  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.7k Views 19 Watching
  • ghislainG
    ghislainG
    ghislain
    It worked for a while and now it doesn't ? no problem of power supply ? 3v3 ?
    • James FlosseJ
      James FlosseJ
      James Flosse
      I supply itwith the 3.3 V output off arduino
      • ghislainG
        ghislainG
        ghislain
        I supply it with 5v, are you sure it's a 3v3 version ?
        • James FlosseJ
          James FlosseJ
          James Flosse
          wrote on last edited by James Flosse
          #33
          i tested with 3.3V and 5volt but same result
          http://www.banggood.com/fr/GY-68-BMP180-Digital-Barometric-Pressure-Sensor-Board-Module-p-1059025.html?rmmds=myorder
          • ghislainG
            ghislainG
            ghislain
            OK, i've no further idea to help you. But i think your sensor is dead. DId you try older or newer library to compile your project ?
            • James FlosseJ
              James FlosseJ
              James Flosse
              Have you link for older library? Are you french?
              • ghislainG
                ghislainG
                ghislain
                I am and you ? I can give you the sketch which is working for me with library i used.
                • James FlosseJ
                  James FlosseJ
                  James Flosse
                  Yes ^^ . can you give me at snyp_thx at hotmail dot fr?
                  • bgunnarbB
                    bgunnarbB
                    bgunnarb
                    Hi!
                    I had exactly the same problem until I realised I had compiled for the 8 MHz version of the Arduino Pro Mini instead of the 16 MHz version.
                    Also, recently building an humidity sensor I realised there are no pull-up resistors on the SDA SDL lines, but that should be built-in if you use a break-out module.
                    I have never been so busy since I retired!
                    • HeinzH
                      HeinzH
                      Heinz
                      Which altitude did you enter, or at which sealevel do you live (in meters)?
                      const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
                      The pressure of 728 hPa is a bit strange as it should be around 1000 hPa. In my eyes you threw out the code to correct the pressure depending on the sealevel of your home. See the code from my sketch:
                      float pressure = bmp.seaLevelForAltitude(SEALEVEL, absolutePressure);
                      Here you can download the sketch I am using:
                      https://github.com/windkh/mysensors/blob/master/WeatherStationSensor/WeatherStationSensor.ino
                      The forecast will be unknown for at least 30minutes, because the sensor needs that time to detect a weather trend.
                      • James FlosseJ
                        James FlosseJ
                        James Flosse
                        @bgunnarb you are find the problem, i think i have arduino pro mini 3.3V but it's 5V. Thx very much it's work better now :)
                        • Jeff WilleckeJ
                          Jeff WilleckeJ
                          Jeff Willecke
                          Where do the pin assignments live?
                          gohanG 1 Reply Last reply
                          • Jeff WilleckeJ Jeff Willecke
                            @Jeff-Willecke
                            in the article page
                            SCL A5 (analog input) Marked blue
                            SDA A4 (analog input) Marked green
                            • Jeff WilleckeJ
                              Jeff WilleckeJ
                              Jeff Willecke
                              @gohan it appears as though I need SLC and SDA for the sensor it will prevent me from using a second SLC/SDA device. I was assuming that they were utilizing the analog input. My comment may be deleted as it is clearly not applicable
                                that is I2C bus, you can collect multiple devices as long as they have different addresses
                                • Jeff WilleckeJ
                                  Jeff WilleckeJ
                                  Jeff Willecke
                                  OH cool. I guess I have tons more to learn thank you for your help
                                  • skywatchS
                                    skywatchS
                                    skywatch
                                    The initial description on this page refers to BMP085.
                                    The 'Example' states it is for BMP085 with Adafruit library (linked for dowbload).
                                    The sketch uses a BME280 with library from Embedded Adventures.
                                    The Datasheet is linked for a BMP085.
                                    The shopping guide links to a BMP180.
                                    • skywatchS skywatch
                                      Sorry for not noticing your post earlier @skywatch
                                      The example was originally designed for BMP085. When the BMP180 became widely available, the buy link was updated to the newer version with the note "replaces the old BMP085". Both use the same library.
                                      At a later stage, a MySensors user suggested changes to the example sketch to use the BME sensor instead. I don't know why this change was made, but my guess is that the user liked the BME sensor better. I don't know why the change was accepted without updating the build page, but my guess is that since the commit doesn't mention the change of sensor and the amount of code changed is quite large (369 additions and 252 deletions) nobody noticed that a new sensor was used.
                                      I'm trying to address the sensor change in https://forum.mysensors.org/topic/9801/bmp-e-atmospheric-pressure
                                        Mark Hansen
                                        wrote on last edited by Mark Hansen
                                        #48
                                        Heads-up: I've observed my sensor trying to sleep for 4 billion ms when running the sample code:
                                        60082 MCO:SLP:MS=4294967214,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        That's 2^32-82. So I think there's an underflow with this line:
                                        unsigned long sleeptime = BME280measurementSleepTime - (quicktimecheck - previousBME280Millis);
                                        Not sure where exactly though. I've changed my code to simply sleep for a constant 60s.
                                          G
                                          G
                                          grumpazoid
                                          wrote on last edited by grumpazoid
                                          #49
                                          @mfalkvidd I've just started to look into this sensor and the main page is still quite confusing as already stated by @skywatch
                                          It seems the choice at present is between the BMP280 or BME280. the latter also includes humidity.
                                          Maybe the title could say Temperature/Pressure/Humidity? I just ordered a replacement Si7021, not realising there was another all in one sensor available.
                                          It is clear that most ebay sellers are also confused and are wrongly listing BMP devices as BME.
                                          I found a good summary to the confusion here https://goughlui.com/2018/08/05/note-bosch-sensortec-bmp280-vs-bme280-sensor-confusion/
                                          Hope this helps someone - Think I'll be going for a BME280 here as it as some positive reviews https://www.ebay.co.uk/itm/Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-Module/401513062540
                                          Raspberry Pi 3B - Domoticz + Node Red
                                          Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
                                          Arduino Mega, RFLink 433Mhz
                                          Sonoff/ESP8266/Tasmota switches
