  3. Sensor node not working without #define MyDebug
25 Posts 6 Posters 8.1k Views 5 Watching
  • ayoA
    ayoA
    ayo
    I have built a sensor node with one of the mysensors examples and my gateway runs the default SerialGateway code without any modification. Sensor node is running on Arduino Mega and Gateway device runs on Arduino Uno and am using the mysensor 2.0. Everything is working properly well but when I tried commenting the #define MY_DEBUG on the gateway code I observe that the sensor node can't seems to work well again and can't successfully connect to the gateway device.
    Sensor node won't work well if comment the My_Debug code on the gateway.
    //#define MY_DEBUG
    Sensor node works well if I uncomment the My_Debug code on the gateway
    My sensor node #define MY_DEBUG code is uncommented.
    This is the screenshot of the result from the gateway and the sensor node respectively
    Result from the sensor node
    It fails at this stage
    TSP:PING:SEND (dest=0)
    !TSP:MSG:SEND 8-8-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    What am I doing wrong? or any fix to make the gateway work with printing out the debug messages.
    I will really appreciate the help.
    Thank You.
    karl261K 1 Reply Last reply
    • cimba007C
      cimba007C
      cimba007
      Can u describe more about your sensor node? What voltage? What speed? General setup?!
      ayoA 1 Reply Last reply
      • ayoA ayo
        //#define MY_DEBUG
        !TSM:UPL:FAIL
        Thank You.
        karl261K
        karl261K
        karl261
        @ayo Hmmm I experienced this also Once with the default repeater node sketch. The radio failed completely when commenting out the my_debug.
        However, it went away somehow, so I cannot debug it. It went away after several reuploads of the sketch. So maybe there was just something wrong during programming in my case...
        • cimba007C cimba007
          ayoA
          ayoA
          ayo
          The Sensor node is being powered by an Arduino Mega 2560 var a USB connection to my pc as source of power. I have a 10uf cap btw the 3.3v and Gnd that powers the nrf24L01+ radio. It's just the normal traditional sensor node setup. Also I have an Led connected to one of the arduino mega pins (pin 4).
          • karl261K karl261
            ayoA
            ayoA
            ayo
            Is it commenting out my_Debug at the gateway side or at the sensor node side. Mine is at the gateway side and the sensor node fails to connect even though my_debug isn't commented out. I even try commenting it out self it doesn't still work either.
            • Alex PopovskiyA
              Alex PopovskiyA
              Alex Popovskiy
              I observed similar problem with nodes communication, only in opposite direction, the gateway was fine but two of my nodes required MY_DEBUG enabled to function properly. One of them was completely unreachable without MY_DEBUG or a delay(10) in the loop(), and other node had big problems receiving data (a lot of fail's). I couldn't figure out where the problem was, my assumption is that it is some kind of timing problem, maybe the radio being polled to fast or something... and debug prints certainly add some time to code execution and that kinda solves the problem. But thats only my assumption, I may be completely wrong
              • delinendD
                delinendD
                delinend
                I have the same problem on Serialgateway 2.0.1-beta. If I disable MY_DEBUG, nothing can't connect to the Gateway.
                • delinendD
                  delinendD
                  delinend
                  Update: If I set my RF24 to MIN (#define RF24_PA_LEVEL RF24_PA_MIN), then my NODE's can fine connect to my Serialgateway, with disabled MY_DEBUG. Hmm that's strange ?!?! So yes, maybe it's a timing problem. Btw. I use 47uF on all NRF24's.
                  tekkaT 1 Reply Last reply
                  • delinendD
                    delinendD
                    delinend
                    I have solved it, with the fix from Alex, with a delay(10) in the loop() :-) Thanks
                    tekkaT ayoA 2 Replies Last reply
                    • delinendD delinend
                      tekkaT
                      tekkaT
                      tekka
                      wrote on last edited by tekka
                      @delinend Please describe your GW setup, that is:
                      • HW type
                      • Frequency / voltage
                      • Arduino IDE version
                      • Board def version.
                      I'd like to reproduce your issue.
                      delinendD 2 Replies Last reply
                      • delinendD
                        delinendD
                        delinend
                        wrote on last edited by delinend
                        This post is deleted!
