  3. Problem getting the code to run with MySensors library 2.0
38 Posts 3 Posters 12.5k Views 3 Watching
  • ayoA ayo
    I believe the problem is a result of the pin 13 you are using for the Led. The Mysensor & SPI both require pin 13 (Pin 13 is SCK pin for SPI) for the radio communication. Try and move your Led Pin to another pin from Pin 8 downward.
    palande.vaibhavP
    palande.vaibhavP
    palande.vaibhav
    @ayo
    I did. The problem is still there. I also tried simplest of the simple LED blink code. Check my new post.
    Thank You
    • palande.vaibhavP
      palande.vaibhavP
      palande.vaibhav
      wrote on last edited by palande.vaibhav
      @palande.vaibhav said:
      @mfalkvidd @ayo
      Even uncommenting #define MY_RADIO_NRF24 WORKS.
      So the problem starts when I uncomment #include <MySensors.h>.
      • palande.vaibhavP
        palande.vaibhavP
        palande.vaibhav
        @mfalkvidd @ayo
        I just tested with older library version 1.5.4.
        Both Blink and my Switch code work with MySensors library version 1.5.4 but doesn't work with version 2.0.
        • ayoA
          ayoA
          ayo
          So I tired the blinking thing on my own Arduino setup using the MySensors 2.0 installed var the Arduino Library manager.
          The Led blinks with the mysensors library attached.
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Flash leds on rx/tx/err
          // Set blinking period
          // Enable inclusion mode
            pinMode(8, OUTPUT);
             digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
            wait(1000);              // wait for a second
            digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
          Maybe you can give that a short...
          palande.vaibhavP 2 Replies Last reply
          • palande.vaibhavP
            palande.vaibhavP
            palande.vaibhav
            • ayoA ayo
                pinMode(8, OUTPUT);
              palande.vaibhavP
              palande.vaibhavP
              palande.vaibhav
              @ayo
              OK. I will give this a shot.
              One more thing is installing the library 2.0 from Arduino library manager gives an error "
              CRC doesn't match. File is corrupted." I am using Arduino IDE version 1.6.12.
              I am downloading the zip from GitHub and pasting it in the Documents/Arduino/libraries folder. This is OK right??
              • ayoA ayo
                  pinMode(8, OUTPUT);
                palande.vaibhavP
                palande.vaibhavP
                palande.vaibhav
                @ayo
                Something weird is happening right now. I am now running MySensors version 2.0. The code you gave works with library version 2.0.
                I was just experimenting with the lines of the code to see which line makes difference and I found that #define MY_GATEWAY_SERIAL line makes difference.
                If I just add that line to my Blink code, it works with MySensors.h
                I don't know why this happens.
                //// Enable debug prints to serial monitor
                //// Enable and select radio type attached
                ////#define MY_RADIO_RFM69
                //// Set LOW transmit power level as default, if you have an amplified NRF-module and
                //// power your radio separately with a good regulator you can turn up PA level.
                //// Enable serial gateway
                //// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V & SenseBender)
                //#if F_CPU == 8000000L
                //#define MY_BAUD_RATE 38400
                //#endif
                //// Flash leds on rx/tx/err
                //#define MY_LEDS_BLINKING_FEATURE
                //// Set blinking period
                //// Inverses the behavior of leds
                ////#define MY_WITH_LEDS_BLINKING_INVERSE
                //// Enable inclusion mode
                //// Enable Inclusion mode button on gateway
                //// Inverses behavior of inclusion button (if using external pullup)
                ////#define MY_INCLUSION_BUTTON_EXTERNAL_PULLUP
                //// Set inclusion mode duration (in seconds)
                //// Digital pin used for inclusion mode button
                  pinMode(8, OUTPUT);
                  delay(1000);              // wait for a second
                This code works but only if I have #define MY_GATEWAY_SERIAL line included. Can you try this on your setup?
                In my code which was not working previously, If I just add #define MY_GATEWAY_SERIAL , it works.
                In your Blink code, if you just comment out the line #define MY_GATEWAY_SERIAL, it won't work. Can you try this?
                palande.vaibhavP 1 Reply Last reply
                • palande.vaibhavP palande.vaibhav
                  @ayo
                  //#endif
                    pinMode(8, OUTPUT);
                  palande.vaibhavP
                  palande.vaibhavP
                  palande.vaibhav
                  @mfalkvidd
                  Any idea why this is happening?
