,
    Will a RFM69HW work without the "#define MY_IS_RFM69HW" ?
    What exactly does this #define do for the HW version?
    Have only used RFM69W so far but have ordered some HW now also.
    • Tomas
    • scalzS
      scalzS
      wrote on last edited by scalz
      #42
      to your GW sketch.
      Also, for using RFM69H you need this define,else the radio can't work properly. This allow us to set the right Radio power level registers in lib.
      @korttoma just curious :) Have you tried my rfm69 repo?
      korttomaK 1 Reply Last reply
      • scalzS scalz
        to your GW sketch.
        korttomaK
        korttomaK
        korttoma
        @scalz
        So does a H version radio work if you do not set the high power registers?
        @scalz said:
        @korttoma just curious Have you tried my rfm69 repo?
        Sorry, I have not yet had the opportunity to test your repo. There is so much non MySensors activities now when Christmas is approaching.
        • Tomas
        • pepsonP
          pepsonP
          pepson
          With radio RFM69HW for gateway sketch should looks as:
          • The MySensors Arduino library handles the wireless radio link and protocol
          • between your home built sensors/actuators and HA controller of choice.
          • The sensors forms a self healing radio network with optional repeaters. Each
          • repeater and gateway builds a routing tables in EEPROM which keeps track of the
          • network topology allowing messages to be routed to nodes.
          • Created by Henrik Ekblad henrik.ekblad@mysensors.org
          • Copyright (C) 2013-2015 Sensnology AB
          • Full contributor list: https://github.com/mysensors/Arduino/graphs/contributors
          • Documentation: http://www.mysensors.org
          • Support Forum: http://forum.mysensors.org
          • This program is free software; you can redistribute it and/or
          • modify it under the terms of the GNU General Public License
          • version 2 as published by the Free Software Foundation.
          • DESCRIPTION
          • The ArduinoGateway prints data received from sensors on the serial link.
          • The gateway accepts input on seral which will be sent out on radio network.
          • The GW code is designed for Arduino Nano 328p / 16MHz
          • Wire connections (OPTIONAL):
            • Inclusion button should be connected between digital pin 3 and GND
            • RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
          • LEDs (OPTIONAL):
            • To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
            • RX (green) - blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
            • TX (yellow) - blink fast on radio message transmitted. In inclusion mode will blink slowly
            • ERR (red) - fast blink on error during transmission error or recieve crc error
          //#define MY_RADIO_NRF24
          #define MY_RADIO_RFM69
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Enable inclusion mode
          //#define MY_INCLUSION_MODE_BUTTON_PIN 3
          // Set blinking period
          // Flash leds on rx/tx/err
          //#define MY_DEFAULT_ERR_LED_PIN 4 // Error led pin
          //#define MY_DEFAULT_RX_LED_PIN 6 // Receive led pin
          //#define MY_DEFAULT_TX_LED_PIN 5 // the PCB, on board LED
          void presentation() {
          sendSketchInfo("MySensors Serial Gateway", "2.0.0");
          • scalzS
            scalzS
            #45
            @pepson if you're using an Arduino Mini pro or equivalent, and follow the recommanded wiring for the radio (CS and INT), looks ok to me.
            @korttoma oki. no it won't work if the define is not set for HW version, and vice versa. Because the W and HW use different registers for setting power levels
            rmtuckerR 1 Reply Last reply
            • pepsonP
              pepsonP
              pepson
              Now i test it on Arduino nano byt finally i want use it on Arduino Mini Pro. Wirering i use as show on this page.
              • scalzS
                scalzS
                @pepson oki. But you've not explained what's your problem, without logs etc..
                • pepsonP
                  pepsonP
                  pepson
                  Now any problem. I only need info how write sketch to use radio RFM69HW.
                  G 1 Reply Last reply
                  • scalzS scalz
                    rmtuckerR
                    rmtuckerR
                    rmtucker
                    wrote on last edited by rmtucker
                    #49
                    @scalz
                    Is there an instruction to alter the power level on the RFM69?
                    From inside a mysensors sketch like the NRF24_PA_level?
                    • scalzS
                      scalzS
                      #50
                      @rmtucker no not yet (not sure, i need to check). But yes, in the next release ;)
                      • pepsonP pepson
                        G
                        G
                        gvorster
                        Try the MockMySensors.ino sketch and enable a few sensors.
                        • pepsonP
                          pepsonP
                          pepson
                          Good will be add manual how in sketch change level for RFM69HW when new version released. I know that should be released on chrismass
                          • scalzS
                            scalzS
                            #53
                            @pepson if you have been kind this year, perhaps :laughing:
                            • martinsM
                              martinsM
                              martins
                              I'm having trouble with the distance between my 2 RFM69 radios. If I use this tutorial and change the frequency to 433 mhz I get distances of up to 10 meters - https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/rfm69-test
                              However if I use the Mysensor libraries for the SerialGateway and the door sensor I don't even get 1 meter.
                              I tried to declare these variables as well but no success.
                              #define RFM69_FREQUENCY RF69_433MHZ
                              #define IS_RFM69HW
                              Any suggestions I might try out?
                              Thanks,
                              Martin
                              martinsM 1 Reply Last reply
                              • pepsonP
                                pepsonP
                                pepson
                                If i buy from aliexpress RFM69HW and when buy i select to seller info that i want 868MHz and on PCB RFM69HW has select/write 868MHz in sketch i must use item:
                                #define RFM69_FREQUENCY RF69_868MHZ ?
                                • martinsM martins
                                  #define IS_RFM69HW
                                  Thanks,
                                  Martin
                                  martinsM
                                  martinsM
                                  martins
                                  @martins
                                  Solved. This is the extra variables for the RFM69H / HW versions and to set the frequency.
                                  Range is now acceptible.
                                  Regards,
                                  Martin
                                  • pepsonP pepson
                                    martinsM
                                    martinsM
                                    martins
                                    @pepson
                                    From library API:
                                    MY_RFM69_FREQUENCY RF69_868MHZ For other frequency, add this define to your sketch and set it to your preferred value in RF69_433MHZ, RF69_868MHZ or RF69_915MHZ
                                    So it seems that 868MHZ is the default value.
                                    Regards
                                    • pepsonP
                                      pepsonP
                                      pepson
                                      Ok thanks
                                      • LaMB95L
                                        LaMB95L
                                        LaMB95
                                        I m getting symbols when I send Hello World message from Arduino Uno to an Arduino Pro Mini (5V).
                                        Yes I have put an input of 3.3V to the pro mini.
                                        Baud rate used is 9600.
                                        Any clue why this is happening? I can provide the code.
                                        • LaMB95L LaMB95
                                          @LaMB95 are you using a Pro Mini 5V 16MHz or Pro Mini 3.3V 8MHz?
                                          If the wrong variant is selected in the Arduino IDE, all timings will be off, including the timings for serial communication.
                                          LaMB95L 1 Reply Last reply
