  2. Announcements
  3. 💬 Air Humidity Sensor - DHT
149 Posts 48 Posters 104.1k Views 38 Watching
  • skywatchS
    skywatchS
    skywatch
    Can anyone please show how to connect more than one DHT with this sketch? What needs changing in the code? (I am OK with the hardware side of things).
    Once I have an example I can work the rest out but at the moment this bit baffles me! ;)
    Thank you :)
    • mikeSM
      mikeSM
      mikeS
      @skywatch
      I know what you mean, I was having the very same trouble with relay actuators, and that's where your solution lies. There is a sketch that allows you to name the number of relays, and then the sketch automatically names the children, you should be able to modify that, (or at least get an idea of how you have multiples of the same sensor on the same board) to add as many dht's as you have spare digital pins on your arduino. Good luck, hours of fun lies ahead ;)
      • tianaT
        tianaT
        tiana
        Is exist some way to calibrate DHT sensors? today i make a experiment assemble 5 nodes with 5 DHT11 sensors put all nodes on one table and leave them for some hours, and the result is the every sensor give different values about temperature and humidity + - MAX 5 degree Celsius around the real temperature in the room. Hardware used Arduino Nano X 5pc., HDT11 X 5pc., the power supply is 12V 2,2A enough to power all of the arduinos.
        • AndurilA
          AndurilA
          Anduril
          @tiana well you could simply calibrate the value you get in your sketch for every DHT on it's own. But you have to do a calibraton, meaning measure all of them at multiple temperatures and humidities.
          If it's only a offset you can also use
          #define SENSOR_TEMP_OFFSET 0
          to correct for this, otherwise you have to implement your calibration function on your own.
          • tianaT
            tianaT
            tiana
            For some sensors is possible to make with offset, but some of the sensors changing their values 2 times in minute with + - 2 degree Celsius some times show more sometimes show less.
            • AndurilA
              AndurilA
              Anduril
              well I think this kind of noise can not be calibrated. I thought they all have different values, but with offset, linear oder squared function for deviation.
              • tianaT
                tianaT
                tiana
                I read datasheet for DHT11 and 2 degree deviation is ok for them. Now i playing with DHT22 I try this #define SENSOR_TEMP_OFFSET -1.3, but nothing is changed the sensor still give me same value.
                • tianaT tiana
                  @tiana try setting SENSOR_TEMP_OFFSET to a really big value, for example -30.8 to make sure that the change is large enough to be noticeable.
                  • pepsonP
                    pepsonP
                    pepson
                    Where i can found good DHT library for this sketch ?
                    • pepsonP pepson
                      @pepson how about the library linked from the build page?
                      • pepsonP
                        pepsonP
                        pepson
                        sorry i found
                        • Jim DanforthJ
                          Jim DanforthJ
                          Jim Danforth
                          Using library linked above
                          Getting: no matching function for call to 'DHT::readSensor(bool)'
                            This thread contains comments for the article "Air Humidity Sensor - DHT" posted on MySensors.org.
                            ramoncarranzaR
                            ramoncarranzaR
                            ramoncarranza
                            @hek
                            hi, how do I change the readings from C to F?
                            My sensor works fine, by I get the readings I celsius
                            mikeSM 1 Reply Last reply
                            • ramoncarranzaR ramoncarranza
                              @hek
                              mikeSM
                              mikeSM
                              mikeS
                              @ramoncarranza
                              Change the line in the sketch:
                              to
                              temperature = dht.toCelsius(temperature);
                              probably? I haven't checked it, just looked at the DHT library. You may need to comment the isMetric line earlier in the sketch too. But I think that's how you do it.
                              ramoncarranzaR 1 Reply Last reply
                              • mikeSM mikeS
                                @ramoncarranza
                                to
                                ramoncarranzaR
                                ramoncarranzaR
                                ramoncarranza
                                @mikeS Thanks so much for your reply, it's working perfectly now.
                                • meanmrgreenM
                                  meanmrgreenM
                                  meanmrgreen
                                  @Jim Danforth
                                  Getting the same, have tried a number of different DHT libraries and cant get it to compile.
                                  • mikeSM
                                    mikeSM
                                    mikeS
                                    @meanmrgreen The only DHT library that will work is the one from the link before the sketch. If you have used others chances are you need to move or rename those other DHT libraries as that is why the sketch cannot call that function.
                                    meanmrgreenM 1 Reply Last reply
                                    • mikeSM mikeS
                                      meanmrgreenM
                                      meanmrgreenM
                                      meanmrgreen
                                      @mikeS
                                      Ive tried to reinstall and start från scratch but i guess i Missed something.
                                      • mikeSM
                                        mikeSM
                                        mikeS
                                        @meanmrgreen sometimes windows puts libraries in your documents folder, so they may be located in 2 or more places. Use windows search to find them all. I have 3 DHT libraries, the mysensors one, the adafruit(I think) and another that came with an MQTT based sketch for an ESP board. I just rename them. Incidentally the mysensors DHT library gives me the most accurate results, as much as 2 degrees and 10% out on the same sensor using a different library.
                                        Also don't update the DHT library if you are told there is an update!
                                        As you can tell I had a few problems myself before I got this working, it almost made me disregard the whole project. Keep trying , it's worth it.
                                        • mikeSM mikeS
                                          meanmrgreenM
                                          meanmrgreenM
                                          meanmrgreen
                                          @mikeS thanks alot!
                                          I'll keep that in mind. Should be getting my "starter kit" order soon from eBay so we'll see how it goes ;)
