  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.7k Views 19 Watching
    wrote on last edited by hek
    This thread contains comments for the article "Atmospheric Pressure Sensor" posted on MySensors.org.
    • NoobduinoN
      NoobduinoN
      Noobduino
      Just a small heads-up... Using the BMP180 ordered from the linked AliExpress shop I was getting no data until I realized the SDA SDL pins on my board were incorrectly marked. Swapping them fixed the issue.
        Oh, my... Thanks for the heads up.
        • K
          K
          kramer
          Just so people are aware, the variable "ALTITUDE" should be in units of meters (according to Adafruit's BMP library).
          • K
            K
            ksga
            Anybody feeling like adopting this to the BME280 and including temperature and humidity readings?? Low cost single chip and power usage looks fairly low...
            F 1 Reply Last reply
            • K ksga
              F
              F
              flopp
              wrote on last edited by flopp
              @ksga
              I think I will do that. It seems to be able to run it from 1.8V to 5V.
              Now BME280 is cheaper than it was 1 year ago, i think.
              http://www.ebay.com/itm/I2C-SPI-Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-/272267632353?hash=item3f646a5ee1:g:07oAAOSwnFZXV9L2
              K 1 Reply Last reply
              • F flopp
                @ksga
                K
                K
                ksga
                @flopp
                That would be awesome. I have one in the mail and are trying to get things ready 😀
                It will replace my SI7021 on my solar powered node...
                • E
                  E
                  emc2
                  BME280 is quite nice. I got one last year that I added to my gateway and it worked flawlessly since then.
                  If you remove the gateway/esp8266 top part you should be able to directly use code from https://github.com/emc2cube/MyWeatherGatewayESP8266 (which was updated from this one anyway)
                  • HeinzH
                    HeinzH
                    Heinz
                    I just ordered one at ebay...
                    Nice to see that other weatherstations make use of this code.
                    • Luc3asL
                      Luc3asL
                      Luc3as
                      I tried to modify the weather forecast script to run each 5 minutes instead of every minute but now I am getting strange forecasts and sometimes unknown conditions.
                      Doesn't anybody tried to accomplish this ?
                      D 1 Reply Last reply
                      • boblasureB
                        boblasureB
                        boblasure
                        So I added the My Sensors board file, added the my sensors libary through library manager, coped the adafruit library and tried to compile. Arduino: 1.8.1 (Windows 8.1), Board: "Arduino Mini, ATmega328"
                        C:\Users\eddy\Documents\Arduino\bmpTest\bmpTest.ino: In function 'void setup()':
                        bmpTest:95: error: 'getConfig' was not declared in this scope
                         metric = getConfig().isMetric;
                        exit status 1
                        option enabled in File -> Preferences.
                        Did I miss something?
                        • boblasureB
                          boblasureB
                          boblasure
                          Okay, I changed the library to version 2.0.0 and it now compiles.
                          • boblasureB boblasure
                            @boblasure I am not sure why, but the name of getConfig was changed. See https://forum.mysensors.org/topic/5841/getconfig-was-not-declared-in-this-scope-v2-1-1-fixed/ if you want to upgrade to 2.1.1 again.
                            • Luc3asL Luc3as
                              D
                              D
                              DavidZH
                              @Luc3as
                              The forecast script is meant to be running every minute to collect the averaging data. If you run it every 5 minutes, you need to change the dividers in the script to come to a hPa/h value that actually makes sense.
                              • ghislainG
                                ghislainG
                                ghislain
                                i've got a problem, pressure always stay to 1013 mbar and i'm at 350m of altitude. Something is wrong but what ? I test the BMP180 alone and it said the good value.
                                • ghislainG
                                  ghislainG
                                  ghislain
                                  wrote on last edited by ghislain
                                  I found some problems in code. I did make some change to be able to get value. I replace "float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;" by "float pressure = bmp.readPressure() / 100 ;"
                                  I'll make a PR on GitHub when everything will be well tested. :)
                                  • James FlosseJ
                                    James FlosseJ
                                    James Flosse
                                    Hi, i've a problem with the bmp180 with domoticz. I use raspberry pi with domoticz and mysensor v2 and nrf24 on gpio, i receive data but i think is wrong. The temperature is 31°C and pressure is 728. I put my altitude in the sketch.
                                    Can you help me?
                                    Best regards.
                                    • James FlosseJ James Flosse
                                      Can you help me?
                                      Best regards.
                                      Welcome to the MySensors community @James-Flosse !
                                      Could you post your sketch and debug output from the node and the gateway?
