  3. MySensors support in MajorDoMo
5 Posts 4 Posters 2.6k Views 1 Watching
  • sergejeyS
    sergejeyS
    sergejey
    Hi guys! Just found this project, I really like the idea and I will recommend it to everyone trying to build sensors network for home automation. This is a project called MajorDoMo (majordomohome.com) -- it is open source as well and it has MQTT support built-in. I'm going to try to use it with MySensors MQTT gateway but maybe somebody else want to give it a try so we could discus any problems/issues together. Thanks!
      @sergejey said:
      majordomohome.com
      Ohh.. I haven't stumbled upon MajorDoMo before. We're here if you have any questions.
      @bjornhallberg You might wanna add it to your list?
        @sergejey said:
        majordomohome.com
        bjornhallbergB
        bjornhallbergB
        bjornhallberg
        wrote on last edited by bjornhallberg
        @hek I'll do that. Never seen the project either.
        @sergejey Does it run well on the Pi?
        sergejeyS 1 Reply Last reply
          sergejeyS
          sergejeyS
          sergejey
          @bjornhallberg Yes, it does. Unfortunately I don't have instructions in English as the most of information about this project is in Russian (smartliving.ru -- the "mirror" web-site with pretty big community at the forum). Project is written in PHP and uses MySQL database a lot so for Pi you will need to have external HDD attached to avoid problems with memory card multiple read/write cycles. There is Windows installer as well.
          • Ivan ZI
            Ivan ZI
            Ivan Z
            I have 4 mysensor device in MajorDomo. Work well.
            1. Door sensor, Reed switch & Vibration sensor
            2. Pulse meter for Gas meter
            3. DHT22
            4. Hygrometer for my plants
            In plan
            • Pulse meter for water counter
            Every sensor insert in small box - power bank http://www.ebay.com/itm/2600mAh-USB-Power-Bank-Portable-External-Battery-Charger-For-iphone-Samsung-/261693722800?pt=US_Cell_Phone_PDA_Chargers&var=&hash=item3cee2950b0
            And small accumulator http://www.ebay.com/itm/271676342921?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
            Looks like this http://smartliving.ru/forum/download/file.php?id=1417
