  3. Problem getting the code to run with MySensors library 2.0
38 Posts 3 Posters 12.5k Views 3 Watching
    @palande.vaibhav said:
    Cause I can't use MY_GATEWAY_SERIAL for a node. Right?
    Yes you can. But I read that there is a bug in MySensors 2.0 that causes the presentation function to not run, so you'll need the latest code from the MySensors development branch on Github.
    palande.vaibhavP
    palande.vaibhavP
    palande.vaibhav
    I tried with the library from Development branch on GitHub. It still doesn't work.
    I must have #define MY_GATEWAY_SERIAL line in the code for the code to work with MySensors.h.
    Library version:
    Code below doesn't work cause I have commented #define MY_GATEWAY_SERIAL: Just uncomment it and the same code works
    //MySensors
    // Enable debug prints
    //// Enable and select radio type attached
    ////#define MY_RADIO_RFM69
    //#define MY_GATEWAY_SERIAL
    const byte DIGITAL_INPUT_SENSOR = 3;   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
    //#define CHILD_ID 1   // Id of the sensor child
    // Initialize motion message
    //MyMessage msg(1, V_LIGHT);
      pinMode(8, OUTPUT);
       digitalWrite(8, HIGH);   // turn the LED on (HIGH is the voltage level)
      delay(1000);              // wait for a second
      digitalWrite(8, LOW);    // turn the LED off by making the voltage LOW
      palande.vaibhavP
      palande.vaibhavP
      palande.vaibhav
      @mfalkvidd
      I saw the post about the presentation function not working in 2.0. But that has been fixed in development version.
      My problem is still there that code doesn't work at all. To which I think my loop function stops working if I don't have #define MY_GATEWAY_SERIAL line in the code.
      • palande.vaibhavP palande.vaibhav
        @mfalkvidd
        @palande.vaibhav what does the debug output say?
        You can also add a few Serial.println in the code to see where the execution stops.
        palande.vaibhavP 1 Reply Last reply
          palande.vaibhavP
          palande.vaibhavP
          palande.vaibhav
          @mfalkvidd
          Thanx for the suggestion. It's worse than I thought.
          Here is the code:
          //MySensors
            pinMode(8, OUTPUT);
            Serial.println("Setup runs");
           Serial.println("presentation runs");
            Serial.println("loop runs");
          This is the output with #define MY_GATEWAY_SERIAL line.
          Without #define MY_GATEWAY_SERIAL, it doesn't show anything on the serial monitor.
            @ayo
            did you try commenting #define MY_GATEWAY_SERIAL and running your Blink code?
            Can you please try that?
            ayoA
            ayoA
            ayo
            I don't have access to my computer now I will try it when I have it.
            @ayo
              @mfalkvidd
              Here is the code:
              //MySensors
                pinMode(8, OUTPUT);
              palande.vaibhavP
              palande.vaibhavP
              palande.vaibhav
              wrote on last edited by palande.vaibhav
              #23
              @mfalkvidd
              Here is the code:
              //MySensors
                pinMode(8, OUTPUT);
              @mfalkvidd Any update on this?
                @mfalkvidd
                Here is the code:
                //MySensors
                  pinMode(8, OUTPUT);
                @palande.vaibhav no, I haven't got any ideas on what could be wrong. Sorry.
                • ayoA ayo
                  @ayo
                  palande.vaibhavP
                  palande.vaibhavP
                  palande.vaibhav
                  @ayo Did you try running the code?
                  ayoA 1 Reply Last reply
                    palande.vaibhavP
                    palande.vaibhavP
                    palande.vaibhav
                    @mfalkvidd
                    Is it only me?
                    Can you please try this on your setup as time permits?
                    I have a manual install of the library 2.0
                    I want to use this for one of my projects and I am dead stuck.
                      palande.vaibhavP
                      palande.vaibhavP
                      palande.vaibhav
                      #27
                      @mfalkvidd
                      I have to keep #define MY_GATEWAY_SERIAL line in the code for both gateway and sensor nodes.