                        • tekkaT tekka
                          • HW type
                          delinendD
                          delinendD
                          delinend
                          @tekka
                          Last Mysensor 2.0.1-beta
                          2 Arduino Mini Pro (8Mhz) 3.3V version
                          2 NRF24l01+ with 47uF caps
                          Use a 3.6V LiPo battery on both setup's.
                          IDE 1.6.12
                          I use the standard GatewaySerial.ino and BinarySwitchSleepSensor.ino sketch, where the problem comes, when I disable the MY_DEBUG in the GatewaySerial.ino sketch.
                          I think the problem is, that the "void loop()" in the GatewaySerial.ino is empty, and the Arduino has a timing problem to the radio, as the loop is running to fast, without doing nothing. If I add delay(10) into the "void loop", it all works fine.
                          • tekkaT tekka
                            • HW type
                            delinendD
                            delinendD
                            delinend
                            @tekka
                            Btw. Another problem. If I use the "#define MY_DISABLED_SERIAL" on my GatewaySerial.ino I still get incomming message on the serial port. Ex. temp sendet from a tempsensor here:
                            6;0;1;0;0,24.5
                            6;0;1;0;0,24.6
                            6;0;1;0;0,24.5
                            6;0;1;0;0,24.4
                            6;0;1;0;0,24.5
                              tekkaT
                              tekkaT
                              tekka
                              @delinend
                              I also need the AVR board def version - you can find this information in the Boards Manager.
                              delinendD 1 Reply Last reply
                                @tekka
                                6;0;1;0;0,24.5
                                6;0;1;0;0,24.6
                                6;0;1;0;0,24.5
                                6;0;1;0;0,24.4
                                6;0;1;0;0,24.5
                                tekkaT
                                tekkaT
                                tekka
                                @delinend said:
                                @tekka
                                6;0;1;0;0,24.5
                                6;0;1;0;0,24.6
                                6;0;1;0;0,24.5
                                6;0;1;0;0,24.4
                                6;0;1;0;0,24.5
                                Well, there is no sense in disabling the serial port on a serial gateway :smirk:
                                • tekkaT tekka
                                  @delinend
                                  delinendD
                                  delinendD
                                  delinend
                                  @tekka
                                  BN: Unknown board
                                  VID: 10C4
                                  PID EA60
                                  SN: Upload any sketch to obtain it
                                  Btw. I use OpTiboot loader
                                    ayoA
                                    ayoA
                                    ayo
                                    wrote on last edited by ayo
                                    So I tried to see if I make one last attempt to fix this problem again, I tried the Alex option using a delay(10) in the for loop. So I put a delay(10) in the for loop of my gateway code whoa it works fully well. I guess their is truly a timely issues here and the enable my_debug it's somehow doing a slowing things down work.
                                    But using a delay(10) in the loop isn't really an efficient way though.
                                    UPDATE: Using a delay(1) also works for me too
                                      @tekka
                                      BN: Unknown board
                                      VID: 10C4
                                      PID EA60
                                      tekkaT
                                      tekkaT
                                      tekka
                                      @delinend Still not the right thing. Sorry for bugging you with that ;)
                                      You'll find the requested information under:
                                      In Arduino IDE under Tools | Board | Boards Manager => Arduino AVR Boards Built-in by Arduino version 1.6.xx
                                      • tekkaT tekka
                                        delinendD
                                        delinendD
                                        delinend
                                        @tekka
                                        It's: Arduino AVR Board Built-In by Arduino version 1.6.14 installed.
                                          @tekka
                                          tekkaT
                                          tekkaT
                                          tekka
                                          @delinend I've tried your setup but cannot reproduce your issue. Are you on the latest dev branch (from today)? What board did you choose in the settings?
                                          Out of curiosity, please upload this sketch:
                                          #define MY_CORE_ONLY
                                            Serial.begin(115200);
                                            Serial.println("***");
                                            Serial.print("V=");
                                            Serial.println(hwCPUVoltage());
                                            Serial.print("F=");
                                            Serial.println(hwCPUFrequency());
                                          void loop() {}
                                          and post the serial output.
