  2. Announcements
  3. 💬 Water Meter Pulse Sensor
109 Posts 37 Posters 66.9k Views 35 Watching
  • zboblamontZ zboblamont
    @bjacobse Another option perhaps to consider (if it is physically viable), is to insert a meter and sensor of your choice within your property, they are not expensive nowadays and easy enough to fit ?
    A simple meter and reed switch such as this link text or similar perhaps.
    bjacobseB
    bjacobseB
    bjacobse
    @zboblamont
    In Sweden you need a certified installer to exchange your pipes, else in case of water damage your insurance won't cover.
    so cheapest for me is a RPI with camera - but yes I would prefer a "real" measuring from a dedicated sensor
    zboblamontZ F 2 Replies Last reply
    • bjacobseB bjacobse
      @zboblamont
      zboblamontZ
      zboblamontZ
      zboblamont
      wrote on last edited by zboblamont
      #82
      @bjacobse Pardon my laughter, insurers look for any excuse for sure, but I have never heard yet where a water meter or any other competent insertion damaged a building, let alone an insurance company refused to compensate for a building which burned to the ground (99.9%) on the basis the water meter was not a verified install. For sure some loss adjusters will use any excuse, but really?
      To clarify, in many countries a certified inspector or Engineer must certify that work is carried out within the regulations, it does not state that HE/SHE has carried out the work, only that it has been inspected and verified as compliant. You know any certified local plumbers with 5 minutes to spare, because that is how long it takes me to fit one, and about the time it takes a certified pipe-jockey to verify it's right and sign it off, if it really concerns you ?
      I have 2 self fitted water meters with sensors, gas meter sensor etc, and a huge amount of DIY stuff any smartass insurer could IMPLY was a contributory factor to the disaster which befell my house, but frankly it wouldn't stand 1 second in Court before being laughed out...
      Place hasn't burned down yet, fallen over in earthquakes, or been subjected to landslide, but luckily I don't have Swedish Insurers.... ;)
      PS- I should clarify that the standing regulations are framed to quite rightly protect consumers as well as the service provider against cowboys interfering with apparatus. Changing light switches or sockets falls under the same overall umbrella despite everyone and their mother changing them.
        @zboblamont
        F
        F
        fredswed
        @bjacobse I believe you can replace the meter yourself if you own it yourself and have the necessary skills. I live in such an area and was told I could mount it myself if I was confident enough. But of course, the fault will be yours if your bad job causes damages. In reality it is quite unlikely that you can mount it badly and not notice the problem immediately.
        A more critical issue is that water meters are usually owned by the municipality or water company and they are sealed. It is impossible to replace the meter without breaking the seal and when the company notices they won't be happy at all.
        • F fredswed
          zboblamontZ
          zboblamontZ
          zboblamont
          #84
          @fredswed And by extension (Possibly Swedish water suppliers differ from UK or Romanian counterparts?) the data retrieved from their devices is often regarded as their property also, and brick walls begin to appear ino what should be readily shared data. If they will not share, fitting a downstream device within your own control can often be the only solution, don't interfere, augment...
          As a perverse example, my own gas and electricity suppliers are the German monolith EON who provide and enable access to their 'graphs' online, updated with 1 or 2 month readings (gas and electricity).
          Having checked the base data for their graphs, I realised they were presenting a lovely graph based on complete bunkum, and developed and maintained my own ever since, which IS accurate. I checked recently and their graphs are still pretty but complete rubbish.
          Installing a gas meter sensor caused EON palpitations until they realised it was the commercial device for the meter and could not object on technicalities then quietly dropped objections, I don't care how they respond when I fit meters to the Consumer box, it is nowhere near their SMART meter which tells me nothing but tells them much, mainly that I halved their 2 monthly bill ;) .
          If the service provider will allow detailed sharing of YOUR data, all good and well as it is mutually beneficial, but if not, easy enough to solve at your own expense.
          I fitted two replacement upgraded radiators in the last month, somewhere a Romanian regulation lurks that I should not have done so, but the insurer doesn't give a damn unless it is found to have caused the demise of the insured property.. Is it worth the risk? Hell yes...