                      Now since I have #define MY_GATEWAY_SERIAL line in the code for both gateway and sensor node, both of them are initializing as gateways.
                      And this causes them not to be able to communicate with each other.
                      Please help
                        ayoA
                        ayoA
                        ayo
                        So I tried the whole code thing again as you have requested and I notice something weird happening to the device.
                        This is the code below
                        //// Enable debug prints to serial monitor
                        //// Set LOW transmit power level as default, if you have an amplified NRF-module and
                        //// power your radio separately with a good regulator you can turn up PA level.
                        //// Enable serial gateway
                          pinMode(8, OUTPUT);
                         Serial.println("Presentation Runs");
                          Serial.println("Loop is running");
                        After I commented out #define MY_GATEWAY_SERIAL nothing really happens on the serial monitor as you have said.
                        No blinking nor display on the monitor.
                        So I went back to the code and enable #define MY_DEBUG to see what was actually happening....
                        THEN..I figured out what was happening
                        I uploaded the new code with #define MY_Debug uncomment and #define MY_Gateway_Serial still commented out I got this one the serial monitor
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        !TSM:FPAR:FAIL
                        !TSM:FAILURE
                        TSM:PDT
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR
                        TSM:FPAR
                        From the result, the device is working as a node and trying to communicate with the parent/gateway and it enters an endless retry loop that keeps trying to communicate with the gateway. This is the reason i suppose nothing seems to be working because it is stuck trying to connect to the parent.
                        The Addition of #define MY_GATEWAY_SERIAL makes it already a gateway/parent device and avoids that endless loop thing.
                        • ayoA
                          ayoA
                          ayo
                          I think one way to go about making it work is to edit that element of the mysensor main code that makes it enter an infinite retry loop is to is to make it retry for about maybe 3 times if no connection still it should raise a flag and leaves the loop and continue into the main code.
                          • ayoA ayo
                              pinMode(8, OUTPUT);
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            !TSM:FPAR:FAIL
                            !TSM:FAILURE
                            TSM:PDT
                            TSM:INIT
                            TSM:RADIO:OK
                            TSM:FPAR
                            TSM:FPAR
                            TSM:FPAR
                            palande.vaibhavP
                            palande.vaibhavP
                            palande.vaibhav
                            @ayo
                            But adding #define MY_GATEWAY_SERIAL to the code for the sensor node will make it a gateway. Right? Please check my last post where I posted the screenshots of this making both of them initialize as the gateway.
                            And if both are gateways they won't communicate
                              @ayo
                              ayoA
                              ayoA
                              ayo
                              Yes they won't communicate
                              @ayo
                              • ayoA ayo
                                @ayo
                                palande.vaibhavP
                                palande.vaibhavP
                                palande.vaibhav
                                @ayo
                                Then this makes library 2.0 completely useless cause we always have to use MY_GATEWAY_SERIAL and so can't create sensor nodes.
                                If you also confirm this then I am gonna report this as a bug.
                                  @ayo
                                  ayoA
                                  ayoA
                                  ayo
                                  wrote on last edited by ayo
                                  #33
                                  No it is not like that.
                                  You can create sensor nodes without the MY_Gateway_Serial thing, you just have to make sure that you have one device acting as a gateway device and the rest as a sensor node and everything will work very fine.
                                  The reason you are having problem is because you are only building with one device and the library requires at-least 2 devices to work.
                                  @ayo
                                  • ayoA ayo
                                    @ayo
                                    palande.vaibhavP
                                    palande.vaibhavP
                                    palande.vaibhav
                                    #34
                                    @ayo
                                    How can I make sensor nodes with the MY_GATEWAY_SERIAL line in the code. This just makes the device a gateway. How do I make it a sensor node with that line included?
                                    Just having two different devices in the same code will work??