                                      If you haven't looked at it already, https://www.mysensors.org/build/debug#enabling-debug-logging has information on how to enable debug logging.
                                      • James FlosseJ
                                        James FlosseJ
                                        James Flosse
                                        wrote on last edited by James Flosse
                                        Hi @mfalkvidd. This is the debug output and my code
                                        2269 MCO:REG:REQ
                                        2277 TSF:MSG:SEND,3-3-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                        2287 TSF:MSG:READ,0-0-3,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        2293 MCO:PIM:NODE REG=1
                                        2295 MCO:BGN:STP
                                        2306 MCO:BGN:INIT OK,TSP=1
                                        Forecast at minute 1 dP/dt = 0.00kPa/h --> unknown
                                        Temperature = 31.00 *C
                                        Pressure = 728.00 hPa
                                        Forecast = unknown
                                        2359 TSF:MSG:SEND,3-3-0-0,s=1,c=1,t=0,pt=7,l=5,sg=0,ft=0,st=OK:31.0
                                        2369 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=4,pt=7,l=5,sg=0,ft=0,st=OK:728
                                        2381 TSF:MSG:SEND,3-3-0-0,s=0,c=1,t=5,pt=0,l=7,sg=0,ft=0,st=OK:unknown
                                        2387 MCO:SLP:MS=60000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                        2394 MCO:SLP:TPD
                                        #include <Wire.h>
                                        #include <Adafruit_BMP085.h>
                                        #define BARO_CHILD 0
                                        #define TEMP_CHILD 1
                                        const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
                                        // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
                                        const unsigned long SLEEP_TIME = 60000;
                                        const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                                        enum FORECAST
                                            STABLE = 0,            // "Stable Weather Pattern"
                                            SUNNY = 1,            // "Slowly rising Good Weather", "Clear/Sunny "
                                            CLOUDY = 2,            // "Slowly falling L-Pressure ", "Cloudy/Rain "
                                            UNSTABLE = 3,        // "Quickly rising H-Press",     "Not Stable"
                                            THUNDERSTORM = 4,    // "Quickly falling L-Press",    "Thunderstorm"
                                            UNKNOWN = 5            // "Unknown (More Time needed)
                                        Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
                                        float lastPressure = -1;
                                        float lastTemp = -1;
                                        int lastForecast = -1;
                                        const int LAST_SAMPLES_COUNT = 5;
                                        float lastPressureSamples[LAST_SAMPLES_COUNT];
                                        // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
                                        // get kPa/h be dividing hPa by 10
                                        #define CONVERSION_FACTOR (1.0/10.0)
                                        int minuteCount = 0;
                                        bool firstRound = true;
                                        // average value is used in forecast algorithm.
                                        float pressureAvg;
                                        // average after 2 hours is used as reference value for the next iteration.
                                        float pressureAvg2;
                                        float dP_dt;
                                        bool metric;
                                        MyMessage tempMsg(TEMP_CHILD, V_TEMP);
                                        MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
                                        MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
                                            if (!bmp.begin())
                                                Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                                                while (1) {}
                                        void presentation()  {
                                          sendSketchInfo("Pressure Sensor", "1.1");
                                          // Register sensors to gw (they will be created as child devices)
                                          present(BARO_CHILD, S_BARO);
                                          present(TEMP_CHILD, S_TEMP);
                                            float temperature = bmp.readTemperature();
                                            if (!metric)
                                                // Convert to fahrenheit
                                                temperature = temperature * 9.0 / 5.0 + 32.0;
                                            int forecast = sample(pressure);
                                            Serial.print("Temperature = ");
                                            Serial.print(temperature);
                                            Serial.println(metric ? " *C" : " *F");
                                            Serial.print("Pressure = ");
                                            Serial.print(pressure);
                                            Serial.println(" hPa");
                                            Serial.print("Forecast = ");
                                            Serial.println(weather[forecast]);
                                            if (temperature != lastTemp)
                                                send(tempMsg.set(temperature, 1));
                                                lastTemp = temperature;
                                            if (pressure != lastPressure)
                                                send(pressureMsg.set(pressure, 0));
                                                lastPressure = pressure;
                                            if (forecast != lastForecast)
                                                send(forecastMsg.set(weather[forecast]));
                                                lastForecast = forecast;
                                            sleep(SLEEP_TIME);
                                        float getLastPressureSamplesAverage()
                                            float lastPressureSamplesAverage = 0;
                                            for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                                                lastPressureSamplesAverage += lastPressureSamples[i];
                                            lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                                            return lastPressureSamplesAverage;
                                        // Algorithm found here
                                        // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
                                        // Pressure in hPa -->  forecast done by calculating kPa/h
                                        int sample(float pressure)
                                            // Calculate the average of the last n minutes.
