  3. Sensor node not working without #define MyDebug
25 Posts 6 Posters 8.1k Views 5 Watching
  • Alex PopovskiyA
    Alex PopovskiyA
    Alex Popovskiy
    I observed similar problem with nodes communication, only in opposite direction, the gateway was fine but two of my nodes required MY_DEBUG enabled to function properly. One of them was completely unreachable without MY_DEBUG or a delay(10) in the loop(), and other node had big problems receiving data (a lot of fail's). I couldn't figure out where the problem was, my assumption is that it is some kind of timing problem, maybe the radio being polled to fast or something... and debug prints certainly add some time to code execution and that kinda solves the problem. But thats only my assumption, I may be completely wrong
    • delinendD
      delinendD
      delinend
      I have the same problem on Serialgateway 2.0.1-beta. If I disable MY_DEBUG, nothing can't connect to the Gateway.
      • delinendD
        delinendD
        delinend
        Update: If I set my RF24 to MIN (#define RF24_PA_LEVEL RF24_PA_MIN), then my NODE's can fine connect to my Serialgateway, with disabled MY_DEBUG. Hmm that's strange ?!?! So yes, maybe it's a timing problem. Btw. I use 47uF on all NRF24's.
        tekkaT 1 Reply Last reply
        • delinendD
          delinendD
          delinend
          I have solved it, with the fix from Alex, with a delay(10) in the loop() :-) Thanks
          tekkaT ayoA 2 Replies Last reply
          • delinendD delinend
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @delinend Please describe your GW setup, that is:
            • HW type
            • Frequency / voltage
            • Arduino IDE version
            • Board def version.
            I'd like to reproduce your issue.
            delinendD 2 Replies Last reply
            • delinendD
              delinendD
              delinend
              wrote on last edited by delinend
              • tekkaT tekka
                • HW type
                delinendD
                delinendD
                delinend
                @tekka
                Last Mysensor 2.0.1-beta
                2 Arduino Mini Pro (8Mhz) 3.3V version
                2 NRF24l01+ with 47uF caps
                Use a 3.6V LiPo battery on both setup's.
                IDE 1.6.12
                I use the standard GatewaySerial.ino and BinarySwitchSleepSensor.ino sketch, where the problem comes, when I disable the MY_DEBUG in the GatewaySerial.ino sketch.
                I think the problem is, that the "void loop()" in the GatewaySerial.ino is empty, and the Arduino has a timing problem to the radio, as the loop is running to fast, without doing nothing. If I add delay(10) into the "void loop", it all works fine.
                • tekkaT tekka
                  • HW type
                  delinendD
                  delinendD
                  delinend
                  @tekka
                  Btw. Another problem. If I use the "#define MY_DISABLED_SERIAL" on my GatewaySerial.ino I still get incomming message on the serial port. Ex. temp sendet from a tempsensor here:
                  6;0;1;0;0,24.5
                  6;0;1;0;0,24.6
                  6;0;1;0;0,24.5
                  6;0;1;0;0,24.4
                  6;0;1;0;0,24.5
                    tekkaT
                    tekkaT
                    tekka
                    @delinend
                    I also need the AVR board def version - you can find this information in the Boards Manager.
                    delinendD 1 Reply Last reply
                      @tekka
                      6;0;1;0;0,24.5
                      6;0;1;0;0,24.6
                      6;0;1;0;0,24.5
                      6;0;1;0;0,24.4
                      6;0;1;0;0,24.5
                      tekkaT
                      tekkaT
                      tekka
                      @delinend said:
                      @tekka
                      6;0;1;0;0,24.5
                      6;0;1;0;0,24.6
                      6;0;1;0;0,24.5
                      6;0;1;0;0,24.4
                      6;0;1;0;0,24.5
                      Well, there is no sense in disabling the serial port on a serial gateway :smirk:
                      • tekkaT tekka
                        @delinend
                        delinendD
                        delinendD
                        delinend
                        @tekka
                        BN: Unknown board
                        VID: 10C4
                        PID EA60
                        SN: Upload any sketch to obtain it
                        Btw. I use OpTiboot loader
                          ayoA
                          ayoA
                          ayo
                          wrote on last edited by ayo
                          So I tried to see if I make one last attempt to fix this problem again, I tried the Alex option using a delay(10) in the for loop. So I put a delay(10) in the for loop of my gateway code whoa it works fully well. I guess their is truly a timely issues here and the enable my_debug it's somehow doing a slowing things down work.