                                    Like in this code:
                                    #define MY_NODE_ID 1
                                    #define SKETCH_MAJOR_VER "1"
                                    #define SKETCH_MINOR_VER "0"
                                    #define PRIMARY_CHILD_ID 3
                                    #define SECONDARY_CHILD_ID 4
                                      // Setup the buttons
                                      pinMode(8,OUTPUT);
                                      // Activate internal pull-ups
                                       Register binary input sensor to sensor_node (they will be created as child devices)
                                       You can use S_DOOR, S_MOTION or S_LIGHT here depending on your usage.
                                       If S_LIGHT is used, remember to update variable type you send in. See "msg" above.
                                      present(SECONDARY_CHILD_ID, S_DOOR);
                                      uint8_t value;
                                      static uint8_t sentValue=2;
                                      static uint8_t sentValue2=2;
                                      //sleep(5);
                                      if (value != sentValue) {
                                         send(msg.set(value==HIGH ? 1 : 0));
                                         digitalWrite(8,!(digitalRead(8)));
                                         String string = "Value changed to: ";
                                         Serial.println(string += value);
                                         sentValue = value;
                                      if (value != sentValue2) {
                                         send(msg2.set(value==HIGH ? 1 : 0));
                                         sentValue2 = value;
                                      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
                                      //sleep(0,CHANGE,0);
                                    • ayoA
                                      ayoA
                                      ayo
                                      I was able to make the blinking thing run with #Define MY_GATEWAY_SERIAL commented out by having another Arduino Uno runing the gateway serial program. Basically you will need two devices setup to work or you could make use of this hack
                                      too which will also make your device work too without having to connect to the parent.
                                      Go to your library folder and find the mysensors library folder open it and look for the core folder open the MySensorCore.cpp file make sure you have a backup of that file before opening it.
                                      Find this section of the code
                                      #if defined(MY_RADIO_FEATURE)
                                      		// Save static parent id in eeprom (used by bootloader)
                                      		hwWriteConfig(EEPROM_PARENT_NODE_ID_ADDRESS, MY_PARENT_NODE_ID);
                                      		debug(PSTR("Starting Connection Process\n"));
                                      		transportInitialize();
                                      		// My modification should be removed for later
                                      		debug(PSTR("Starting Connection Process 2\n"));
                                      		int counter = 0;
                                      		while (!isTransportOK()) {
                                      			hwWatchdogReset();
                                      			transportProcess();
                                      			//debug(PSTR("Trying to connect to parent \n"));
                                      				yield();
                                      			counter++;
                                      			if (counter >= 3) // exit after 3 attempts to connect
                                      		debug(PSTR("Starting Connection Process 3\n"));
                                      You can replace that section with those or just make those modification you see.
                                      Save and try to upload your program again with the #define MY_Gateway_Serial thing commented out and the program will still run.
                                      What that modification does is to exit the loop after 3 connection attempts.
                                        @ayo
                                        Like in this code:
                                          pinMode(8,OUTPUT);
                                          uint8_t value;
                                          //sleep(5);
                                             sentValue = value;
                                             sentValue2 = value;
                                        ayoA
                                        ayoA
                                        ayo
                                        I meant without the MY_Gateway_Serial thing
                                        @ayo
                                        Like in this code:
                                          pinMode(8,OUTPUT);
                                          uint8_t value;
                                          //sleep(5);
                                             sentValue = value;
                                             sentValue2 = value;
                                        • ayoA ayo
                                          		int counter = 0;
                                          			hwWatchdogReset();
                                          			transportProcess();
                                          				yield();
                                          			counter++;
                                          palande.vaibhavP
                                          palande.vaibhavP
                                          palande.vaibhav
                                          @ayo
                                          Oh I get it now. Now I understand. I must have a gateway and at least one sensor node running for this to work. If there is no gateway then sensor nodes don't work because of the constant loop trying to find a parent.
                                          My problem was I was trying to write and run the code with just the sensor node.
                                          I will also do the modifications you mentioned to the core files.
                                          Thanx a lot for your help. I really appreciate it. :+1:
                                          12.5k
