  2. Announcements
  3. 💬 Atmospheric Pressure Sensor
pressurebmp085
60 Posts 22 Posters 37.7k Views 19 Watching
  • ghislainG
    ghislainG
    ghislain
    I am and you ? I can give you the sketch which is working for me with library i used.
    • James FlosseJ
      James FlosseJ
      James Flosse
      Yes ^^ . can you give me at snyp_thx at hotmail dot fr?
      • bgunnarbB
        bgunnarbB
        bgunnarb
        Hi!
        I had exactly the same problem until I realised I had compiled for the 8 MHz version of the Arduino Pro Mini instead of the 16 MHz version.
        Also, recently building an humidity sensor I realised there are no pull-up resistors on the SDA SDL lines, but that should be built-in if you use a break-out module.
        I have never been so busy since I retired!
        • HeinzH
          HeinzH
          Heinz
          Which altitude did you enter, or at which sealevel do you live (in meters)?
          const float ALTITUDE = 688; // <-- adapt this value to your own location's altitude.
          The pressure of 728 hPa is a bit strange as it should be around 1000 hPa. In my eyes you threw out the code to correct the pressure depending on the sealevel of your home. See the code from my sketch:
          float pressure = bmp.seaLevelForAltitude(SEALEVEL, absolutePressure);
          Here you can download the sketch I am using:
          https://github.com/windkh/mysensors/blob/master/WeatherStationSensor/WeatherStationSensor.ino
          The forecast will be unknown for at least 30minutes, because the sensor needs that time to detect a weather trend.
          • James FlosseJ
            James FlosseJ
            James Flosse
            @bgunnarb you are find the problem, i think i have arduino pro mini 3.3V but it's 5V. Thx very much it's work better now :)
            • Jeff WilleckeJ
              Jeff WilleckeJ
              Jeff Willecke
              Where do the pin assignments live?
              gohanG 1 Reply Last reply
              • Jeff WilleckeJ Jeff Willecke
                @Jeff-Willecke
                in the article page
                SCL A5 (analog input) Marked blue
                SDA A4 (analog input) Marked green
                • Jeff WilleckeJ
                  Jeff WilleckeJ
                  Jeff Willecke
                  @gohan it appears as though I need SLC and SDA for the sensor it will prevent me from using a second SLC/SDA device. I was assuming that they were utilizing the analog input. My comment may be deleted as it is clearly not applicable
                    that is I2C bus, you can collect multiple devices as long as they have different addresses
                    • Jeff WilleckeJ
                      Jeff WilleckeJ
                      Jeff Willecke
                      OH cool. I guess I have tons more to learn thank you for your help
                      • skywatchS
                        skywatchS
                        skywatch
                        The initial description on this page refers to BMP085.
                        The 'Example' states it is for BMP085 with Adafruit library (linked for dowbload).
                        The sketch uses a BME280 with library from Embedded Adventures.
                        The Datasheet is linked for a BMP085.
                        The shopping guide links to a BMP180.
                        • skywatchS skywatch
                          Sorry for not noticing your post earlier @skywatch
                          The example was originally designed for BMP085. When the BMP180 became widely available, the buy link was updated to the newer version with the note "replaces the old BMP085". Both use the same library.
                          At a later stage, a MySensors user suggested changes to the example sketch to use the BME sensor instead. I don't know why this change was made, but my guess is that the user liked the BME sensor better. I don't know why the change was accepted without updating the build page, but my guess is that since the commit doesn't mention the change of sensor and the amount of code changed is quite large (369 additions and 252 deletions) nobody noticed that a new sensor was used.
                          I'm trying to address the sensor change in https://forum.mysensors.org/topic/9801/bmp-e-atmospheric-pressure
                            Mark Hansen
                            wrote on last edited by Mark Hansen
                            #48
                            Heads-up: I've observed my sensor trying to sleep for 4 billion ms when running the sample code:
                            60082 MCO:SLP:MS=4294967214,SMS=0,I1=255,M1=255,I2=255,M2=255
                            That's 2^32-82. So I think there's an underflow with this line:
                            unsigned long sleeptime = BME280measurementSleepTime - (quicktimecheck - previousBME280Millis);
                            Not sure where exactly though. I've changed my code to simply sleep for a constant 60s.
                              G
                              G
                              grumpazoid
                              wrote on last edited by grumpazoid
                              #49
                              @mfalkvidd I've just started to look into this sensor and the main page is still quite confusing as already stated by @skywatch
                              It seems the choice at present is between the BMP280 or BME280. the latter also includes humidity.
                              Maybe the title could say Temperature/Pressure/Humidity? I just ordered a replacement Si7021, not realising there was another all in one sensor available.
                              It is clear that most ebay sellers are also confused and are wrongly listing BMP devices as BME.
                              I found a good summary to the confusion here https://goughlui.com/2018/08/05/note-bosch-sensortec-bmp280-vs-bme280-sensor-confusion/
                              Hope this helps someone - Think I'll be going for a BME280 here as it as some positive reviews https://www.ebay.co.uk/itm/Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-Module/401513062540
                              Raspberry Pi 3B - Domoticz + Node Red
                              Arduino Pro Mini 3.3V - W5100 Ethernet, Nrf24
                              Arduino Mega, RFLink 433Mhz
                              Sonoff/ESP8266/Tasmota switches
                              • G
                                G
                                grumpazoid
                                I have now had my delivery of the above ebay sensor. Everything looks good. It is a BME280 and reports temp, humidity and pressure.
                                I have used the sketch on the build page and it has worked without any editing. I just had to install the BME280 library as given in the example sketch. Everything is shown nicely in Domoticz.
                                Interesting to note that when compiling in arduino IDE I get the following error : Low memory available, stability problems may occur.
                                Wonder if there will be enough room to add my battery level monitoring code?
                                • G grumpazoid
                                  @grumpazoid If you don't use the forecast feature, remove #define GENERATE_FORECAST. Doing that should give you much less ram usage.
                                  • G
                                    G
                                    grumpazoid
                                    @mfalkvidd Thanks for that. This is going to be my outside weather node running off a 12V solar charged battery. I started wi a DHT22 but it failed after a few months.
                                    • G
                                      G
                                      grumpazoid
                                      @mfalkvidd I've got it up and running now on the bench complete with measuring voltage. I found that removing all the serial print statements also free up a lot of memory. Thanks to all those involved for the provided code.
                                      • I
                                        I
                                        Iliah Borg
                                        When using BME280 breakout https://lowpowerlab.com/shop/product/185 with Embedded Adventures library, life is easier if addrBME280 is set to 0x77 (it is set to 0x76 in BME280_MOD-1022.h)
                                        • F
                                          F
                                          Fear na Boinne
                                          Weird question, but has anyone dealt with thermal isolation of the BMPx8x modules?
                                          To increase the WAF, I have one, together with a BH1750 and an rf-nano in a small, aesthetically pleasing, 3D printed custom housing. However, the temperature is stuck at 26.2°C, which I assume is due to the radiant heat from (mostly) the Arduino and the nRF24L01+
                                          So I am looking for ways to keep the BMPx8x cooler, so it can correctly measure the temperature (and therefore also the pressure, as the warmer chip means the barometric adjustment will be off)...
                                          mfalkviddM BearWithBeardB 2 Replies Last reply
