  3. Sensor node not working without #define MyDebug
25 Posts 6 Posters 8.1k Views 5 Watching
  • tekkaT tekka
    @delinend Please describe your GW setup, that is:
    • HW type
    • Frequency / voltage
    • Arduino IDE version
    • Board def version.
    I'd like to reproduce your issue.
    delinendD
    delinendD
    delinend
    @tekka
    Last Mysensor 2.0.1-beta
    2 Arduino Mini Pro (8Mhz) 3.3V version
    2 NRF24l01+ with 47uF caps
    Use a 3.6V LiPo battery on both setup's.
    IDE 1.6.12
    I use the standard GatewaySerial.ino and BinarySwitchSleepSensor.ino sketch, where the problem comes, when I disable the MY_DEBUG in the GatewaySerial.ino sketch.
    I think the problem is, that the "void loop()" in the GatewaySerial.ino is empty, and the Arduino has a timing problem to the radio, as the loop is running to fast, without doing nothing. If I add delay(10) into the "void loop", it all works fine.
    • tekkaT tekka
      • HW type
      delinendD
      delinendD
      delinend
      wrote on last edited by delinend
      @tekka
      Btw. Another problem. If I use the "#define MY_DISABLED_SERIAL" on my GatewaySerial.ino I still get incomming message on the serial port. Ex. temp sendet from a tempsensor here:
      6;0;1;0;0,24.5
      6;0;1;0;0,24.6
      6;0;1;0;0,24.5
      6;0;1;0;0,24.4
      6;0;1;0;0,24.5
      tekkaT 1 Reply Last reply
      • delinendD delinend
        Update: If I set my RF24 to MIN (#define RF24_PA_LEVEL RF24_PA_MIN), then my NODE's can fine connect to my Serialgateway, with disabled MY_DEBUG. Hmm that's strange ?!?! So yes, maybe it's a timing problem. Btw. I use 47uF on all NRF24's.
        tekkaT
        tekkaT
        tekka
        @delinend
        I also need the AVR board def version - you can find this information in the Boards Manager.
        delinendD 1 Reply Last reply
          @tekka
          6;0;1;0;0,24.5
          6;0;1;0;0,24.6
          6;0;1;0;0,24.5
          6;0;1;0;0,24.4
          6;0;1;0;0,24.5
          tekkaT
          tekkaT
          tekka
          @delinend said:
          @tekka
          6;0;1;0;0,24.5
          6;0;1;0;0,24.6
          6;0;1;0;0,24.5
          6;0;1;0;0,24.4
          6;0;1;0;0,24.5
          Well, there is no sense in disabling the serial port on a serial gateway :smirk:
          • tekkaT tekka
            @delinend
            delinendD
            delinendD
            delinend
            @tekka
            BN: Unknown board
            VID: 10C4
            PID EA60
            SN: Upload any sketch to obtain it
            Btw. I use OpTiboot loader
              I have solved it, with the fix from Alex, with a delay(10) in the loop() :-) Thanks
              ayoA
              ayoA
              ayo
              wrote on last edited by ayo
              So I tried to see if I make one last attempt to fix this problem again, I tried the Alex option using a delay(10) in the for loop. So I put a delay(10) in the for loop of my gateway code whoa it works fully well. I guess their is truly a timely issues here and the enable my_debug it's somehow doing a slowing things down work.
              But using a delay(10) in the loop isn't really an efficient way though.
              UPDATE: Using a delay(1) also works for me too
                @tekka
                BN: Unknown board
                VID: 10C4
                PID EA60
                tekkaT
                tekkaT
                tekka
                wrote on last edited by tekka
                @delinend Still not the right thing. Sorry for bugging you with that ;)
                You'll find the requested information under:
                In Arduino IDE under Tools | Board | Boards Manager => Arduino AVR Boards Built-in by Arduino version 1.6.xx
                • tekkaT tekka
                  delinendD
                  delinendD
                  delinend
                  @tekka
                  It's: Arduino AVR Board Built-In by Arduino version 1.6.14 installed.
                    @tekka
                    tekkaT
                    tekkaT
                    tekka
                    @delinend I've tried your setup but cannot reproduce your issue. Are you on the latest dev branch (from today)? What board did you choose in the settings?
                    Out of curiosity, please upload this sketch:
                    #define MY_CORE_ONLY
                      Serial.println("***");
                      Serial.print("V=");
                      Serial.println(hwCPUVoltage());
                      Serial.print("F=");
                      Serial.println(hwCPUFrequency());
                    void loop() {}
                    and post the serial output.
                    • delinendD
                      delinendD
                      delinend
                      #21
                      Here the output.
                      V=3726
                      F=89
                      The board name is: [Optiboot] Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
                      As I use Optiboot bootloader.
                      pro328o.name=[Optiboot] Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328
                      pro328o.upload.tool=avrdude
                      pro328o.upload.protocol=arduino
                      pro328o.upload.maximum_size=32256
                      pro328o.upload.maximum_data_size=2048
                      pro328o.upload.speed=57600
                      pro328o.bootloader.tool=avrdude
                      pro328o.bootloader.low_fuses=0xff
                      pro328o.bootloader.high_fuses=0xde
                      pro328o.bootloader.extended_fuses=0xfd
                      pro328o.bootloader.file=optiboot/optiboot_atmega328.hex
                      pro328o.bootloader.unlock_bits=0x3F
                      pro328o.bootloader.lock_bits=0x0F
                      pro328o.build.mcu=atmega328p
                      pro328o.build.board=AVR_PRO
                      pro328o.build.f_cpu=8000000L
                      pro328o.build.core=arduino
                      pro328o.build.variant=eightanaloginputs
                        Here the output.
                        V=3726
                        F=89
                        tekkaT
                        tekkaT
                        tekka
                        @delinend Ok, so you have a slightly higher voltage and frequency - this could cause some timing issues, since the sketch is compiled at 8Mhz. Can you feed 3.3V, e.g. using a voltage regulator?
                        • tekkaT tekka
                          delinendD
                          delinendD
                          delinend
                          @tekka
                          This is with my Lab Powersupply to 3.3V
                          V=3300
                          F=89
                            @tekka
                            V=3300
                            F=89
                            tekkaT
                            tekkaT
                            tekka
                            @delinend ok, and still the same with MY_DEBUG and the latest dev branch?
                            • tekkaT tekka
                              delinendD
                              delinendD
                              delinend
                              #25
                              @tekka
                              Hmm.. It works fine without the delay(10), at 3.3V! But if I rice the voltage to around 3.6-3.7V, I have to add the delay(10) again in the void loop(). ?!?!
                              Btw. The nRF24l01+ is attached Vcc on the Arduino Mini Pro board.