                                            int index = minuteCount % LAST_SAMPLES_COUNT;
                                            lastPressureSamples[index] = pressure;
                                            minuteCount++;
                                            if (minuteCount > 185)
                                                minuteCount = 6;
                                            if (minuteCount == 5)
                                                pressureAvg = getLastPressureSamplesAverage();
                                            else if (minuteCount == 35)
                                                float lastPressureAvg = getLastPressureSamplesAverage();
                                                float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                                                if (firstRound) // first time initial 3 hour
                                                    dP_dt = change * 2; // note this is for t = 0.5hour
                                                else
                                                    dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                                            else if (minuteCount == 65)
                                                if (firstRound) //first time initial 3 hour
                                                    dP_dt = change; //note this is for t = 1 hour
                                                else
                                                    dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                                            else if (minuteCount == 95)
                                                    dP_dt = change / 1.5; // note this is for t = 1.5 hour
                                                else
                                                    dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                                            else if (minuteCount == 125)
                                                pressureAvg2 = lastPressureAvg; // store for later use.
                                                    dP_dt = change / 2; // note this is for t = 2 hour
                                                else
                                                    dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                                            else if (minuteCount == 155)
                                                    dP_dt = change / 2.5; // note this is for t = 2.5 hour
                                                else
                                                    dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                                            else if (minuteCount == 185)
                                                    dP_dt = change / 3; // note this is for t = 3 hour
                                                else
                                                    dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                                                pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                                                firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
                                            int forecast = UNKNOWN;
                                            if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
                                                forecast = UNKNOWN;
                                            else if (dP_dt < (-0.25))
                                                forecast = THUNDERSTORM;
                                            else if (dP_dt > 0.25)
                                                forecast = UNSTABLE;
                                            else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
                                                forecast = CLOUDY;
                                            else if ((dP_dt > 0.05) && (dP_dt < 0.25))
                                                forecast = SUNNY;
                                            else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                                                forecast = STABLE;
                                            else
                                                forecast = UNKNOWN;
                                            // uncomment when debugging
                                            Serial.print(F("Forecast at minute "));
                                            Serial.print(minuteCount);
                                            Serial.print(F(" dP/dt = "));
                                            Serial.print(dP_dt);
                                            Serial.print(F("kPa/h --> "));
                                            return forecast;
                                        2017-03-09 10:52:56.474 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 10:52:56.475 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 10:52:56.488 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:52:56.497 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:52:56.503 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:53:40.053 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 10:53:40.054 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 10:53:40.067 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:53:40.075 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:53:40.081 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:14.102 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 10:54:14.104 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 10:54:14.148 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:54:14.162 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:14.172 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:26.662 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 10:54:26.664 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 10:54:26.676 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:54:26.685 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:26.691 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:44.122 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 10:54:44.123 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 10:54:44.136 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:54:44.145 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:44.150 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:50.417 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 10:54:51.225 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 10:54:51.227 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:54:51.236 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:54:51.242 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:55:55.513 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:58:05.600 (GATEWAY) Temp (Temp)
                                        2017-03-09 10:58:05.608 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 10:59:10.651 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:01:20.704 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:02:00.701 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 11:02:00.702 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 11:02:00.715 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:02:00.723 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:00.728 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:31.650 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 11:02:31.652 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 11:02:31.664 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:02:31.673 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:31.678 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:38.872 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 11:02:38.873 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 11:02:38.886 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:02:38.894 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:38.900 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:41.863 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 11:02:41.864 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 11:02:41.887 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:02:41.895 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:41.901 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:49.208 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 11:02:49.209 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 11:02:49.232 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:02:49.240 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:02:49.245 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:03:54.286 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:04:59.319 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:06:04.359 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:06:04.368 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:06:36.109 MySensors: Node: 3, Sketch Name: Pressure Sensor
                                        2017-03-09 11:06:36.111 MySensors: Node: 3, Sketch Version: 1.1
                                        2017-03-09 11:06:36.123 (GATEWAY) Temp (Temp)
                                        2017-03-09 11:06:36.132 (GATEWAY) General/Barometer (Baro)
                                        2017-03-09 11:06:36.137 (GATEWAY) General/Barometer (Baro)
                                          The node sends the data received from the bmp180, so everything seems to be correct. Could you clarify what you expected?
