  2. Announcements
  • martinsM martins
    Get this error from the gateway installed on Raspberry Pi2 with RFM69 Radio.
    From the IDE it works fine:
    0;255;3;0;9;Starting gateway (RRNGA-, 2.0.0)
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:CHKUPL:OK
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.1.0-beta
    mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: !TSM:INIT:TSP FAIL
    mysgw: TSM:FAIL:CNT=1
    From the gateway on the Pi this is the error:
    ./bin/mysgw -d
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=2
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=3
    mysgw: TSM:FAIL:PDT
    mysgw: TSM:INIT
    mysgw: TSM:FAIL:CNT=4
    mysgw: TSM:FAIL:PDT
    Any ideas where I might start looking at?
    Thanks,
    Martin
    marceloaqno
    Code Contributor
    @martins RFM69 is not yet supported in RPi.
    martinsM 1 Reply Last reply
    • M marceloaqno
      martinsM
      martinsM
      martins
      @marceloaqno
      OK let me explain better. I've build an arduino serial gateway and connecting it on the uart of the pi. If I do tail -f /dev/ttyAMA0 I can see the messages comming in on the serial interface. However if I run ./bin/mysgw -d I get this error:
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FAIL:PDT
      This is the configure I used to build it:
      ./configure --my-gateway=serial --my-serial-port=/dev/ttyAMA0 --my-serial-baudrate=38400
      So the RFM69 Radio in not directly on the PI but on the arduino and is used as the serial gateway.
      Hope this clarify it more.
      Regards,
      Martin
      • martinsM martins
        @marceloaqno
        mysgw: TSF:LRT:OK
        mysgw: TSM:INIT
        mysgw: TSF:WUR:MS=0
        mysgw: TSM:FAIL:PDT
        Regards,
        Martin
        martinsM
        martinsM
        martins
        @marceloaqno
        Issue solved. Domoticz read directly the serial inputs from the arduino that's connected on the PI. I was under the impression that you need a gateway (software) running on the PI to interface with Domoticz.
        Thanks,
        Martin
        • E
          E
          ewgor
          Hi there,
          I'm trying to make a gateway on my pi and since the begining i'm stuck!
          Using this: git clone https://github.com/mysensors/MySensors.git
          i get: fatal: unable to access 'https://github.com/mysensors/MySensors.git/': Could not resolve host: github.com
          I tried with sudo too! am i the only one getting this?
          • E ewgor
            Hi there,
            #165
            @ewgor "Could not resolve host" means dns is not working on your raspberry pi. Is the network working properly (can you access other web sites from the pi?) http://www.suntimebox.com/raspberry-pi-tutorial-course/week-3/day-5/ seems to have a guide if you need help configuring network settings.
            Velo17V 1 Reply Last reply
              Velo17V
              Velo17V
              Velo17
              wrote on last edited by Velo17
              #166
              (sorry, I hit reply on mfalkvidd's post)
              I have a strange problem:
              I tried to be smart (haha) and updated my Raspberry2 with
              sudo apt-get update
              sudo apt-get dist-upgrade
              This took quite a while and looked successful to me.
              Unfortunately the MySensors Gateway and/or controller setup is not working correctly anymore. For troubleshooting I disabled my controller (MyController running on the Pi and for sniffing also MYSController available on my Windows machine). I stopped the gateway service and manually ran the gateway with -d debug information and get this:
              mysGateway: Starting gateway...
              mysGateway: Protocol version - 2.0.1-beta
              mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
              mysGateway: TSF:LRT:OK
              mysGateway: TSM:INIT
              mysGateway: TSM:INIT:TSP OK
              mysGateway: TSM:INIT:GW MODE
              mysGateway: TSM:READY
              mysGateway: Listening for connections on 0.0.0.0:5003
              mysGateway: MCO:REG:NOT NEEDED
              mysGateway: MCO:BGN:STP
              mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
              mysGateway: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:BC
              mysGateway: TSF:MSG:FPAR REQ,ID=7
              mysGateway: TSF:PNG:SEND,TO=0
              mysGateway: TSF:CKU:OK
              mysGateway: TSF:MSG:GWL OK
              mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              mysGateway: TSF:MSG:PINGED,ID=7,HP=1
              mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=11,pt=0,l=17,sg=0:Ernie Giess-O-Mat
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=12,pt=0,l=4,sg=0:0.17
              mysGateway: TSF:MSG:READ,7-7-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:READ,7-7-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:READ,7-7-0,s=3,c=0,t=30,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:READ,7-7-0,s=4,c=0,t=21,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
              mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:8219.0
              mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:29.66
              mysGateway: TSF:MSG:READ,7-7-0,s=3,c=1,t=38,pt=7,l=5,sg=0:9.0
              mysGateway: TSF:MSG:READ,7-7-0,s=4,c=1,t=34,pt=1,l=1,sg=0:0
              mysGateway: TSF:MSG:READ,17-17-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              mysGateway: TSF:MSG:FPAR REQ,ID=17
              mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              mysGateway: TSF:MSG:PINGED,ID=17,HP=1
              mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:10834.0
              mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:3.96
              mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=0,pt=1,l=1,sg=0:67
              mysGateway: TSF:MSG:READ,17-17-0,s=1,c=1,t=0,pt=7,l=5,sg=0:18.8
              mysGateway: TSM:READY:NWD REQ
              mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
              mysGateway: TSF:SRT:OK
              Which looks okay to me (2 sensor nodes are sending data here). But after this NWD REQ...STR:OK block nothing more happens, only more of these 3 lines blocks repeat over and over with about 15 minutes or so inbetween.