                  Cause I can't use MY_GATEWAY_SERIAL for a node. Right?
                  • ayoA
                    ayoA
                    ayo
                    Okay....so you are really having a strange problem here.
                    Am using the Arduino version 1.6.8,
                    Can you consider upgrading your arduino version maybe that could fix the CRC thing...
                      @mfalkvidd
                      Yes you can. But I read that there is a bug in MySensors 2.0 that causes the presentation function to not run, so you'll need the latest code from the MySensors development branch on Github.
                      palande.vaibhavP 4 Replies Last reply
                      • ayoA ayo
                        palande.vaibhavP
                        palande.vaibhavP
                        palande.vaibhav
                        @ayo
                        1.6.8 is the older version. 1.6.12 is the latest version.
                        And the CRC error is the known bug. So, if your IDE and MySensors work then don't change anything.
                        • ayoA ayo
                          palande.vaibhavP
                          palande.vaibhavP
                          palande.vaibhav
                          @ayo
                          did you try commenting #define MY_GATEWAY_SERIAL and running your Blink code?
                          Can you please try that?
                          ayoA 1 Reply Last reply
                            palande.vaibhavP
                            palande.vaibhavP
                            palande.vaibhav
                            But am I right that for MySensors version 2.0, we must have #define MY_GATEWAY_SERIAL line in order for the code to work? OR is it just me?
                            And I don't even have anything in the presentation function. I think my problem is loop function not working if I don;t have #define MY_GATEWAY_SERIAL line in the code.
                              palande.vaibhavP
                              palande.vaibhavP
                              palande.vaibhav
                              I tried with the library from Development branch on GitHub. It still doesn't work.
                              I must have #define MY_GATEWAY_SERIAL line in the code for the code to work with MySensors.h.
                              Library version:
                              Code below doesn't work cause I have commented #define MY_GATEWAY_SERIAL: Just uncomment it and the same code works
                              //MySensors
                              //#define MY_GATEWAY_SERIAL
                              const byte DIGITAL_INPUT_SENSOR = 3;   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                              //#define CHILD_ID 1   // Id of the sensor child
                              // Initialize motion message
                              //MyMessage msg(1, V_LIGHT);
                                pinMode(8, OUTPUT);
                                palande.vaibhavP
                                palande.vaibhavP
                                palande.vaibhav
                                @mfalkvidd
                                I saw the post about the presentation function not working in 2.0. But that has been fixed in development version.
                                My problem is still there that code doesn't work at all. To which I think my loop function stops working if I don't have #define MY_GATEWAY_SERIAL line in the code.
                                  @mfalkvidd
                                  @palande.vaibhav what does the debug output say?
                                  You can also add a few Serial.println in the code to see where the execution stops.
                                    palande.vaibhavP
                                    palande.vaibhavP
                                    palande.vaibhav
                                    @mfalkvidd
                                    Thanx for the suggestion. It's worse than I thought.
                                    Here is the code:
                                    //MySensors
                                      pinMode(8, OUTPUT);
                                      Serial.println("Setup runs");
                                     Serial.println("presentation runs");
                                      Serial.println("loop runs");
                                    This is the output with #define MY_GATEWAY_SERIAL line.
                                    Without #define MY_GATEWAY_SERIAL, it doesn't show anything on the serial monitor.
                                      @ayo
                                      ayoA
                                      ayoA
                                      ayo
                                      I don't have access to my computer now I will try it when I have it.
                                      @ayo
                                        @mfalkvidd
                                        Here is the code:
                                        //MySensors
                                          pinMode(8, OUTPUT);
                                        palande.vaibhavP
                                        palande.vaibhavP
                                        palande.vaibhav
                                        #23
                                        @mfalkvidd
                                        Here is the code:
                                        //MySensors
                                          pinMode(8, OUTPUT);
                                        @mfalkvidd Any update on this?
                                          @mfalkvidd
                                          Here is the code:
                                          //MySensors
                                            pinMode(8, OUTPUT);
                                          @palande.vaibhav no, I haven't got any ideas on what could be wrong. Sorry.
                                          12.5k
