  2. Announcements
  3. 💬 Building an Ethernet Gateway
133 Posts 42 Posters 102.4k Views 35 Watching
  • mppM mpp
    @hek just tested the gateway sketch on an esp with an rfm69 and it looks really promising. Would it be possible to communicate with moteino's or do I have to create arduino+rfm69 nodes running the mysensor sketch?
    #41
    @mpp according to this:
    Moteino is a low power wireless Arduino compatible development platform based on the popular ATmega328p chip used in the Arduino-UNO, making it 100% compatible with the Arduino IDE (programming environment) ... They are compatible with any other Arduino clones that use the popular HopeRF RFM69 transceiver
    so they should work just fine. Just upload one of the MySensors example sketches to the moteino and try.
      Just for sharing, yesterday I was playing around and I tried to make an ethernet gateway with a UNO with w5100 shield and a nrf24 radio, then I attached a DHT11 sensor to it; when I compiled the sketch I had to disable the MY_DEBUG otherwise the I could not upload it to the UNO as it was using 102% of available memory and even with no debug the Arduino IDE was giving me warning about low ram memory available that could make system unstable. I then removed the NRF24 part as I didn't need it at the moment and the sketch compiled smoothly.
      It looks like the MEGA2560 could be a better candidate if you want to make a gateway with some sensors.
      • S
        Sensibelchen
        wrote on last edited by Sensibelchen
        #43
        Solved: challenge with requesttime
        Update: mysensors adapter 1.0.7 for ioBroker solved the issue.
        Challenge:
        my arduino node20 is requesting epoch time. W5100 gateway forwards message to controller (ioBroker). This is the gateways console in debug:
        0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=1,pt=0,l=0,sg=0:
        0;255;3;0;9;Eth: 20;255;3;1;I_TIME;1491770622
        0;255;3;0;9;TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=0,pt=0,l=10,sg=0,ft=0,st=OK:1491770622
        0;255;3;0;9;TSF:MSG:READ,20-20-0,s=255,c=3,t=0,pt=0,l=10,sg=0:1491770622
        0;255;3;0;9;TSF:MSG:ACK
        The parser helps with the interpretation:
        1. request from node20 (Arduino) t=1 (=I_TIME)
        2. gateway receives epoch time from controller (ioBroker)
        3. gateway forwards info to node20. BUT: now with t=0 (=I_BATTERY_LEVEL)!!!!!!!!!!!!!!!
        4. node20 confirms battery level (and still doesn't know the time)
        I'm using the ordinary gateway for W5100. Sensordata moves flawless to the controller but forwarding the time seems to be broken.
        Any idea? Thank you in advance.
        • E
          E
          Ed1500
          The reason why the 5100 module has problems sharing the SPI interface is because it lacks some hardware compared to the W5100 shield.
          On (most of) the module(s) the SEN (SPI Enable) pin is pulled HIGH with a resistor, whereas on the W5100 shield it also receives the inverted CS signal.
          That means that when the chip is deselected (CS=HIGH), the SEN pin receives a LOW and the SPI is switched off.
          Apparently the state of the SS pin through the CS signal is not enough to Switch off the W5100 SPI: the MISO remains active, the SEN pin neds to be addressed too to shut off SPI completely.
          If it works with a virtual SPI connection, great, but if you want to "fix" the hardware SPI, all you need to do is to invert the CS signal with a 74xx14 or maybe even a 74xx04 and feed that to the SEN pin of the chip.
          https://arduinodiy.wordpress.com/2017/04/12/the-w5100-bug/
          • Mitja BlazinsekM
            Mitja BlazinsekM
            Mitja Blazinsek
            i'm using w5100 and mega, checking wiring 10 times and successfully uploaded code didn't change anything in code just copy paste but it seem like is not working i installed domoticz controller and it log to me
            2017-04-17 21:51:38.438 Error: MySensors: Can not connect to: 192.168.178.66:5003
            2017-04-17 21:51:38.438 TCP: Connection problem (Unable to connect to specified IP/Port)
            Also i can't see any new client in router client table, rx led is blinking but tx led on w5100 is always off
            can anyone tell me how can i see if gw is working, i don't know is the problem on controller or hw? and how can i fix the problem?
            THX for any help, and excuse for my english please ;)
              Try with any other sketch even not mysensors and check if ip is working, if still not working could be also the Chinese clone shield: I had one that got the wrong termination resistors and I fixed it by soldering 1 100ohms resistor between pin 1-2 and 1 between pin 3-6 below the ethernet socket
              • Mitja BlazinsekM
                Mitja BlazinsekM
                Mitja Blazinsek
                probably dumb question but where can i found any sketch to test the shield i tried ethernet examples from arduino ide but dont know how to connect the right pins it just said like: (Ethernet shield attached to pins 10, 11, 12, 13)
                E 1 Reply Last reply
                • Mitja BlazinsekM Mitja Blazinsek
                  E
                  E
                  Ed1500
                  @Mitja-Blazinsek https://i0.wp.com/www.jdohnalek.com/wp-content/uploads/2014/10/W5100-Red-Mini-01-e1414707788425.jpg
                  • numanxN
                    numanxN
                    numanx
                    Could you send us a picture with the module?