              "of course" I also re-compiled the gateway source with re-setting the configuration, which is
              sudo ./configure --my-rf24-channel=124 --my-rf24-irq-pin=11  --my-debug=enable
              sudo make install
              any ideas what I can try to make it work again? :-(
              In any case, happy weekend to everyone,
              greetings from Germany!
              • Velo17V Velo17
                sudo apt-get update
                sudo make install
                marceloaqno
                Code Contributor
                #167
                @Velo17 It might be related to the nrf24 irq pin. Could you try to build the gateway without the my-rf24-irq-pin option and check if the gateway still behaves this way?
                • M marceloaqno
                  Velo17V
                  Velo17V
                  Velo17
                  @marceloaqno Thanks for the hint! This actually solves the lock up. But shouldnt the interrupt offer a superior connectivity and thus be desireable? Until yesterday (before I did the RPi upgrading) this worked - or at least it appeared to work (I dont know if the interrupt was actually used)
                  • Velo17V Velo17
                    marceloaqno
                    Code Contributor
                    @Velo17 I had the same problem in the past but I thought it was because of my nrf24 module wasn't properly shielded or my cables was too long, causing some kind of interference to the irq pin.
                    I end up disabling the interrupt options until I replace my nrf24 module or rearrange the cables, which I haven't done yet.
                    Could you give more details on what kind of nrf module you are using and how it is connected to rpi?
                    • P
                      P
                      pettib
                      Hi everyone.
                      I´m trying to build a new homeController with the following parts / software.
                      Raspberry Pi 3
                      Home Assistant
                      MySensors
                      Tellstick
                      Mosquitto MQTT Broker
                      I got everything working beside the MySensors. I´m trying to connect the NRF 24L01+ chip directly to the RPI with help from https://www.mysensors.org/build/raspberry.
                      I want to use MQTT between MySensors and HomeAssistant
                      The MQTT broker is working when i´m testing it.
                      The Mosquitto is configurated with username and Password in the config of Mosquitto.
                      The config i´m using when Make Mysensors is the following:
                      ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24 --my-rf24-irq-pin=15
                      I also changed in the file /examples_linux/mysgw.cpp
                      #define MY_MQTT_USER "My User"
                      #define MY_MQTT_PASSWORD "My Password"
                      When i´m running the command: sudo systemctl status mysgw I got following result.
                      ● mysgw.service - MySensors Gateway daemon
                      Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
                      Active: active (running) since tis 2016-12-27 18:52:34 CET; 25min ago
                      Main PID: 1405 (mysgw)
                      CGroup: /system.slice/mysgw.service
                      └─1405 /usr/local/bin/mysgw
                      dec 27 19:18:10 HomeAssistant mysgw[1405]: failed to connect
                      dec 27 19:18:10 HomeAssistant mysgw[1405]: socket: Too many open files
                      When trying to run command sudo mysgw -d it shows following info in a endless loop:
                      mysgw: Attempting MQTT connection...
                      mysgw: connected to 127.0.0.1
                      Please help figure this out.
                      //PeTi
                      • Flor SandersF
                        Flor SandersF
                        Flor Sanders
                        wrote on last edited by Flor Sanders
                        #171
                        Hello
                        The past two days I've been trying to setup the gateway on my RPi 2 with domoticz.
                        Here's what I did.
                        I installed domoticz onto my raspi, then I tried the install the gateway.
                        cd MySensors
                        Afterwards I did the following
                        make
                        sudo ./bin/mysgw -d
                        Then it seems to start normally onto the point where it refuses to connect to anything.
                        Does anyone have a clue what's going wrong?
                        I can't seem to figure it out. I've tried it several times over, and always go similar results.
                        I was using GertSanders's connector for the RPi Hub and I've tried it with normal wiring too.
                        As far as I can see it shouldn't be a wiring problem...
                        0_1482936624899_upload-edfa86af-fd0c-4e63-be7b-5393e20f27eb
                        EDIT:
                        !UPDATE!
                        I think I just fixed it. I reconfigured it to include the IRQ Pin and now it's just listening for throughput
                        pi@raspberrypi:~/MySensors $  sudo ./bin/mysgw -d
                        mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.0-beta
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: TSM:INIT:TSP OK
                        mysgw: TSM:INIT:GW MODE
                        mysgw: MCO:REG:NOT NEEDED
                        mysgw: Listening for connections on 0.0.0.0:5003
                        mysgw: MCO:BGN:STP
                        mysgw: MCO:BGN:INIT OK,TSP=1
                        • Flor SandersF
                          Flor SandersF
                          Flor Sanders
                          I got the previous problem out of the way for now...
