  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 48.5k Views 38 Watching
  • hekH Offline
    hekH Offline
    wrote on last edited by hek
    This thread contains comments for the article "Air Humidity Sensor - DHT" posted on MySensors.org.
    ramoncarranzaR 2 Replies Last reply
    • rsalmonR Offline
      rsalmonR Offline
      rsalmon
      wrote on last edited by gohan
      bonjour , quel library DHT utilisez vous ? j'ai un probleme de compilation
      Arduino:1.6.10 (Windows 10), Carte : "Arduino Pro or Pro Mini, ATmega328 (3.3V, 8 MHz)"
      ATTENTION . Définition sur : 'Uncategorized'
      air_temp:73: error: no matching function for call to 'DHT::DHT()'
       DHT dht;
      C:\Users\rsalmon\Documents\Arduino\air_temp\air_temp.ino:73:5: note: candidates are:
      In file included from C:\Users\rsalmon\Documents\Arduino\air_temp\air_temp.ino:44:0:
      C:\Users\rsalmon\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.h:40:4: note: DHT::DHT(uint8_t, uint8_t, uint8_t)
          DHT(uint8_t pin, uint8_t type, uint8_t count=6);
      C:\Users\rsalmon\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.h:40:4: note:   candidate expects 3 arguments, 0 provided
      C:\Users\rsalmon\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.h:38:7: note: constexpr DHT::DHT(const DHT&)
       class DHT {
      C:\Users\rsalmon\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.h:38:7: note:   candidate expects 1 argument, 0 provided
      C:\Users\rsalmon\Documents\Arduino\libraries\DHT-sensor-library-master/DHT.h:38:7: note: constexpr DHT::DHT(DHT&&)
      C:\Users\rsalmon\Documents\Arduino\air_temp\air_temp.ino: In function 'void setup()':
      air_temp:91: error: 'class DHT' has no member named 'setup'
      air_temp:92: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
      air_temp:97: error: 'class DHT' has no member named 'getMinimumSamplingPeriod'
      C:\Users\rsalmon\Documents\Arduino\air_temp\air_temp.ino: In function 'void loop()':
      air_temp:104: error: 'class DHT' has no member named 'readSensor'
         dht.readSensor(true);
      air_temp:107: error: 'class DHT' has no member named 'getTemperature'
      air_temp:114: error: 'class DHT' has no member named 'toFahrenheit'
      air_temp:131: error: 'class DHT' has no member named 'getHumidity'
      • rsalmonR rsalmon
         DHT dht;
         class DHT {
        Welcome to the MySensors community, @rsalmon
        You need to use the DHT library included in the MySensors examples. See https://forum.mysensors.org/topic/4672/dht-sketch-version-2-0-0-error-solved/
        Please use english when contributing in the foums, see https://forum.mysensors.org/topic/610/forum-user-guidelines
        • phillipP Offline
          phillipP Offline
          phillip
          has any one been able to fix this error?
          • phillipP phillip
            @phillip yes, by following the instructions given in my post above.
            • carlosC Offline
              carlosC Offline
              carlos
              I was looking for examples on mysensors 2.0 having several sensors in the same node and this sketch looks very iteresting.
              • T Offline
                T Offline
                thomas schneider
                Hi everybody,
                I try to uploaded the sketch on my arduino nano and I have an error with this line :dht.readSensor(true);
                When I delete this line I have no error on the upload but the senosr has no refresh...
                carlosC 1 Reply Last reply
                • T thomas schneider
                  Hi everybody,
                  carlosC Offline
                  carlosC Offline
                  carlos
                  @thomas-schneider
                  Did you see the comments from Mikael?. Do you have the DHT library?.
                  What does the error say?
                  • T Offline
                    T Offline
                    thomas schneider
                    Yes I saw the comments of Mickael. But sorry, I didn't understand how to download the library. Now all is done and ok ! We need to come back and download the entire folder. Why this library is not in mysensors library ? It's not easy for a newbie.
                    Thanks for the support and congratulations for the website.
                    • skywatchS Offline
                      skywatchS Offline
                      skywatch
                      Can anyone please show how to connect more than one DHT with this sketch? What needs changing in the code? (I am OK with the hardware side of things).
                      Once I have an example I can work the rest out but at the moment this bit baffles me! ;)
                      Thank you :)
                      • mikeSM Offline
                        mikeSM Offline
                        mikeS
                        @skywatch
                        I know what you mean, I was having the very same trouble with relay actuators, and that's where your solution lies. There is a sketch that allows you to name the number of relays, and then the sketch automatically names the children, you should be able to modify that, (or at least get an idea of how you have multiples of the same sensor on the same board) to add as many dht's as you have spare digital pins on your arduino. Good luck, hours of fun lies ahead ;)
                        • tianaT Offline
                          tianaT Offline
                          tiana
                          Is exist some way to calibrate DHT sensors? today i make a experiment assemble 5 nodes with 5 DHT11 sensors put all nodes on one table and leave them for some hours, and the result is the every sensor give different values about temperature and humidity + - MAX 5 degree Celsius around the real temperature in the room. Hardware used Arduino Nano X 5pc., HDT11 X 5pc., the power supply is 12V 2,2A enough to power all of the arduinos.
                          • AndurilA Offline
                            AndurilA Offline
                            Anduril
                            @tiana well you could simply calibrate the value you get in your sketch for every DHT on it's own. But you have to do a calibraton, meaning measure all of them at multiple temperatures and humidities.
                            If it's only a offset you can also use
                            #define SENSOR_TEMP_OFFSET 0
                            to correct for this, otherwise you have to implement your calibration function on your own.
                            • tianaT Offline
                              tianaT Offline
                              tiana
                              For some sensors is possible to make with offset, but some of the sensors changing their values 2 times in minute with + - 2 degree Celsius some times show more sometimes show less.
                              • AndurilA Offline
                                AndurilA Offline
                                Anduril
                                well I think this kind of noise can not be calibrated. I thought they all have different values, but with offset, linear oder squared function for deviation.
                                • tianaT Offline
                                  tianaT Offline
                                  tiana
                                  I read datasheet for DHT11 and 2 degree deviation is ok for them. Now i playing with DHT22 I try this #define SENSOR_TEMP_OFFSET -1.3, but nothing is changed the sensor still give me same value.
                                  • tianaT tiana
                                    @tiana try setting SENSOR_TEMP_OFFSET to a really big value, for example -30.8 to make sure that the change is large enough to be noticeable.
                                    • pepsonP Offline
                                      pepsonP Offline
                                      pepson
                                      Where i can found good DHT library for this sketch ?
                                      • pepsonP pepson
                                        @pepson how about the library linked from the build page?
                                        • pepsonP Offline
                                          pepsonP Offline
                                          pepson
                                          sorry i found
