  2. Announcements
  3. 💬 Building a wired RS485 sensor network
164 Posts 33 Posters 76.9k Views 35 Watching
  • R
    R
    Reza
    for wiring , is this true ?
    rs485...............arduino
    vcc......................5v
    gnd....................gnd
    DI.........................9
    DE........................2
    RE.......................10
    R0........................8
    K 2 Replies Last reply
    • R Reza
      K
      K
      kimot
      @Reza
      DI and DO depends on your board type.
      Look at AltSoftSerial_Boards.h
      DE and RE should be connected together and connected to pin,
      which is defined in your program:
      #define MY_RS485_DE_PIN 2
      R 1 Reply Last reply
      • R Reza
        K
        K
        kimot
        @Reza
        http://cmss.pl/arduino/MySensor_RS485_test02_b.JPG
        • K kimot
          @Reza
          R
          R
          Reza
          @kimot thank you friend :rose:
          • K kimot
            @Reza
            R
            R
            Reza
            @kimot
            for a raspberry pi gateway this wiring is true ?
            wimdW 1 Reply Last reply
            • R Reza
              @kimot
              wimdW
              wimdW
              wimd
              @Reza No. You need to have your gateway inbetween. Your controller can't "talk" directly with you MySensors network. Wee the picture from kimot.
              gohanG R 2 Replies Last reply
              • wimdW wimd
                @wimd
                actually RPI can act as gateway https://www.mysensors.org/build/raspberry , but I agree that's much easier to have an Arduino as a gateway
                • wimdW wimd
                  R
                  R
                  Reza
                  @wimd we can build a gateway with raspberrypi without arduino . @gohan saying true . but i have to use gpio for serial gateway because when i use a usb serial port after turn on/off or reboot raspberry can not detect my gateway... but with gpio i test and this is true, so i have to use gpio for gateway
                  K gohanG 2 Replies Last reply
                  • R
                    R
                    Reza
                    if i use rs485 for my network , can solve problems about signaling and distance and wall? and solve problem about NACK ?
                    • R Reza
                      K
                      K
                      kimot
                      wrote on last edited by kimot
                      #70
                      @Reza
                      Maybe your problem and its solution with "serial-through USB" connection on Raspberry is described here:
                      https://g0kao.wordpress.com/2013/08/08/usb-port-assignment-on-a-raspberry-pi/
                      K 1 Reply Last reply
                      • K kimot
                        @Reza
                        K
                        K
                        kimot
                        @kimot
                        I am not sure, that Raspberry can work like RS485 gateway for MySensors RS485 network.
                        On a "quick" look through code, I do not find anything for RS485.
                        • R Reza
                          @Reza
                          Maybe it is worth a try and get a W5100 network shield and make an ethernet gateway. I have one now and so far I'm happy with it.
                          • R
                            R
                            Reza
                            thank you friends
                            • R
                              R
                              Reza
                              @kimot @gohan do you use a wired network with rs485 ? i have problem with rf24 and i want change my wireless network to a wiring network , but i want know with a rs485 all command are send? without error and NACK ? now for wireless network i have for example every 5 true commands 1 fail command(NACK)
                              gohanG 1 Reply Last reply
                              • R Reza
                                @Reza
                                not yet, but I am getting the parts to make a wired rs485 network of 4 nodes + gateway. About the NACK error it should be handled by the library and retransmit the lost packet.
                                • P
                                  P
                                  pjr
                                  Currently there is no "hw" ack functionlity like the radio has.
                                  You can check out the rs485 transmit code from here.
                                  But you can of course use the ack functionality between controller software and node to make sure message will get to destination.
                                    @Reza
                                    R
                                    R
                                    Reza
                                    @gohan now my sensors lib how many send packet if first is lost ? how more this ?
                                    i want after send command Turn on light Certainly
                                    • R
                                      R
                                      Reza
                                      wrote on last edited by Reza
                                      #78
                                      i am tired for test and trying to configure wiring network with RS485. this is strange :angry:
                                      i build a gateway and a relay with rs485 . for test i now use 2raspberry pi and 1orangepi and a laptop ! every time disconnect gateway from one and connect to other one ( with out other change for example sketch and wiring and etc. just change controller) some time this is very good work on laptop. some time good work on orange and some time good on raspbrrey pis !! some time same first command has sent(LED on gateway and on node just one blink. some time LEDs 2 blink and turn on later)
                                      i am using 15cm wire between 2nodes! when change to some meter so dont work never...
                                      so there is not any one that understand what is reason this issue !!!
                                      i am ready and i have devices and madules. so any body that think can solve this , told me so i test on my devices and feedback.
                                      • P
                                        P
                                        pjr
                                        wrote on last edited by pjr
                                        #79
                                        @Reza have you tried to use terminating resistors?
                                        And perhaps it could be good to try 1k pull-up and pull-downs at the gateway end. The left diagram:
                                        With these two tricks I got my setup stable.
                                        And a little tweak to transport class could help also..
                                        • P pjr
                                          R
                                          R
                                          Reza
                                          @pjr
                                          i use 120 ohm in terminate before. but now i use 1k for pull-up and down.but this is effectless.
                                          please wait until i read this topic (rs485 stress test) and do it and feedback here . thank you