                          Now onto the next one.
                          I started a node and now I can clearly see data being sent and received on my serial log and ssh. (See picture)
                          0_1482941358792_upload-08fe5f75-3536-4fb5-a0f4-2ee7d0edbc6a
                          So I tried adding the gateway to domoticz using following settings:
                          0_1482941417649_upload-ce92a80a-a5aa-4713-bfe8-227c71b8ce72
                          Yet if I check hardware setup I can see no nodes being presented.
                          0_1482941455435_upload-e36e2fbf-ac80-4381-895d-293e6e638ead
                          Are there settings or steps I missed?
                          Greetings
                          Flor
                          TigroenotT 1 Reply Last reply
                          • Flor SandersF Flor Sanders
                            Greetings
                            Flor
                            TigroenotT
                            TigroenotT
                            Tigroenot
                            @Flor-Sanders I think you maybe should choose not USB but Ethernet gateway in domoticz.
                            • Flor SandersF
                              Flor SandersF
                              Flor Sanders
                              @Tigroenot
                              That fixed it indeed XD
                              Thanks for helping me out
                              • P pettib
                                Hi everyone.
                                Raspberry Pi 3
                                Home Assistant
                                MySensors
                                Tellstick
                                //PeTi
                                marceloaqno
                                Code Contributor
                                @pettib Could it be that you are using an old version of Mosquitto?
                                mosquitto -h
                                Flor SandersF 1 Reply Last reply
                                • M marceloaqno
                                  mosquitto -h
                                  Flor SandersF
                                  Flor SandersF
                                  Flor Sanders
                                  @marceloaqno
                                  How so?
                                  I've tried running the command you've supplied, but it doesn't work... Do I have to install mosquitto?
                                  I didn't see it anywhere in the guide.
                                  Everything is working at the moment, you think it can pose a problem later?
                                  • Robinek70R
                                    Robinek70R
                                    Robinek70
                                    Hello everyone,
                                    I've been working gateway on RPi, but I don't know how to configure MY_SIGNING_SOFT .
                                    File mysgw.cpp contains MY_SIGNING_SOFT definition and I can uncomment it, but I don't know where and how I should define: SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY ?
                                    Could you give more details how to configure soft signing on RPi?
                                    thanks
                                    //Robert
                                    • aandA
                                      aandA
                                      aand
                                      Has anyone successfully built on an Orange Pi One running armbian? RPi running raspbinan is supported, but on my Orange Pi One running armbian I get
                                      ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                                      I already have TMRh20's RF24 code running on this system, so I know it's capable.
                                      • aandA aand
                                        Tag
                                        wrote on last edited by Tag
                                        #179
                                        @aand
                                        working on the same setup, unfortunately was not able to compile the mysensors gateway...
                                        this is the error i get:
                                        root@orangepizero:~/MySensors# make
                                        g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DMY_IS_SERIAL_PTY -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                                        In file included from examples_linux/mysgw.cpp:74:0:
                                        In file included from ./drivers/RF24/RF24.cpp:23:0,
                                        from ./MySensors.h:294,
                                        ./drivers/RF24/RF24.h:52:17: fatal error: SPI.h: No such file or directory
                                        compilation terminated.
                                        Makefile:98: recipe for target 'build/examples_linux/mysgw.o' failed
                                        make: *** [build/examples_linux/mysgw.o] Error 1
                                        seems spi is missing...
                                        however it seems to be available in the system:
                                        root@orangepizero:~/MySensors# ll /dev/spidev0.0
                                        crw------- 1 root root 153, 0 Dec 30 16:26 /dev/spidev0.0
                                        root@orangepizero:~/MySensors# dmesg | grep -i spi
                                        [ 0.814155] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                                        [ 0.814185] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                                        [ 0.815261] spi spi0: master is unqueued, this is deprecated
                                        setup:
                                        Orangepi zero
                                        Armbian
                                        hope that we get native OPI support soon, any way all help is appreciated!!
                                        kind regards,
                                        Tag
                                        jirmJ 1 Reply Last reply
                                        • T Tag
                                          @aand
                                          setup:
                                          Orangepi zero
                                          Armbian
                                          kind regards,
                                          Tag
                                          jirmJ
                                          jirmJ
                                          jirm
                                          @aand said:
                                          Orange Pi One
                                          @aand
                                          I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?
                                          Seems ready state of the nrf24 board is needed in the moment to build/make the compilation of that module for the myGateway.
                                          We have any chance to run any Raspbian version (not armbian) on OPI ?
                                          Sure have so much differences about raspbian and armbian to aply same softw installation methods on both without adaptat in each case.
                                          Im so interesed too for use OPI One like my HA Controller and MQTT Gateway, so will be really good if you can post here any evolution and impressions about using OPI for that.
                                          Cheers