                    • Mitja BlazinsekM
                      Mitja BlazinsekM
                      Mitja Blazinsek
                      look like the Chinese shield is crap i try to test the web server example and nothing displayed
                        E
                        E
                        Ed1500
                        @Mitja-Blazinsek can you check your lineresistors? It is the spider like, 8 legged rrsistor array as in this picture https://arduinodiy.files.wordpress.com/2017/04/w5100bug2.png?w=768&h=332
                        what is the value?
                        • numanxN
                          numanxN
                          numanx
                          Maybe you have the ENC28J60 module which is different than w5100.
                          try this code at the beginning of your sketch(using a mysensor's example)
                          you have to change the ip to match your subnet and try to ping it.
                          You can find the correct pinout here http://s3.electrodragon.com/wp-content/uploads/2011/11/172004eierrfwri9xsfamq-11.jpg
                          #define MY_GATEWAY_ENC28J60
                          #define MY_IP_ADDRESS 192,168,1,66
                          #define MY_PORT 5003
                          #include <UIPEthernet.h>```
                          • Mitja BlazinsekM
                            Mitja BlazinsekM
                            Mitja Blazinsek
                            i'm sure it's w5100 it's label on chip
                            https://goo.gl/photos/xkr326Zrjgom2Ko57
                            E 3 Replies Last reply
                              E
                              E
                              Ed1500
                              @Mitja-Blazinsek exactly the same module I have. Funduino right? Is working here
                                Look at THIS page, half way down, there is the picture where to solder the 2 resistors.
                                  E
                                  E
                                  Ed1500
                                  @Mitja-Blazinsek I went back to what I have done to get that module to work and I remember the only thing I had to do was add a delay in the setup, as most problems with that funduino board seem to be because of a Reset problem:
                                  with this setup It works for me:
                                  // setup ethernet communication using DHCP
                                  delay(250); /// <-------- THAT ONE, BEFORE your ethernet.begin statement
                                  if (Ethernet.begin(mac) == 0) {
                                  //Serial.println(F("Unable to configure Ethernet using DHCP"));
                                  for (;;);
                                  Forget about "changing the 510 resistors" that is something that is valid for some shields, not for the Funduino module.
                                  I only have the Miso,Mosi,SCK and NSS connected (and Vcc/ground ofcourse). NOT the RST. Besides, if you connect RST you cannot upload sketches as your Arduino will continuously reset
                                    E
                                    E
                                    Ed1500
                                    @Mitja-Blazinsek Is your problem solved now Mitja?
                                    connecting stand alone W5100 to ethernet should be solved by the delay i advised. I guess it should work with rfm69 if you set up the software SPI as described, but if you want to use hardware SPI a slight modification is necessary, which i described earlier
                                    • H
                                      H
                                      hiddenuser
                                      This post is deleted!
                                      • H
                                        H
                                        hiddenuser
                                        I am not sure where I went wrong the below code hangs half way through. I am using ENC28J60
                                        https://www.aliexpress.com/item/Mini-ENC28J60-Webserver-module-Ethernet-Shield-board-for-Arduino-Nano-v3-0/2037927977.html?spm=2114.40010208.4.8.mUp9p8
                                        #ifndef config_h
                                        #define config_h
                                        #include <stdint.h>
                                           MySensors configuration
                                        //#define MY_BAUD_RATE 9600
                                        //#define MY_BAUD_RATE 38400
                                        //#define MY_BAUD_RATE 115200
                                        //#define MY_NODE_ID 100
                                        //#define MY_GATEWAY_W5100
                                        // Enabled repeater feature for this node
                                        //#define MY_REPEATER_FEATURE
                                        // The ENC28J60 ethernet module seems to have a hard time co-operate with
                                        // radio on the same spi bus.
                                        #define MY_SOFTSPI
                                        // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
                                        #ifndef MY_RF24_CE_PIN
                                        #define MY_RF24_CE_PIN 5
                                        #ifndef MY_RF24_CS_PIN
                                        #define MY_RF24_CS_PIN 6
                                        // Gateway IP address
                                        #define MY_IP_ADDRESS 192,168,0,66
                                        //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 55
                                        #define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xFE
                                        // Flash leds on rx/tx/err
                                        //#define MY_LEDS_BLINKING_FEATURE
                                        // Set blinking period
                                        // Enable inclusion mode
                                        #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
                                        #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
                                        #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
                                        //#define MY_DISABLED_SERIAL
                                        // Turn off debug if serial pins is used for other stuff
                                        #ifdef MY_DISABLED_SERIAL
                                        #undef MY_DEBUG
                                        *  Gateway config
                                         * @def MY_GATEWAY_MAX_RECEIVE_LENGTH
                                         * @brief Max buffersize needed for messages coming from controller.
