  3. Serial API 2.0 question for custom code
1 Posts 1 Posters 753 Views 1 Watching
  • ierisI
    ierisI
    ieris
    I'm creating a custom project and want it to be compatible with MySensors API.
    I have a following situation and do not understood what would be the correct way of communication between gateway and node:
    Node-0 <-gateway
    Node-1 <-temp sensor
    Node-10 <-temp sensor
    Node-50 <-relay node
    Temperature nodes are sending data to gateway and relay node.
    By example relay node are receiving temperature from Node-9:
    9;2;1;1;0;21.60
    I want to send a 'set point' temperature from gateway to relay node, how this message should look like?
    0;9;1;1;45;22.00 ? (V_HVAC_SETPOINT_HEAT=45)
    Is it ok to send a temperature node-id in child-sendor-id place?
