  3. Problem getting the code to run with MySensors library 2.0
38 Posts 3 Posters 11.8k Views 3 Watching
    @palande.vaibhav what does the debug output say?
    You can also add a few Serial.println in the code to see where the execution stops.
    palande.vaibhavP Offline
    palande.vaibhav
    @mfalkvidd
    Thanx for the suggestion. It's worse than I thought.
    Here is the code:
    //MySensors
    // Enable debug prints
    //#define MY_DEBUG
    //// Enable and select radio type attached
    ////#define MY_RADIO_RFM69
    #define MY_GATEWAY_SERIAL
    // Initialize motion message
    //MyMessage msg(1, V_LIGHT);
      pinMode(8, OUTPUT);
      Serial.println("Setup runs");
    void presentation() {
     Serial.println("presentation runs");
      Serial.println("loop runs");
       digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
      delay(1000);              // wait for a second
      digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
    This is the output with #define MY_GATEWAY_SERIAL line.
    Without #define MY_GATEWAY_SERIAL, it doesn't show anything on the serial monitor.
    palande.vaibhavP 1 Reply Last reply
    • palande.vaibhavP palande.vaibhav
      @ayo
      did you try commenting #define MY_GATEWAY_SERIAL and running your Blink code?
      Can you please try that?
      ayoA Offline
      ayoA Offline
      ayo
      I don't have access to my computer now I will try it when I have it.
      @palande.vaibhav said:
      @ayo
        @mfalkvidd
        Here is the code:
        //MySensors
        //#define MY_DEBUG
          pinMode(8, OUTPUT);
        palande.vaibhav
        wrote on last edited by palande.vaibhav
        #23
        @mfalkvidd
        Here is the code:
        //MySensors
        //#define MY_DEBUG
          pinMode(8, OUTPUT);
        @mfalkvidd Any update on this?
          @mfalkvidd
          Here is the code:
          //MySensors
          //#define MY_DEBUG
            pinMode(8, OUTPUT);
          @palande.vaibhav no, I haven't got any ideas on what could be wrong. Sorry.
          • ayoA ayo
            @ayo
            palande.vaibhav
            @ayo Did you try running the code?
            ayoA 1 Reply Last reply
              palande.vaibhav
              @mfalkvidd
              Is it only me?
              Can you please try this on your setup as time permits?
              I have a manual install of the library 2.0
              I want to use this for one of my projects and I am dead stuck.
                Cause I can't use MY_GATEWAY_SERIAL for a node. Right?
                Yes you can. But I read that there is a bug in MySensors 2.0 that causes the presentation function to not run, so you'll need the latest code from the MySensors development branch on Github.
                palande.vaibhav
                #27
                @mfalkvidd
                I have to keep #define MY_GATEWAY_SERIAL line in the code for both gateway and sensor nodes.
                Now since I have #define MY_GATEWAY_SERIAL line in the code for both gateway and sensor node, both of them are initializing as gateways.
                And this causes them not to be able to communicate with each other.
                Please help
                  ayoA Offline
                  ayoA Offline
                  ayo
                  So I tried the whole code thing again as you have requested and I notice something weird happening to the device.
                  This is the code below
                  //// Enable debug prints to serial monitor
                  //#define MY_DEBUG
                  //// Set LOW transmit power level as default, if you have an amplified NRF-module and
                  //// power your radio separately with a good regulator you can turn up PA level.
                  //// Enable serial gateway
                  //#define MY_GATEWAY_SERIAL
                    pinMode(8, OUTPUT);
                   Serial.println("Presentation Runs");
                    Serial.println("Loop is running");
                  After I commented out #define MY_GATEWAY_SERIAL nothing really happens on the serial monitor as you have said.
                  No blinking nor display on the monitor.
                  So I went back to the code and enable #define MY_DEBUG to see what was actually happening....
                  THEN..I figured out what was happening
                  I uploaded the new code with #define MY_Debug uncomment and #define MY_Gateway_Serial still commented out I got this one the serial monitor
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  !TSM:FPAR:FAIL
                  !TSM:FAILURE
                  TSM:PDT
                  TSM:INIT
                  TSM:RADIO:OK
                  TSM:FPAR
                  TSM:FPAR
                  TSM:FPAR
                  From the result, the device is working as a node and trying to communicate with the parent/gateway and it enters an endless retry loop that keeps trying to communicate with the gateway. This is the reason i suppose nothing seems to be working because it is stuck trying to connect to the parent.
                  The Addition of #define MY_GATEWAY_SERIAL makes it already a gateway/parent device and avoids that endless loop thing.
                  • ayoA Offline
                    ayoA Offline
                    ayo
                    I think one way to go about making it work is to edit that element of the mysensor main code that makes it enter an infinite retry loop is to is to make it retry for about maybe 3 times if no connection still it should raise a flag and leaves the loop and continue into the main code.
                    • ayoA ayo
                      //#define MY_DEBUG
                        pinMode(8, OUTPUT);
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      palande.vaibhav
                      @ayo
                      But adding #define MY_GATEWAY_SERIAL to the code for the sensor node will make it a gateway. Right? Please check my last post where I posted the screenshots of this making both of them initialize as the gateway.
                      And if both are gateways they won't communicate
                        @ayo
                        ayoA Offline
                        ayoA Offline
                        ayo
                        Yes they won't communicate
                        @ayo
                        • ayoA ayo
                          @ayo
                          palande.vaibhav
                          @ayo
                          Then this makes library 2.0 completely useless cause we always have to use MY_GATEWAY_SERIAL and so can't create sensor nodes.
                          If you also confirm this then I am gonna report this as a bug.
                            @ayo
                            ayoA Offline
                            ayoA Offline
                            ayo
                            wrote on last edited by ayo
                            #33
                            No it is not like that.