                                        #ifndef MY_GATEWAY_MAX_RECEIVE_LENGTH
                                        #define MY_GATEWAY_MAX_RECEIVE_LENGTH (100u)
                                         * @def MY_GATEWAY_MAX_SEND_LENGTH
                                         * @brief Max buffer size when sending messages.
                                        #ifndef MY_GATEWAY_MAX_SEND_LENGTH
                                        #define MY_GATEWAY_MAX_SEND_LENGTH (120u)
                                         * @def MY_GATEWAY_MAX_CLIENTS
                                         * @brief Max number of parallel clients (sever mode).
                                        #ifndef MY_GATEWAY_MAX_CLIENTS
                                        #define MY_GATEWAY_MAX_CLIENTS (1u)
                                        * @def MY_RX_MESSAGE_BUFFER_FEATURE
                                        * @brief This enabled the receiving buffer feature.
                                        * This feature is currently not supported for RFM69 and RS485, for RF24 MY_RF24_IRQ_PIN has to be defined.
                                        //#define MY_RX_MESSAGE_BUFFER_FEATURE
                                         * @def MY_RX_MESSAGE_BUFFER_SIZE
                                         * @brief Declare the amount of incoming messages that can be buffered.
                                        #ifdef MY_RX_MESSAGE_BUFFER_FEATURE
                                        #ifndef MY_RX_MESSAGE_BUFFER_SIZE
                                        #define MY_RX_MESSAGE_BUFFER_SIZE  (20)
                                         * @def MY_RF24_PA_LEVEL
                                         * @brief Default RF24 PA level. Override in sketch if needed.
                                        #ifndef MY_RF24_PA_LEVEL
                                         * @def MY_RF24_CHANNEL
                                         * @brief RF channel for the sensor net, 0-125.
                                         * Frequence: 2400 Mhz - 2525 Mhz Channels: 126
                                         * http://www.mysensors.org/radio/nRF24L01Plus.pdf
                                         * 0 => 2400 Mhz (RF24 channel 1)
                                         * 1 => 2401 Mhz (RF24 channel 2)
                                         * 76 => 2476 Mhz (RF24 channel 77)
                                         * 83 => 2483 Mhz (RF24 channel 84)
                                         * 124 => 2524 Mhz (RF24 channel 125)
                                         * 125 => 2525 Mhz (RF24 channel 126)
                                         * In some countries there might be limitations, in Germany for example only the range 2400,0 - 2483,5 Mhz is allowed
                                         * http://www.bundesnetzagentur.de/SharedDocs/Downloads/DE/Sachgebiete/Telekommunikation/Unternehmen_Institutionen/Frequenzen/Allgemeinzuteilungen/2013_10_WLAN_2,4GHz_pdf.pdf
                                        #ifndef MY_RF24_CHANNEL
                                        #define MY_RF24_CHANNEL  76
                                         * @def MY_RF24_DATARATE
                                         * @brief RF24 datarate (RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps or RF24_2MBPS for 2Mbps).
                                        #ifndef MY_RF24_DATARATE
                                        #define MY_RF24_DATARATE RF24_250KBPS
                                        #include "config.h"
                                        Output:
                                        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
                                        0;255;3;0;9;TSM:INIT
                                        0;255;3;0;9;TSF:WUR:MS=0
                                        0;255;3;0;9;TSM:INIT:TSP OK
                                        0;255;3;0;9;TSM:INIT:GW MODE
                                        IP: 192.168.0.66
                                        0;255;3;0;9;MCO:BGN:STP
                                        0;255;3;0;9;Eth: connect
                                        0;255;3;0;9;Eth: 0;0;3;0;2;
                                        0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                                        0;255;3;0;9;Eth: 0;0;3;0;18;PING
                                        0;255;3;0;9;TSF:MSG:READ,1-1-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                        0;255;3;0;9;TSF:MSG:BC
                                        0;255;3;0;9;TSF:MSG:FPAR REQ,ID=1
                                        0;255;3;0;9;TSF:PNG:SEND,TO=0
                                        0;255;3;0;9;TSF:CKU:OK
                                        0;255;3;0;9;TSF:MSG:GWL OK
                                        ketch uses 26,232 bytes (85%) of program storage space. Maximum is 30,720 bytes.
                                        Global variables use 1,286 bytes (62%) of dynamic memory, leaving 762 bytes for local variables. Maximum is 2,048 bytes.
                                          sorry, but that is not the complete code.