          • J
            J
            JohnLi
            It looks very interesting. I complied and uploaded successful, but it ran without run the loop function at all. infrared sensor lighted up but no print out attached Serial.print.
            Can you give us the url to the library #include <MySensors.h>?. I am using MySensors 2.3.1 loaded from Adruino IDE->Tools->Manage Libary->search My Sensors from https://www.mysensors.org
            4:55:53.476 -> 60127 TSM:FAIL:RE-INIT
            14:55:53.476 -> 60129 TSM TSM:FAIL:DIS
            14:55:53.476 -> 900384 TSF:TDI:TSL
            14:55:54.962 ->
            14:55:54.962 -> __ __ ____
            14:55:54.962 -> | / |_ / | ___ _ __ ___ ___ _ __ ___
            14:55:54.962 -> | |/| | | | _
            \ / _ \ _ \/ __|/ _ \|
            _/ __|
            14:55:54.962 -> | | | | |
            | || | / | | _ \ _ | | _
            14:55:54.962 -> |
            |_
            , |/ ___|| ||/_/|| |/
            14:55:54.962 -> |
            __/ 2.3.1
            14:55:54.962 ->
            14:55:54.962 -> 16 MCO:BGN:INIT NODE,CP=RNNNA---,REL=255,VER=2.3.1
            14:55:54.962 -> 26 TSM:INIT
            14:55:54.962 -> 27 TSF:WUR:MS=0
            14:55:54.997 -> 33 !TSM:INIT:TSP FAIL
            14:55:54.997 -> 35 TSM:FAIL:CNT=1
            14:55:54.997 -> 37 TSM:FAIL:DIS
              it looks like it is can't find the radio module. Check cables and pins numering
              • E
                E
                executivul
                Sorry to hijack the thread a bit,
                I'm using a TCRT5000 sensor to read a water meter (Zenner), it works ok until it stops detecting pulses, I have to increase the sensitivity (clockwise turn the trimpot) and it works ok for another few days/weeks, then again it needs an increase in sensitivity, like somehow it's loosing it's sensitivity .
                I'm already with my second sensor, the first one got to the end of the trimpot and couldn't adjust anymore.
                Has this happened to anyone else? It's powered by 5V, it's the LED losing power or the photosensor losing sensitivity? Any ideas?
                Thanks.
                  Don't you have another sensor to try?
                  • A
                    A
                    Alehandro06
                    @flopp which box did you buy for m-bus readings? did you work it out?
                    ''I was so lucky that my water company change the meter to a meter with wireless m-bus.
                    So I bought a box for this and now I have 100% correct readings.''
                    • B
                      B
                      bereska
                      Water Meter shows up in mysensors.json and homeassistant logs but fails to appear in Homeassistant GUI.
                      I have a dozen Nodes already successfully operating
                      I used the default sketch on this page. Just added Node 6
                      Looks like values are not getting through
                      Thank you for your help
                      • B
                        B
                        bereska
                        this is HA log:
                        2019-07-04 23:24:05 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on mygateway1-out/6/255/3/0/11: b'Water Meter',
                        2019-07-04 23:24:05 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 6;255;3;0;11;Water Meter,
                        2019-07-04 23:24:23 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on mygateway1-out/6/255/3/0/11: b'Water Meter',
                        2019-07-04 23:24:23 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 6;255;3;0;11;Water Meter
                        B 1 Reply Last reply
                        • B bereska
                          this is HA log:
                          B
                          B
                          bereska
                          here is the sketch:
                          #define MY_RADIO_RF24
                          #define MY_NODE_ID 6
                          //#define MY_RADIO_NRF5_ESB
                          //#define MY_RADIO_RFM95
                          #define DIGITAL_INPUT_SENSOR 3                  // The digital input you attached your sensor.  (Only 2 and 3 generates interrupt!)
                          #define PULSE_FACTOR 1000                       // Number of blinks per m3 of your meter (One rotation/liter)
                          #define SLEEP_MODE false                        // flowvalue can only be reported when sleep mode is false.
