  3. Domoticz
  4. domoticz auto add device (mysensors) even if disable "Accept new Hardware Devices"
65 Posts 10 Posters 26.3k Views 6 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Are they not self explanatory?
    The first enables the feature, the second decides what IO to use for the button, the third the duration of the mode and the last if you use a external pull up on the signal.
    Inclusion mode for a gw is to have the gw accept reporting new nodes to a controller. It can be used for any type of gw.
    R 1 Reply Last reply
    • AnticimexA Anticimex
      R
      R
      Reza
      wrote on last edited by Reza
      #22
      @Anticimex
      so can i use MY_INCLUSION_MODE_BUTTON_PIN for add my device? add a button to pin3 and just when press this devices add to my gatway.otherwise dont add any devices(auto add in domoticz)
      AnticimexA 1 Reply Last reply
      • R Reza
        @Anticimex
        AnticimexA
        AnticimexA
        Anticimex
        @Reza please read replies carefully. You need to make sure you enable the feature. That is the first define. Most if not all defines have a default value. Just search the code.
        Press the button (assuming it is connected properly) and the gateway will accept new nodes for the duration specified by the third define. I am no specialist on how this works so someone else can probably give better details on how node-gw-controller handle additions of new nodes. But my Vera won't add devices unless I put my GW in inclusion mode and boot up nodes so they send their presentation data to the gw. But if it is the gw or the controller that decides if the device should be added or not based onthe gw inclusion mode I don't know, but it would seem to me pretty obvious that it would be the gw that decides that.
        In other words, inclusion mode is used to add new devices. And as far as I know it is the only way (once you enable that feature). I don't know if that is the solution to your problem as I don't fully understand what your problem really is, but it will not prevent any others from listening in on your sensors.
        Enabling encryption will obfuscate the data you transmit from eavesdroppers, but any reasonably intelligent attacker will anyway be able to guess what data you transmit.
          R
          R
          Reza
          #24
          thank you my friend . i test serial gateway with vera . exactly. in vera there is inclusion button and dont add auto device... but in domoticz is not...
          so thank you for help. if you found any solution please help me.
          • R Reza
            AnticimexA
            AnticimexA
            Anticimex
            @Reza This is the MySensors forum, not the Domoticz forum. If you have issues with Domoticz, I suggest you post your questions there. MySensors provide a set of features. It is up to the controllers to make use of them.
              R
              R
              Reza
              @Anticimex
              in domoticz forum told me this issue is related to mysensors gateway and here told me this issue is related to domoticz :)
              • R Reza
                @Anticimex
                AnticimexA
                AnticimexA
                Anticimex
                @Reza Well, you said it yourself. It works with Vera. So it is obviously not a MySensors issue.
                  R
                  R
                  Reza
                  @Anticimex
                  but in vera , there is a device(gateway) with inclusion button but in domoticz my gateway dont have a inclusion button , so this is related to domoticz?
                  • R Reza
                    @Anticimex
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @Reza Well, of course it is! MySensors cannot control what Domoticz UI shows.
                      R
                      R
                      Reza
                      right :( so i must change my controller ? i want a open surce controller and a good controller :(
                      • R Reza
                        AnticimexA
                        AnticimexA
                        Anticimex
                        @Reza Or you get the Domoticz people to fix their shit.
                          R
                          R
                          Reza
                          but they told me this problem is related to mysensors gateway ! :|
                          one more question. can i use static id between my device and gateway? and i disable feature inclusion mode ? so my gateway dont auto add other devices...
                          • R Reza
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @Reza So convenient for them. But we at MySensors cannot change how domoticz works so I if they don't want to fix it, well, that is just too bad.
                              R
                              R
                              Reza
                              #34
                              @Anticimex
                              yes , also i explain to them that this problem is related to domoticz because mysensors gateway is working well with vera controller and there is a inclusion button in vera dashboard , but in domoticz...
                              • tbowmoT
                                tbowmoT
                                tbowmo
                                Another solution, could be to change the default rf channel, and have the two houses on different frequencies.
                                • tbowmoT tbowmo
                                  R
                                  R
                                  Reza
                                  @tbowmo
                                  this is good . how do this ?
                                  tekkaT 1 Reply Last reply
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    Look in myconfig.h, if I remember right.. There should be some hints
                                    • R Reza
                                      @tbowmo
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @Reza The community cannot focus all energy on supporting your case. Many if not all of your questions are answered in the howtos & forum - why don't you take advantage of the search function, enter "rf channel" and read some of the posts?
                                      • tbowmoT tbowmo
                                        R
                                        R
                                        Reza
                                        thank you
                                        • tekkaT tekka
                                          R
                                          R
                                          Reza
                                          @tekka
                                          this is a general issue . not just my problem ! if this issue resolved so can help to many people in future ! the reason of that i question this issue in this forum is after resolved , can help to many. so if you sad from this , ok i will silence in this forum.
                                          thank you