                          But using a delay(10) in the loop isn't really an efficient way though.
                          UPDATE: Using a delay(1) also works for me too
                            @tekka
                            BN: Unknown board
                            VID: 10C4
                            PID EA60
                            tekkaT
                            tekkaT
                            tekka
                            @delinend Still not the right thing. Sorry for bugging you with that ;)
                            You'll find the requested information under:
                            In Arduino IDE under Tools | Board | Boards Manager => Arduino AVR Boards Built-in by Arduino version 1.6.xx
                            • tekkaT tekka
                              delinendD
                              delinendD
                              delinend
                              @tekka
                              It's: Arduino AVR Board Built-In by Arduino version 1.6.14 installed.
                                @tekka
                                tekkaT
                                tekkaT
                                tekka
                                @delinend I've tried your setup but cannot reproduce your issue. Are you on the latest dev branch (from today)? What board did you choose in the settings?
                                Out of curiosity, please upload this sketch:
                                #define MY_CORE_ONLY
                                  Serial.println("***");
                                  Serial.print("V=");
                                  Serial.println(hwCPUVoltage());
                                  Serial.print("F=");
                                  Serial.println(hwCPUFrequency());
                                void loop() {}
                                and post the serial output.
                                • delinendD
                                  delinendD
                                  delinend
                                  #21
                                  Here the output.
                                  V=3726
                                  F=89
                                  The board name is: [Optiboot] Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
                                  As I use Optiboot bootloader.
                                  pro328o.name=[Optiboot] Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
                                  pro328o.upload.tool=avrdude
                                  pro328o.upload.protocol=arduino
                                  pro328o.upload.maximum_size=32256
                                  pro328o.upload.maximum_data_size=2048
                                  pro328o.upload.speed=57600
                                  pro328o.bootloader.tool=avrdude
                                  pro328o.bootloader.low_fuses=0xff
                                  pro328o.bootloader.high_fuses=0xde
                                  pro328o.bootloader.extended_fuses=0xfd
                                  pro328o.bootloader.file=optiboot/optiboot_atmega328.hex
                                  pro328o.bootloader.unlock_bits=0x3F
                                  pro328o.bootloader.lock_bits=0x0F
                                  pro328o.build.mcu=atmega328p
                                  pro328o.build.board=AVR_PRO
                                  pro328o.build.f_cpu=8000000L
                                  pro328o.build.core=arduino
                                  pro328o.build.variant=eightanaloginputs
                                    Here the output.
                                    V=3726
                                    F=89
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @delinend Ok, so you have a slightly higher voltage and frequency - this could cause some timing issues, since the sketch is compiled at 8Mhz. Can you feed 3.3V, e.g. using a voltage regulator?
                                    • tekkaT tekka
                                      delinendD
                                      delinendD
                                      delinend
                                      @tekka
                                      This is with my Lab Powersupply to 3.3V
                                      V=3300
                                      F=89
                                        @tekka
                                        V=3300
                                        F=89
                                        tekkaT
                                        tekkaT
                                        tekka
                                        @delinend ok, and still the same with MY_DEBUG and the latest dev branch?
                                        • tekkaT tekka
                                          delinendD
                                          delinendD
                                          delinend
                                          #25
                                          @tekka
                                          Hmm.. It works fine without the delay(10), at 3.3V! But if I rice the voltage to around 3.6-3.7V, I have to add the delay(10) again in the void loop(). ?!?!
                                          Btw. The nRF24l01+ is attached Vcc on the Arduino Mini Pro board.