                          #define MAX_FLOW 40                             // Max flow (l/min) value to report. This filters outliers.
                          #define CHILD_ID 1                              // Id of the sensor child
                          uint32_t SEND_FREQUENCY =
                              30000;           // Minimum time between send (in milliseconds). We don't want to spam the gateway.
                          MyMessage flowMsg(CHILD_ID,V_FLOW);
                          MyMessage volumeMsg(CHILD_ID,V_VOLUME);
                          MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
                          double ppl = ((double)PULSE_FACTOR)/1000;        // Pulses per liter
                          volatile uint32_t pulseCount = 0;
                          volatile uint32_t lastBlink = 0;
                          volatile double flow = 0;
                          bool pcReceived = false;
                          uint32_t oldPulseCount = 0;
                          uint32_t newBlink = 0;
                          double oldflow = 0;
                          double volume =0;
                          double oldvolume =0;
                          uint32_t lastSend =0;
                          uint32_t lastPulse =0;
                            // initialize our digital pins internal pullup resistor so one pulse switches from high to low (less distortion)
                            pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);
                            pulseCount = oldPulseCount = 0;
                            request(CHILD_ID, V_VAR1);
                            lastSend = lastPulse = millis();
                            attachInterrupt(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), onPulse, FALLING);
                            sendSketchInfo("Water Meter", "1.1");
                            // Register this device as Water flow sensor
                            present(CHILD_ID, S_WATER);
                            uint32_t currentTime = millis();
                            if (SLEEP_MODE || (currentTime - lastSend > SEND_FREQUENCY)) {
                              lastSend=currentTime;
                              if (!pcReceived) {
                                //Last Pulsecount not yet received from controller, request it again
                                return;
                              if (!SLEEP_MODE && flow != oldflow) {
                                oldflow = flow;
                                Serial.print("l/min:");
                                Serial.println(flow);
                                // Check that we don't get unreasonable large flow value.
                                // could happen when long wraps or false interrupt triggered
                                if (flow<((uint32_t)MAX_FLOW)) {
                                  send(flowMsg.set(flow, 2));                   // Send flow value to gw
                              // No Pulse count received in 2min
                              if(currentTime - lastPulse > 120000) {
                                flow = 0;
                              // Pulse count has changed
                              if ((pulseCount != oldPulseCount)||(!SLEEP_MODE)) {
                                oldPulseCount = pulseCount;
                                Serial.print("pulsecount:");
                                Serial.println(pulseCount);
                                send(lastCounterMsg.set(pulseCount));                  // Send  pulsecount value to gw in VAR1
                                double volume = ((double)pulseCount/((double)PULSE_FACTOR));
                                if ((volume != oldvolume)||(!SLEEP_MODE)) {
                                  oldvolume = volume;
                                  Serial.print("volume:");
                                  Serial.println(volume, 3);
                                  send(volumeMsg.set(volume, 3));               // Send volume value to gw
                            if (SLEEP_MODE) {
                              sleep(SEND_FREQUENCY);
                            if (message.type==V_VAR1) {
                              uint32_t gwPulseCount=message.getULong();
                              pulseCount += gwPulseCount;
                              flow=oldflow=0;
                              pcReceived = true;
                          void onPulse()
                            if (!SLEEP_MODE) {
                              uint32_t newBlink = micros();
                              uint32_t interval = newBlink-lastBlink;
                              if (interval!=0) {
                                if (interval<500000L) {
                                  // Sometimes we get interrupt on RISING,  500000 = 0.5 second debounce ( max 120 l/min)
                                  return;
                                flow = (60000000.0 /interval) / ppl;
                              lastBlink = newBlink;
                            pulseCount++;
                          • B
                            B
                            bereska
                            looks like the problem is the node is NOT sending initial value to gw
                            need your help modifying the sketch accordingly
                            thank you
                            • B
                              B
                              bereska
                              Is it possible to get any help on this page or not?