                            You can create sensor nodes without the MY_Gateway_Serial thing, you just have to make sure that you have one device acting as a gateway device and the rest as a sensor node and everything will work very fine.
                            The reason you are having problem is because you are only building with one device and the library requires at-least 2 devices to work.
                            @ayo
                            • ayoA ayo
                              @ayo
                              palande.vaibhav
                              #34
                              @ayo
                              How can I make sensor nodes with the MY_GATEWAY_SERIAL line in the code. This just makes the device a gateway. How do I make it a sensor node with that line included?
                              Just having two different devices in the same code will work??
                              Like in this code:
                               * Interrupt driven binary switch example with dual interrupts
                               * Author: Patrick 'Anticimex' Fallberg
                               * Connect one button or door/window reed switch between
                               * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
                               * one in similar fashion on digital I/O pin 2.
                               * This example is designed to fit Arduino Nano/Pro Mini
                              #define MY_NODE_ID 1
                              #define SKETCH_NAME "Binary Sensor"
                              #define SKETCH_MAJOR_VER "1"
                              #define SKETCH_MINOR_VER "0"
                              #define PRIMARY_CHILD_ID 3
                              #define SECONDARY_CHILD_ID 4
                              #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
                              #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
                              #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
                              #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
                              #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
                              #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
                              #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
                              #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
                              #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
                              #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
                              MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
                              MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
                                // Setup the buttons
                                pinMode(PRIMARY_BUTTON_PIN, INPUT);
                                pinMode(SECONDARY_BUTTON_PIN, INPUT);
                                pinMode(8,OUTPUT);
                                // Activate internal pull-ups
                                digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
                                digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
                                Serial.begin(115200);
                                sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER "." SKETCH_MINOR_VER);
                                 Register binary input sensor to sensor_node (they will be created as child devices)
                                 You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
                                 If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
                                present(PRIMARY_CHILD_ID, S_DOOR);
                                present(SECONDARY_CHILD_ID, S_DOOR);
                                uint8_t value;
                                static uint8_t sentValue=2;
                                static uint8_t sentValue2=2;
                                //sleep(5);
                                value = digitalRead(PRIMARY_BUTTON_PIN);
                                if (value != sentValue) {
                                   // Value has changed from last transmission, send the updated value
                                   send(msg.set(value==HIGH ? 1 : 0));
                                   digitalWrite(8,!(digitalRead(8)));
                                   String string = "Value changed to: ";
                                   Serial.println(string += value);
                                   sentValue = value;
                                value = digitalRead(SECONDARY_BUTTON_PIN);
                                if (value != sentValue2) {
                                   send(msg2.set(value==HIGH ? 1 : 0));
                                   sentValue2 = value;
                                // Sleep until something happens with the sensor
                                sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
                                //sleep(0,CHANGE,0);
                              • ayoA Offline
                                ayoA Offline
                                ayo
                                I was able to make the blinking thing run with #Define MY_GATEWAY_SERIAL commented out by having another Arduino Uno runing the gateway serial program. Basically you will need two devices setup to work or you could make use of this hack
                                too which will also make your device work too without having to connect to the parent.
                                Go to your library folder and find the mysensors library folder open it and look for the core folder open the MySensorCore.cpp file make sure you have a backup of that file before opening it.
                                Find this section of the code
                                #if defined(MY_RADIO_FEATURE)
                                		// Save static parent id in eeprom (used by bootloader)
                                		hwWriteConfig(EEPROM_PARENT_NODE_ID_ADDRESS, MY_PARENT_NODE_ID);
                                		debug(PSTR("Starting Connection Process\n"));
                                		transportInitialize();
                                		// My modification should be removed for later
                                		debug(PSTR("Starting Connection Process 2\n"));
                                		int counter = 0;
                                		while (!isTransportOK()) {
                                			hwWatchdogReset();
                                			transportProcess();
                                			//debug(PSTR("Trying to connect to parent \n"));
                                			#if defined(ARDUINO_ARCH_ESP8266)
                                				yield();
                                			counter++;
                                			if (counter >= 3) // exit after 3 attempts to connect
                                				break;
                                		debug(PSTR("Starting Connection Process 3\n"));
                                You can replace that section with those or just make those modification you see.
                                Save and try to upload your program again with the #define MY_Gateway_Serial thing commented out and the program will still run.
                                What that modification does is to exit the loop after 3 connection attempts.
                                  @ayo
                                  Like in this code:
                                    pinMode(8,OUTPUT);
                                    uint8_t value;
                                    //sleep(5);
                                       sentValue = value;
                                       sentValue2 = value;
                                  ayoA Offline
                                  ayoA Offline
                                  ayo
                                  I meant without the MY_Gateway_Serial thing
                                  @ayo
                                  Like in this code:
                                    pinMode(8,OUTPUT);
                                    uint8_t value;
                                    //sleep(5);
                                       sentValue = value;
                                       sentValue2 = value;
                                  • ayoA ayo
                                    		int counter = 0;
                                    			hwWatchdogReset();
                                    			transportProcess();
                                    				yield();
                                    			counter++;
                                    				break;
                                    palande.vaibhav
                                    @ayo
                                    Oh I get it now. Now I understand. I must have a gateway and at least one sensor node running for this to work. If there is no gateway then sensor nodes don't work because of the constant loop trying to find a parent.
                                    My problem was I was trying to write and run the code with just the sensor node.
                                    I will also do the modifications you mentioned to the core files.
                                    Thanx a lot for your help. I really appreciate it. :+1:
                                    • ayoA Offline
                                      ayoA Offline
                                      ayo
                                      That's correct :)
                                      12.2k
