  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.1k Views 19 Watching
  • Jeff WilleckeJ
    Jeff WilleckeJ
    Jeff Willecke
    Where do the pin assignments live?
    gohanG 1 Reply Last reply
    • Jeff WilleckeJ Jeff Willecke
      @Jeff-Willecke
      in the article page
      SCL A5 (analog input) Marked blue
      SDA A4 (analog input) Marked green
      • Jeff WilleckeJ
        Jeff WilleckeJ
        Jeff Willecke
        @gohan it appears as though I need SLC and SDA for the sensor it will prevent me from using a second SLC/SDA device. I was assuming that they were utilizing the analog input. My comment may be deleted as it is clearly not applicable
          that is I2C bus, you can collect multiple devices as long as they have different addresses
          • Jeff WilleckeJ
            Jeff WilleckeJ
            Jeff Willecke
            OH cool. I guess I have tons more to learn thank you for your help
            • skywatchS
              skywatchS
              skywatch
              The initial description on this page refers to BMP085.
              The 'Example' states it is for BMP085 with Adafruit library (linked for dowbload).
              The sketch uses a BME280 with library from Embedded Adventures.
              The Datasheet is linked for a BMP085.
              The shopping guide links to a BMP180.
              • skywatchS skywatch
                Sorry for not noticing your post earlier @skywatch
                The example was originally designed for BMP085. When the BMP180 became widely available, the buy link was updated to the newer version with the note "replaces the old BMP085". Both use the same library.
                At a later stage, a MySensors user suggested changes to the example sketch to use the BME sensor instead. I don't know why this change was made, but my guess is that the user liked the BME sensor better. I don't know why the change was accepted without updating the build page, but my guess is that since the commit doesn't mention the change of sensor and the amount of code changed is quite large (369 additions and 252 deletions) nobody noticed that a new sensor was used.
                I'm trying to address the sensor change in https://forum.mysensors.org/topic/9801/bmp-e-atmospheric-pressure
                  Mark Hansen
                  wrote on last edited by Mark Hansen
                  #48
                  Heads-up: I've observed my sensor trying to sleep for 4 billion ms when running the sample code:
                  60082 MCO:SLP:MS=4294967214,SMS=0,I1=255,M1=255,I2=255,M2=255
                  That's 2^32-82. So I think there's an underflow with this line:
                  unsigned long sleeptime = BME280measurementSleepTime - (quicktimecheck - previousBME280Millis);
                  Not sure where exactly though. I've changed my code to simply sleep for a constant 60s.
                    G
                    G
                    grumpazoid
                    wrote on last edited by grumpazoid
                    #49
                    @mfalkvidd I've just started to look into this sensor and the main page is still quite confusing as already stated by @skywatch
                    It seems the choice at present is between the BMP280 or BME280. the latter also includes humidity.
                    Maybe the title could say Temperature/Pressure/Humidity? I just ordered a replacement Si7021, not realising there was another all in one sensor available.
                    It is clear that most ebay sellers are also confused and are wrongly listing BMP devices as BME.
                    I found a good summary to the confusion here https://goughlui.com/2018/08/05/note-bosch-sensortec-bmp280-vs-bme280-sensor-confusion/
                    Hope this helps someone - Think I'll be going for a BME280 here as it as some positive reviews https://www.ebay.co.uk/itm/Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-Module/401513062540
                    Raspberry Pi 3B - Domoticz + Node Red
                    Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
                    Arduino Mega, RFLink 433Mhz
                    Sonoff/ESP8266/Tasmota switches
                    • G
                      G
                      grumpazoid
                      I have now had my delivery of the above ebay sensor. Everything looks good. It is a BME280 and reports temp, humidity and pressure.
                      I have used the sketch on the build page and it has worked without any editing. I just had to install the BME280 library as given in the example sketch. Everything is shown nicely in Domoticz.
                      Interesting to note that when compiling in arduino IDE I get the following error : Low memory available, stability problems may occur.
                      Wonder if there will be enough room to add my battery level monitoring code?
                      • G grumpazoid
                        @grumpazoid If you don't use the forecast feature, remove #define GENERATE_FORECAST. Doing that should give you much less ram usage.
                        • G
                          G
                          grumpazoid
                          @mfalkvidd Thanks for that. This is going to be my outside weather node running off a 12V solar charged battery. I started wi a DHT22 but it failed after a few months.