                              rejoe2R 1 Reply Last reply
                              • B bereska
                                rejoe2R
                                rejoe2R
                                rejoe2
                                @bereska said in 💬 Water Meter Pulse Sensor:
                                Crying out loud most likely will not help...
                                Seems your setup is a little special, so just some assumptions from one using a serial GW and not MyS-MQTT:
                                Your controller is asked for sending an initial value, but has none yet. So no answer is sent out. Triggering the counter on Node side could help to send one (after waiting time has passed). Then have a look at your controller, if there's a value available. If, you might set the correct value, restart your node afterwards and see, if everything now works as expected?
                                • rejoe2R rejoe2
                                  B
                                  B
                                  bereska
                                  @rejoe2 thank you. How do i trigger "the counter on Node side"?
                                  • rejoe2R
                                    rejoe2R
                                    rejoe2
                                    ...just let the node count some pulses (your code states: FALLING). So just pull the counter PIN (here: D3) to ground several times.
                                    • rejoe2R rejoe2
                                      B
                                      B
                                      bereska
                                      @rejoe2 i did like you said, still no show in HA
                                      here is the serial log:
                                       __  __       ____
                                              |___/                      2.3.0
                                      16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.3.0
                                      26 TSM:INIT
                                      28 TSF:WUR:MS=0
                                      34 !TSM:INIT:TSP FAIL
                                      36 TSM:FAIL:CNT=1
                                      38 TSM:FAIL:DIS
                                      40 TSF:TDI:TSL
                                       __  __       ____
                                              |___/                      2.3.0
                                      26 TSM:INIT
                                      28 TSF:WUR:MS=0
                                      34 TSM:INIT:TSP OK
                                      36 TSM:INIT:STATID=6
                                      38 TSF:SID:OK,ID=6
                                      40 TSM:FPAR
                                      77 TSF:MSG:SEND,6-6-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                      532 TSF:MSG:READ,0-0-6,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                      538 TSF:MSG:FPAR OK,ID=0,D=1
                                      624 TSF:MSG:READ,31-31-6,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                      1267 TSF:MSG:READ,21-21-6,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                      1546 TSF:MSG:READ,41-41-6,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                      2088 TSM:FPAR:OK
                                      2088 TSM:ID
                                      2091 TSM:ID:OK
                                      2093 TSM:UPL
                                      2097 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                      2103 TSF:MSG:READ,0-0-6,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                      2109 TSF:MSG:PONG RECV,HP=1
                                      2113 TSM:UPL:OK
                                      2115 TSM:READY:ID=6,PAR=0,DIS=1
                                      2119 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                      2127 TSF:MSG:READ,0-0-6,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                      2138 TSF:MSG:SEND,6-6-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.0
                                      2148 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                      2242 TSF:MSG:READ,0-0-6,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                      2250 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=11,pt=0,l=11,sg=0,ft=0,st=OK:Water Meter
                                      2260 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.1
                                      2273 TSF:MSG:SEND,6-6-0-0,s=1,c=0,t=21,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2281 MCO:REG:REQ
                                      2289 TSF:MSG:SEND,6-6-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                      2297 TSF:MSG:READ,0-0-6,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                      2304 MCO:PIM:NODE REG=1
                                      2306 MCO:BGN:STP
                                      2310 TSF:MSG:SEND,6-6-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                      2318 MCO:BGN:INIT OK,TSP=1
                                      32319 TSF:MSG:SEND,6-6-0-0,s=1,c=2,t=24,pt=0,l=0,sg=0,ft=0,st=OK:
                                      • rejoe2R
                                        rejoe2R
                                        rejoe2
                                        wrote on last edited by rejoe2
                                        #99
                                        Logparser states: there was nothing counted (empty payload). So make sure, there really was counted anything.
                                        (I didn't check your sketch, just assuming, it's the default one and everything is wired correctly; if that's the case, you should be able to see a different payload than nothing or "0", that your controller might treat as non existent).
                                          Great work @bart59 !
                                          Do you have any indication on how long battery life you will get with this setup?
                                          stevefury
                                          @mfalkvidd how looks the sensor now with the modifications? and how to wire this?
