  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.1k Views 19 Watching
  • James FlosseJ
    James FlosseJ
    James Flosse
    The pressure and temperature is incorrect xD. sorry, i have 20°C in my room and the METAR of the near airport say 1016 hPa.
    • James FlosseJ James Flosse
      @James-Flosse thanks :)
      Strange problem. Is the bmp getting stable power? Maybe it is defective? You don't happen to have another bmp to compare with?
      • James FlosseJ
        James FlosseJ
        James Flosse
        Only bmp180 connected to arduino and i have test with 3 other :s
        • ghislainG
          ghislainG
          ghislain
          wrote on last edited by ghislain
          #24
          Hi, i'm using this sketch and I had to modify it a little bit. But i'm at work and i haven't it.
          You defined the altitude to 688 meters in you sketch, are you sure, you said you're at 1014mbars. If you're really at 700m you should be near 930mbars not 1014mbars.
          • James FlosseJ
            James FlosseJ
            James Flosse
            Ok i defined the altitude by my own (225 meters) but i have the same pressure and temperature :S
            • ghislainG
              ghislainG
              ghislain
              Too bad, can you upload a basic example sketch in the library adafruit to read pressure and temperature, just to be sure there is the same behavior.
              • James FlosseJ
                James FlosseJ
                James Flosse
                #include <Wire.h>
                #include <Adafruit_Sensor.h>
                #include <Adafruit_BMP085_U.h>
                Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
                void setup(void)
                  Serial.begin(9600);
                  Serial.println("Pressure Sensor Test"); Serial.println("");
                  /* Initialise the sensor */
                  if(!bmp.begin())
                    /* There was a problem detecting the BMP085 ... check your connections */
                    Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
                    while(1);
                void loop(void)
                  /* Get a new sensor event */
                  sensors_event_t event;
                  bmp.getEvent(&event);
                  /* Display the results (barometric pressure is measure in hPa) */
                  if (event.pressure)
                    /* Display atmospheric pressure in hPa */
                    Serial.print("Pressure: "); Serial.print(event.pressure); Serial.println(" hPa");
                  else
                    Serial.println("Sensor error");
                  delay(250);
                Pressure: 756.46 hPa
                Pressure: 756.47 hPa
                Pressure: 756.49 hPa
                Pressure: 756.44 hPa
                Pressure: 756.41 hPa
                Pressure: 756.42 hPa
                Pressure: 756.39 hPa
                Pressure: 756.38 hPa
                Pressure: 756.40 hPa
                Pressure: 756.34 hPa
                Pressure: 756.22 hPa
                Pressure: 756.33 hPa
                Pressure: 756.37 hPa
                same pressure
                • ghislainG
                  ghislainG
                  ghislain
                  Where did you buy your bmp180 ? you said the 3 you have make the same behavior ? something is wrong with the BMP sensor.
                  • James FlosseJ
                    James FlosseJ
                    James Flosse
                    I bought it in banggood, but it work's before...
                    • ghislainG
                      ghislainG
                      ghislain
                      It worked for a while and now it doesn't ? no problem of power supply ? 3v3 ?
                      • James FlosseJ
                        James FlosseJ
                        James Flosse
                        I supply itwith the 3.3 V output off arduino
                        • ghislainG
                          ghislainG
                          ghislain
                          I supply it with 5v, are you sure it's a 3v3 version ?
                          • James FlosseJ
                            James FlosseJ
                            James Flosse
                            wrote on last edited by James Flosse
                            #33
                            i tested with 3.3V and 5volt but same result
                            http://www.banggood.com/fr/GY-68-BMP180-Digital-Barometric-Pressure-Sensor-Board-Module-p-1059025.html?rmmds=myorder
                            • ghislainG
                              ghislainG
                              ghislain
                              OK, i've no further idea to help you. But i think your sensor is dead. DId you try older or newer library to compile your project ?
                              • James FlosseJ
                                James FlosseJ
                                James Flosse
                                Have you link for older library? Are you french?
                                • ghislainG
                                  ghislainG
                                  ghislain
                                  I am and you ? I can give you the sketch which is working for me with library i used.
                                  • James FlosseJ
                                    James FlosseJ
                                    James Flosse
                                    Yes ^^ . can you give me at snyp_thx at hotmail dot fr?
                                    • bgunnarbB
                                      bgunnarbB
                                      bgunnarb
                                      Hi!
                                      I had exactly the same problem until I realised I had compiled for the 8 MHz version of the Arduino Pro Mini instead of the 16 MHz version.
                                      Also, recently building an humidity sensor I realised there are no pull-up resistors on the SDA SDL lines, but that should be built-in if you use a break-out module.
                                      I have never been so busy since I retired!
                                      • HeinzH
                                        HeinzH
                                        Heinz
                                        Which altitude did you enter, or at which sealevel do you live (in meters)?
                                        const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
                                        The pressure of 728 hPa is a bit strange as it should be around 1000 hPa. In my eyes you threw out the code to correct the pressure depending on the sealevel of your home. See the code from my sketch:
                                        float pressure = bmp.seaLevelForAltitude(SEALEVEL, absolutePressure);
                                        Here you can download the sketch I am using:
                                        https://github.com/windkh/mysensors/blob/master/WeatherStationSensor/WeatherStationSensor.ino
                                        The forecast will be unknown for at least 30minutes, because the sensor needs that time to detect a weather trend.
                                        • James FlosseJ
                                          James FlosseJ
                                          James Flosse
                                          @bgunnarb you are find the problem, i think i have arduino pro mini 3.3V but it's 5V. Thx very much it's work better now :)
