  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • carlosC
    carlosC
    carlos
    I was looking for examples on mysensors 2.0 having several sensors in the same node and this sketch looks very iteresting.
    • T
      thomas schneider
      Hi everybody,
      I try to uploaded the sketch on my arduino nano and I have an error with this line :dht.readSensor(true);
      When I delete this line I have no error on the upload but the senosr has no refresh...
      carlosC 1 Reply Last reply
      • T thomas schneider
        Hi everybody,
        carlosC
        carlosC
        carlos
        @thomas-schneider
        Did you see the comments from Mikael?. Do you have the DHT library?.
        What does the error say?
        • T
          thomas schneider
          Yes I saw the comments of Mickael. But sorry, I didn't understand how to download the library. Now all is done and ok ! We need to come back and download the entire folder. Why this library is not in mysensors library ? It's not easy for a newbie.
          Thanks for the support and congratulations for the website.
          • skywatchS
            skywatchS
            skywatch
            Can anyone please show how to connect more than one DHT with this sketch? What needs changing in the code? (I am OK with the hardware side of things).
            Once I have an example I can work the rest out but at the moment this bit baffles me! ;)
            Thank you :)
            • mikeSM
              mikeSM
              mikeS
              @skywatch
              I know what you mean, I was having the very same trouble with relay actuators, and that's where your solution lies. There is a sketch that allows you to name the number of relays, and then the sketch automatically names the children, you should be able to modify that, (or at least get an idea of how you have multiples of the same sensor on the same board) to add as many dht's as you have spare digital pins on your arduino. Good luck, hours of fun lies ahead ;)
              • tianaT
                tianaT
                tiana
                Is exist some way to calibrate DHT sensors? today i make a experiment assemble 5 nodes with 5 DHT11 sensors put all nodes on one table and leave them for some hours, and the result is the every sensor give different values about temperature and humidity + - MAX 5 degree Celsius around the real temperature in the room. Hardware used Arduino Nano X 5pc., HDT11 X 5pc., the power supply is 12V 2,2A enough to power all of the arduinos.
                • AndurilA
                  AndurilA
                  Anduril
                  @tiana well you could simply calibrate the value you get in your sketch for every DHT on it's own. But you have to do a calibraton, meaning measure all of them at multiple temperatures and humidities.
                  If it's only a offset you can also use
                  #define SENSOR_TEMP_OFFSET 0
                  to correct for this, otherwise you have to implement your calibration function on your own.
                  • tianaT
                    tianaT
                    tiana
                    For some sensors is possible to make with offset, but some of the sensors changing their values 2 times in minute with + - 2 degree Celsius some times show more sometimes show less.
                    • AndurilA
                      AndurilA
                      Anduril
                      well I think this kind of noise can not be calibrated. I thought they all have different values, but with offset, linear oder squared function for deviation.
                      • tianaT
                        tianaT
                        tiana
                        I read datasheet for DHT11 and 2 degree deviation is ok for them. Now i playing with DHT22 I try this #define SENSOR_TEMP_OFFSET -1.3, but nothing is changed the sensor still give me same value.
                        • tianaT tiana
                          @tiana try setting SENSOR_TEMP_OFFSET to a really big value, for example -30.8 to make sure that the change is large enough to be noticeable.
                          • pepsonP
                            pepsonP
                            pepson
                            Where i can found good DHT library for this sketch ?
                            • pepsonP pepson
                              @pepson how about the library linked from the build page?
                              • pepsonP
                                pepsonP
                                pepson
                                sorry i found
                                • Jim DanforthJ
                                  Jim DanforthJ
                                  Jim Danforth
                                  Using library linked above
                                  Getting: no matching function for call to 'DHT::readSensor(bool)'
                                    This thread contains comments for the article "Air Humidity Sensor - DHT" posted on MySensors.org.
                                    ramoncarranzaR
                                    ramoncarranzaR
                                    ramoncarranza
                                    @hek
                                    hi, how do I change the readings from C to F?
                                    My sensor works fine, by I get the readings I celsius
                                    mikeSM 1 Reply Last reply
                                    • ramoncarranzaR ramoncarranza
                                      @hek
                                      mikeSM
                                      mikeSM
                                      mikeS
                                      @ramoncarranza
                                      Change the line in the sketch:
                                      to
                                      temperature = dht.toCelsius(temperature);
                                      probably? I haven't checked it, just looked at the DHT library. You may need to comment the isMetric line earlier in the sketch too. But I think that's how you do it.
                                      ramoncarranzaR 1 Reply Last reply
                                      • mikeSM mikeS
                                        @ramoncarranza
                                        to
                                        ramoncarranzaR
                                        ramoncarranzaR
                                        ramoncarranza
                                        @mikeS Thanks so much for your reply, it's working perfectly now.
                                        • meanmrgreenM
                                          meanmrgreenM
                                          meanmrgreen
                                          @Jim Danforth
                                          Getting the same, have tried a number of different DHT libraries and cant get it to compile.
