Sensor node not working without #define MyDebug
Here the output.
V=3726
F=89
The board name is: [Optiboot] Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
As I use Optiboot bootloader.##############################################################
pro328o.name=[Optiboot] Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
pro328o.upload.tool=avrdude
pro328o.upload.protocol=arduino
pro328o.upload.maximum_size=32256
pro328o.upload.maximum_data_size=2048
pro328o.upload.speed=57600
pro328o.bootloader.tool=avrdude
pro328o.bootloader.low_fuses=0xff
pro328o.bootloader.high_fuses=0xde
pro328o.bootloader.extended_fuses=0xfd
pro328o.bootloader.file=optiboot/optiboot_atmega328.hex
pro328o.bootloader.unlock_bits=0x3F
pro328o.bootloader.lock_bits=0x0F
pro328o.build.mcu=atmega328p
pro328o.build.board=AVR_PRO
pro328o.build.f_cpu=8000000L
pro328o.build.core=arduino
pro328o.build.variant=eightanaloginputs##############################################################
Here the output.
V=3726
F=89
@delinend Ok, so you have a slightly higher voltage and frequency - this could cause some timing issues, since the sketch is compiled at 8Mhz. Can you feed 3.3V, e.g. using a voltage regulator?
