  3. Some advise needed for the first project SerialGW and MotionSensor
12 Posts 4 Posters 3.6k Views 4 Watching
  • emrsenE
    emrsenE
    emrsen
    I just have started to use mysensors which I have the feeling that I can do a lot with my projects but I've stuck in the first project of using serial gateway with Arduino nano and motion detector with Arduino uno.
    I just have used the example sketches and used 10micoF 16V capacitors but can not able to register sensor client.
    I have updated Arduino ide to latest version but this also had not helped.
    I also have ran Clear EepromConfig successfully but this has not helped either..
    Please find the output from serial monitor of the sensor client below. After TSM:PDT it loops back to TSM:INIT.
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSM:ID
    TSM:ID
    TSM:ID
    !TSM:CHKID:FAIL (ID=255)
    !TSM:FAILURE
    TSM:PDT
    Please find the serial log for the Gateway
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;255;3;0;9;TSP:MSG:BC
    0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
    0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
    0;255;3;0;9;TSP:MSG:GWL OK
    0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
    0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    255;255;3;0;3;
    Please advise where I should check or how to overcome "!TSM:CHKID:FAIL (ID=255)"
    Thanks a lot
    • emrsenE
      emrsenE
      emrsen
      wrote on last edited by emrsen
      I have revised all wiring and reinstalled latest library. I just have switched gateway and sensor nodes.
      I've checked that after TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok: in sensor side there should be a TSP:MSG:READ line then TSP:ASSIGNID:OK but this is not happening.
      Any idea where I have to check? I've stuck in my project.
      I'm just using example sketches in have not changed anything
      Your help is appreciated. Thanks
      T 1 Reply Last reply
      • emrsenE emrsen
        TimO
        @emrsen The node is asking for an ID. The ID is given out by a controller or you have to use static IDs in your sensor sketch.
        • emrsenE
          emrsenE
          emrsen
          Thanks for the reply I shall try
          • emrsenE
            emrsenE
            emrsen
            @TimO thanks for responding but I still can not get the ID from controller. I also have tried to set ID in node manually as 0 but this had not helped either.
            I think I'm missing a very basic dumb thing please check the setup I've listed below and added sketches I've used and output log files.
            As far as I understand from the output logs : Node requests ID from Gateway and I see that gateway also receives data from node but gateway do not respond to the node creating and delivering an ID.
            Thanks a lot for your help :)
            I've re-setup both Gateway and node from scratch. I've downloaded latest lib. from github. I also have cleared the eprom of the Node.
            Gateway I used Arduino nano clone and NRF24L01+(not the powerful model with antenna) used 10 micF condensator as described. Code I've used created from example of Serial Gateway as below
             * The ArduinoGateway prints data received from sensors on the serial link.
             * The gateway accepts input on seral which will be sent out on radio network.
             * The GW code is designed for Arduino Nano 328p / 16MHz
             * Wire connections (OPTIONAL):
             * - Inclusion button should be connected between digital pin 3 and GND
             * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
             * LEDs (OPTIONAL):
             * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs
            // Enable serial gateway
            #define MY_GATEWAY_SERIAL
            // Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
            #if F_CPU == 8000000L
            #define MY_BAUD_RATE 38400
            // Enable inclusion mode
            // Flash leds on rx/tx/err
            //#define MY_LEDS_BLINKING_FEATURE
            // Set blinking period
            #define MY_WITH_LEDS_BLINKING_INVERSE
            #define MY_DEFAULT_ERR_LED_PIN 4  // Error led pin
            #define MY_DEFAULT_RX_LED_PIN  6  // Receive led pin
            #define MY_DEFAULT_TX_LED_PIN  5  // the PCB, on board LED
            void presentation() {
            Output of the serial Gateway is below
            0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
            0;255;3;0;9;TSM:INIT:TSP OK
            0;255;3;0;9;TSM:INIT:GW MODE
            0;255;0;0;18;2.0.1-beta
            0;255;3;0;9;MCO:BGN:STP
            0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
            0;255;3;0;9;TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
            255;255;3;0;3;
            255;255;3;0;3;
            0;255;3;0;9;TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
            0;255;3;0;9;TSF:MSG:BC
            0;255;3;0;9;TSF:MSG:FPAR REQ,ID=255
            0;255;3;0;9;TSF:CHKUPL:OK
            0;255;3;0;9;TSF:MSG:GWL OK
            0;255;3;0;9;TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
            255;255;3;0;3;
            255;255;3;0;3;
            255;255;3;0;3;
            255;255;3;0;3;
            I used Arduino Uno Clone as node and uploaded Motion Sensor sketch not changing any thing please find the code below
             * Version 1.0 - Henrik Ekblad
             * Motion Sensor example using HC-SR501
             * http://www.mysensors.org/build/motion
            // Enable debug prints
            // Initialize motion message
              sendSketchInfo("Motion Sensor", "1.0");
              present(CHILD_ID, S_MOTION);
              // Read digital motion value
              Serial.println(tripped);
              send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
              sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
            This is the log screen in node device. Node requests ID from Gateway and I see that gateway also receives data from node but as far as I see from log gateway do not respond to the node creating and delivering an ID.
            MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta
            TSM:INIT
            TSM:INIT:TSP OK
            TSM:FPAR
            TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
            TSF:MSG:FPAR RES,ID=0,D=0
            TSF:MSG:FPAR OK,ID=0,D=1
            TSM:FPAR:OK
            TSM:ID
            TSM:ID:REQ
            TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
            TSM:ID
            TSM:ID:REQ
            TSM:ID
            TSM:ID:REQ
            TSM:ID
            TSM:ID:REQ
            !TSM:ID:FAIL,ID=255
            TSM:FAILURE
            TSM:FAILURE:PDT
            TSM:FAILURE:RE-INIT
            TSM:INIT
            TSM:INIT:TSP OK
            TSM:FPAR```
            • emrsenE emrsen
               * LEDs (OPTIONAL):
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              255;255;3;0;3;
              TSM:INIT
              TSM:INIT:TSP OK
              TSM:FPAR
              TSM:FPAR:OK
              TSM:ID
              TSM:ID:REQ
              TSM:ID
              TSM:ID:REQ
              TSM:ID
              TSM:ID:REQ
              TSM:ID
              TSM:ID:REQ
              !TSM:ID:FAIL,ID=255
              TSM:FAILURE
              TSM:FAILURE:PDT
              TSM:FAILURE:RE-INIT
              TSM:INIT
              TSM:INIT:TSP OK
              TSM:FPAR```
              @emrsen the gateway does not assign IDs. The controller does. Are you using a controller?
              ID 0 is reserved for the gateway. Node IDs need to be 1-254 if you want to assign it manually. See https://www.mysensors.org/about/network for details.
              emrsenE 1 Reply Last reply
                emrsenE
                emrsenE
                emrsen
                @mfalkvidd Thanks a lot for the enlightment I'm not using a controller I've just asumed that gateway will be fine to manage the Nodes which is the dumb thing I was missing.
                I've started to work on selecting a controller.
                Can anyone advise which controller is most easy to setup and integrate for a newbee? I have Raspberry Pi3 at home hosting Blynk Server which I plan to setup on this platform.
                Thanks again for the help and support so far.
                • T
                  TimO
                  Well, Domoticz is very easy to setup and the integration is good. I personally prefer OpenHAB2 because of the wide range of supported hardware. But the setup is definitely more advanced.
                  • T TimO
                    emrsenE
                    emrsenE
                    emrsen
                    @TimO Thanks for the info I shall work on it at the weekend shall update about my progress :)
                    • CurlyWurlyC
                      CurlyWurlyC
                      CurlyWurly
                      See here on another thread for what I did to make things work. It seems with Uno clones, you have to supply separate power (the USB does not supply enough juice).
                      https://forum.mysensors.org/topic/4896/solved-mysensors-node-not-working-trouble-finding-parent-node
                      N.B. When testing without a controller, the only code change you need to do is to add a line in the sensor node code to set the node id (see link for more details)
                      • emrsenE
                        emrsenE
                        emrsen
                        @TimO said:
                        Domoticz
                        Thanks for the advise
                        • emrsenE
                          emrsenE
                          emrsen
                          Thanks all you guys, now my first experimental system is working :) :thumbsup:
