  2. Announcements
  3. 💬 Door, Window and Push-button Sensor
110 Posts 36 Posters 54.4k Views 32 Watching
  • T Offline
    T Offline
    Terence Faul
    Hi I notice that there is not sleep in this sketch. Is it not required for this build
    • T Terence Faul
      @terence-faul the sketch will work as-is, as long as the node has a constant power supply. If you want a battery-powered node, you'll need sleep. See earlier discussions in this thread for ways to add sleep.
      • pepsonP Offline
        pepsonP Offline
        pepson
        Hi
        Can i connect two sensor contact to this arduino ? First to pin 3 second to pin 4 ? But how modified this sketch to support two sensor contact ?
        skywatchS 1 Reply Last reply
        • pepsonP pepson
          Hi
          skywatchS Offline
          skywatchS Offline
          skywatch
          @pepson If you need the node to sleep or want to use interrupts then only digital pins 2 and 3 will do this for uno/promini.
          So otherwise 2 options really.
          If you just need to know that one of the sensors triggered (but not which one) then you can add sensors in series (for normally 'closed' sensors) or parallel (for normally 'open' sensors).
          To use interrupt and know which sensor triggered you'd have to connect both sensor to interrupt pin with blocking diodes to digital pins as well and then on interrupt you can check which digital pin activated the isr.
          • pepsonP Offline
            pepsonP Offline
            pepson
            I need connect two contact sensor. And i want to know from two sensor his status...
            I need use one to door but second to door garage.
            • pepsonP pepson
              skywatchS Offline
              skywatchS Offline
              skywatch
              #106
              @pepson Then just add another sensor from ground to digital pin 2 and change the code you see in the example to accommodate the extra input.
              You'll need to add another child id, another button, another bounce function, another presentation, another send and another bounce call.
              pepsonP 1 Reply Last reply
              • skywatchS skywatch
                pepsonP Offline
                pepsonP Offline
                pepson
                @skywatch
                Yes but i dont know how do it.... :-(
                I dont know programing.
                N gohanG 2 Replies Last reply
                • pepsonP pepson
                  @skywatch
                  N Offline
                  N Offline
                  @pepson said in 💬 Door, Window and Push-button Sensor:
                  @skywatch
                  Not an excuse, it's time for you to learn :)
                  • pepsonP pepson
                    @skywatch
                    @pepson then it is going to be quite difficult for you to work on DIY electronics projects if you don't how to program.
                    • I Offline
                      I Offline
                      iahim67
                      Perhaps it would be good to update the example code. I mean the pull-up sequence:
                      "It is recommended to set the pinMode() to INPUT_PULLUP to enable the internal pull-up resistor." - https://www.arduino.cc/reference/en/language/functions/digital-io/digitalwrite/
                      The following seems to be obsolete:
                      // Setup the button
                      pinMode(BUTTON_PIN,INPUT);
                      // Activate internal pull-up