                          • G
                            G
                            grumpazoid
                            @mfalkvidd I've got it up and running now on the bench complete with measuring voltage. I found that removing all the serial print statements also free up a lot of memory. Thanks to all those involved for the provided code.
                            • I
                              I
                              Iliah Borg
                              When using BME280 breakout https://lowpowerlab.com/shop/product/185 with Embedded Adventures library, life is easier if addrBME280 is set to 0x77 (it is set to 0x76 in BME280_MOD-1022.h)
                              • F
                                F
                                Fear na Boinne
                                Weird question, but has anyone dealt with thermal isolation of the BMPx8x modules?
                                To increase the WAF, I have one, together with a BH1750 and an rf-nano in a small, aesthetically pleasing, 3D printed custom housing. However, the temperature is stuck at 26.2°C, which I assume is due to the radiant heat from (mostly) the Arduino and the nRF24L01+
                                So I am looking for ways to keep the BMPx8x cooler, so it can correctly measure the temperature (and therefore also the pressure, as the warmer chip means the barometric adjustment will be off)...
                                mfalkviddM BearWithBeardB 2 Replies Last reply
                                • F Fear na Boinne
                                  @Fear-na-Boinne how about calling sleep() between measurements? That will pus the Arduino and the nrf24 in sleep mode, where they won't generate heat.
                                  F 1 Reply Last reply
                                    F
                                    F
                                    Fear na Boinne
                                    @mfalkvidd Didn't think of that... I can try changing the delay() to a sleep() and see how much that impacts the temperature...
                                    (But I still am open to ideas to help insulate the sensor, and am now also wondering whether creating extra vent holes on both sides of the rf-nano might be a good idea, even if it means more dust can come in as well...)
                                    • F Fear na Boinne
                                      BearWithBeardB
                                      BearWithBeardB
                                      BearWithBeard
                                      #58
                                      @Fear-na-Boinne I don't know how your device / enclosure is built, but it's good practice to place environmental sensors as close to an opening in the enclosure and keep the dead volume around it as small as possible. Ideally, you'd put it in a separate chamber and move it as far away from other electronics and possible heat sources to minimize their influence to the measurements. If you're worried about dust, you could use thin cloth or something like that around the openings as a dust filter.
                                      That being said, the BME/P sensors tend to report too high temperatures (just google for "BME temperature too high" or something like that - you'll find tons of topics), partly due to self-heating depending on how you use it, e.g. with oversampling enabled. IIRC, using forced mode, oversampling at 0 for pressure and 1 for temperature (and humidity) and filter turned off, is the prefered way for simple weather measurements with minimal current draw according to the datasheet.
                                      If you have one of those 5V modules, the voltage regulator on board might give off some heat aswell.
                                      The "easiest" fix would be to offset the temperature reading in software by a few degrees, if the reported temperature is off by the same value over the whole relevant temperature range (assuming 15 - 30°C for room temperature in your case).
                                      • F
                                        F
                                        Fear na Boinne
                                        The min temperature has dropped significantly since using sleep(), but still the lowest I have seen is 22.8°C, when the other sensor in the room (The central heating thermostat that speaks OpenTherm) was showing a bigger variance.
                                        My sensors are running on the 3.3v the Arduino puts out, so no extra regulators putting out heat (ie other than the one on the Arduino board).
                                        I designed openings and stand-offs in the lid of the enclosure for the sensors, and the rf-nano sits at the bottom of the enclosure, but atm they share the same single chamber... Thinking of drilling a few venting holes near the rf-nano to let warm air out and cool air in...
                                        IIRC am not oversampling, just doing timed single samples, but I'd have to check that.
                                        It's currently sampling once every 10s because the enclosure also has a BH1750 lux sensor I want to sample more frequently, and they obviously run in the same sketch... :P
                                        • F
                                          F
                                          Fear na Boinne
                                          Putting the graphs next to eachother, the graphs looked similar, and after guesstimating the difference and applying that to the sensor as a correction in Domoticz, the graphs are overlapping sufficiently to explain the differences by the difference in location (one is in the center at ~1.7m height, the other on a shelf in a corner at ~2m height) and standard deviation...
                                          I'll keep it like this for a while and will reevaluate at a week's interval.
                                          FWIW I am actually doing the basic oversampling, while doing the timed single samples.
                                          If it remains an issue, I could modify the code to start the sensor with reduced oversampling/accuracy setting, but for now it looks good (enough)...
